Hydraulic Thumb on BH77
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
Everything is plumbed for the rear valve. Sorry, I hijacked my owned thread to talk about the rear remote.
But I get a leak from there:
That's the section between the PB sleeve and JIC fitting. Am I supposed to have a seal in there? I noticed that the sleeve goes deeper than the lenght of my fitting, so it wont press against the bottom. So am I using the wrong fitting or am I supposed to have a seal in there?
7,328
If the port in the sleeve is JIC you dont need a seal.
If its BSPP you need a sealing washer.
What say the company that sold ypu the valve?
awesome
Sep 16, 2018
320
215
ottawa
The valve port is bspp.
The male end of the sleeve, going into the valve is bspp. I dont know what the female end is but there is a bevel inside, just like JIC fittings.
7,328
Where did you get the sleeve? JIC fittings must bottom out.
My guess is the sleeve is SAE o-ring boss.
awesome
Sep 16, 2018
320
215
ottawa
I got it from princess auto. The inside looks like this
Really looks like a female JIC but much longer. So way the fitting can touch the bottom of the sleeve
awesome
Sep 16, 2018
320
215
ottawa
So end #1 is "sae" ? And I need an oring?
My fitting looks like that except that end #2 is npt for me
awesome
Sep 16, 2018
320
215
ottawa
I'm sorry, I'm confused. Which part goes in the sleeve? The SAE?
My valve has G1/2 ports. I have bspp-M to npt-M adapters on the other ports.
I want to connect a npt-m hose on my PB port.
7,328
I suspect the female port in the PB skeeve is SAE oring boss. Same thread type abd size as JIC .If your hose is male NPT this would work
awesome
Sep 16, 2018
320
215
ottawa
Ah, now I understand. Thank you.
I just looked at images of SAE oring boss and yess, it does look like that.
What confused me is that this section looks like JIC
Concept Automation LLC
B2650HSDC, BH77
Mar 12, 2026
74
20
New England
The M59 foot pedal never felt right. Added cleats that helped. Also added hand control rod that helped with delicate handing like stacking rocks. Hand control is more intuitive to me but probably a personal preference. Mention as hand control might be easier to fab
Funny the B26 thumb pedal though very similar is more ergonomic OEM design.
Once you experience a thumb, you’ll wonder how you did without.
Yet to get delivery of my used B2650HSDC / BH77, I did get it from Messick's. Having them add the Rear 1st. & 2nd. rear Hyd. option to her before delivery, as it includes the levers in the cab. Adding a Bexpanded Thumb mechanical for now, but see I'd want to put a Hyd. piston on the Thumb in the future.
Reading all the posts, seems best to have a hydraulic control of that cylinder, not a solenoid On/Off. To gently grab rocks and other items etc..
What I do not understand, is that now I will have Hyd. rear ports available. From the Cab, will the Lever control be just On/Off outputs to the rear ports ? If this is true, then I sort of have a rear 3rd. function capability to add. to control the Hyd. Thumb, what would be nice is a valve like the outrigger.
( Related to all Thumbs....Seems they are All too Short in Length, and should at least extend out to the bucket teeth. See when I get mine. I can cut & weld ).
