In search of a better truck for towing the M6060 and folding cutter.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Whatever you find, just make sure you can 1000% verify the mileage.
MANY times a week we get cars & trucks, gas & diesel that the mileage has been moved on. On pretty much ALL manufactures.
Now, as techs, we can pop the hood and usually in two seconds verify that the mileage is incorrect. I know you're no spring chicken and can most certainly do the same. But im telling you, just BE CAREFUL. These bastards are slick these days.
When it comes to diesels in our shop, the bossman has the knowledge and therefore does 100% of the diag. If it comes in my bay, at that point, i'm only a parts changer.
We tend to get atleast 1 fuel system a week on the 6.7 powerstrokes. Last weeks victim:
Generally, its our farm accounts that have the most problem with these. They all run aux tanks in the bed and at some point they get a spec of dirt or water or some other bs in them and shred the injection pump. When this happens, she'll put metal through everything, even alllllll the way back to the tank.
And not being a diesel tech whatsoever, I now get ahold of the duramaxs, and moving around the fuel system you can clearly see a strong resemblance between the two. We don't get too many of the 6.6s but they do come in one a month or so.
I aint done or seen a 6.4 in atleast a year. We did floods of them years ago. Then they all went away lol. Ford knew they done f'ed up.
I would agree with most that cummins got it right. The engine is soild. The truck it is put in can be another story. We do a couple turbos a year on them. They're vgt style turbos and what we usually see is the unison ring seizing from carbon build up. On your own unit one can sometimes pull her down, clean her up real good, and get some more time out of it. But generally it just gets a turbo. And a few times a year we get one with a puking timing cover seal. For whatever reason, cummins decided to make the camshaft gear one with the cam therefore you have to remove the dang cam just to reseal the cover. I did learn a trick from a cummins feller that involves wooden dowels so you can leave the valvetrain where its at just pick the lifters up off the cam. Victim from 3 weeks ago:
And of course, who could forget the good ole 6.0s. You'll hear endless amounts of bad things. But truthfully, once you get them right, they'll stay with you quite a while. I think we've fixed most in our Hinds county area therefore, we don't see too many these days. We stud em, give em the updated heads, bulletproof if you will, and they're usually good to go a while.
Good luck with your search sir.
11,673
Excellent post!
I can go to the local Kubota dealer and try out anything on the lot but that's not so easy to do with trucks and trailers. I definitely need to do more research and think this through. The lowest risk but highest cost decision is to buy a late model or new F350/F450/F550, but it'd be easy to waste $30k by buying the wrong older truck.
I really appreciate all of the feedback in this thread. Your comments and experience could very well help me make the best decision.
jyoutz
Jan 14, 2019
3,590
2,692
Edgewood, New Mexico
Excellent post!
IDK about the rest of the truck, but if you buy that truck with the 5.9 Cummins, you will seldom have any engine issues and you can do all of the maintenance in 45 minutes yourself.
Edit: all of the engine maintenance in 45 minutes. IDK about the rest of the truck.
Like Tractors
Several Kubotas
Jan 1, 2020
98
150
Eastern Iowa
I was hoping you'd jump in. ☺ I will absolutely defer to your expertise, so if you told me that an '01 F-650 for around $28k is a bad choice I'd drop the idea yesterday! The dealer lists 205hp at 2,500rpm but I don't know if that's correct. Ford-Trucks.com has specs listed for all '01 F250 and up trucks, and they show the Cummins engine to produce 185hp @ 2,300 rpm and 420 lb-ft @ ?. I don't know if the data is accurate or not, and even if it is, gearing of the rear end and transmission have a huge affect on how a vehicle drives, and more importantly tows.
Well, that doesn't seem like a lot of horsepower or a lot of gears, unless the rear axle is a two speed axle. I haven't towed with a truck like that, I will defer to a towing expert, engines I know. One caution with that Cummins ISB engine is injection pump failures, especially if they have been subjected to low supply pressure. The turbocharger is a conventional design that employs a wastegate , pretty trouble free.
I have done towing with my 2000 F250 that measures 300 horsepower on my SuperFlo dynamometer, pulling a car hauler trailer with a 1997 F250 on the trailer from Rock Springs WY to home, that just plain walks the hills that that load like it's nobodies business. I am sort of a fan of the old 7.3L International built engine. I even have a Chevrolet version of the ole 7.3L.
