Hydraulic Thumb on BH77
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
Everything is plumbed for the rear valve. Sorry, I hijacked my owned thread to talk about the rear remote.
But I get a leak from there:
That's the section between the PB sleeve and JIC fitting. Am I supposed to have a seal in there? I noticed that the sleeve goes deeper than the lenght of my fitting, so it wont press against the bottom. So am I using the wrong fitting or am I supposed to have a seal in there?
6,242
If the port in the sleeve is JIC you dont need a seal.
If its BSPP you need a sealing washer.
What say the company that sold ypu the valve?
awesome
Sep 16, 2018
320
215
ottawa
The valve port is bspp.
The male end of the sleeve, going into the valve is bspp. I dont know what the female end is but there is a bevel inside, just like JIC fittings.
6,242
Where did you get the sleeve? JIC fittings must bottom out.
My guess is the sleeve is SAE o-ring boss.
awesome
Sep 16, 2018
320
215
ottawa
I got it from princess auto. The inside looks like this
Really looks like a female JIC but much longer. So way the fitting can touch the bottom of the sleeve
awesome
Sep 16, 2018
320
215
ottawa
So end #1 is "sae" ? And I need an oring?
My fitting looks like that except that end #2 is npt for me
awesome
Sep 16, 2018
320
215
ottawa
I'm sorry, I'm confused. Which part goes in the sleeve? The SAE?
My valve has G1/2 ports. I have bspp-M to npt-M adapters on the other ports.
I want to connect a npt-m hose on my PB port.
6,242
I suspect the female port in the PB skeeve is SAE oring boss. Same thread type abd size as JIC .If your hose is male NPT this would work
awesome
Sep 16, 2018
320
215
ottawa
Ah, now I understand. Thank you.
I just looked at images of SAE oring boss and yess, it does look like that.
What confused me is that this section looks like JIC