Botamon
Mar 26, 2018
471
893
Winnemucca, Nevada
Personally, I think you'll be disappointed if you are just looking for a truck to pull a lot of weight and yet accelerate and keep up with traffic. All of the medium duty and heavy duty trucks have derated engines; they don't have the horsepower/torque of the pickup engine equivalent but will last forever. It just takes long to get all that weight up to speed. I see those heavier duty trucks holding up traffic on all our mountain passes here in Nevada. The only trucks that could pull a lot of weight and still accelerate fast enough to keep up with general traffic are purpose-built pullers like those you see at the pulling contests. 2,000+ horsepower - and the engines are good for only a few pulls!
That being said, if what you really need is a more stable towing platform then I agree with jyoutz. Find an older (preemissions) Dodge/Cummins dually with the 6 speed manual transmission, with not too many miles, that hasn't been beat up/rusted out. Pre - emissions means any of the 5.9 engines; if it has the 6.7 Cummins then it will have emissions crap on it. If you get one with the automatic transmission, you'll need to have it beefed up to handle a lot of weight and still last. Just be aware that even though these trucks are 20 years old - they are still selling for close to or as much as they sold for as new, if they have less than 200,000 miles on them. And that's because people are willing to pay those prices to not have to deal with the newer diesels with the problematic emissions.
I have a 2004 Dodge Cummins dually, 6 speed manual. ONLY repair ever done on it was to change the water pump a few years ago. It has only 78,000 miles on it but then like you, I only use it when I need to pull a load. I'll own this truck until I am too old to drive.
This load scaled at 28,000 lbs:
Hauling my M7060, or the big cabover camper with jeep, I never have to shift out of 6th gear on any of the mountain passes. That engine just PULLS...drama-free.
11,673
@Like Tractors and @Botamon, thanks for your replies. So much to think about for sure.
Midwest Military Equipment are arguably the experts when it comes to the M1078, so I called Joe (owner I think) this morning to ask about towing an 18,000lb trailer and he told me that the A1 version would be more than capable since it's up around 300hp and has an exhaust brake. I have the gen 1 model which is sometimes referred to as an A0 and not as well suited to that sort of towing. The Caterpillar engine is mechanical on the A0 models with no electronics, unlike the A1 engines.
For the record, a nice M1078 A1 is around $50k.
The journey continues.
Like Tractors
Several Kubotas
Jan 1, 2020
98
150
Eastern Iowa
Now there ya go, I love it when a guy does his research by tapping the experts! Out of curiosity, which Caterpiller engine do you have in that old dog?
11,673
My M1078 is a '98 model and has the Caterpillar 3116 inline six cylinder with turbo charger and intercooler. It's rated at 225 hp @ 2,200 rpm and 637 lb-ft @ 2,600 rpm (seems backwards). It has a 7-speed Allison 3070 automatic transmission. It's also AWD with a 30% front 70% rear distribution until it's put in 4WD mode and then it's 50% front and rear.
Like Tractors
Several Kubotas
Jan 1, 2020
98
150
Eastern Iowa
Is that truck built by General Motors? Many moons ago, a GM friend/associate of mine told me that the 3116 will only be Original Equipment in a GM built vehicle, some agreement with Caterpiller I was told.
I have done dynamometer testing and various repairs on the Cat 3116, I will have to look up some test records to see what sort of power they put to the earth.
That transmission is a pretty tough gear box.
11,673
Made by Stewart & Stevenson Services, Inc. Here's the manufactures plate in the cab of my truck.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
470
267
Randolph county N.C.
I like the F-650 buy idea. It wont be fast but will be very safe, capable and simpler to maintain than the newer stuff.
I drove a roll back F-650 tow truck with the Cummins and an Allison automatic. That tow truck started life as a box truck and at 140k miles the roll back bed was installed. Truck now has 300k and is the most reliable lowest operating cost truck out of the 6 truck fleet.
I currently own a 2001 F-550 with the 7.3 Powerstroke. I added an aftermarket turbo, BTS built trans and it is tuned. I purchased it to tow a large 5th wheel trailer to be a full timer, that didn't work out but I still have the truck. I understand the comment about large gaps between gears but it is a minor issue. The new stuff on paper is more capable but not as reliable. If you scroll around on Ford Truck Enthusiasts forums they have a good section on medium duty trucks.
11,673
Interesting! Maybe a chassis/driveline produced by GM. It was just a curiosity thing. What RPM does the engine run at your desired cursing speed? Have a picture of the engine label by chance, more curiosity on my part.
Hmmm .... good questions. The top speed with the factory rear end is 58mph but I couldn't tell you what the rpm is. I'll look for the engine label without raising the cab, but if I need to raise the cab it'll have to wait until the spring. 😂
11,673
I haven't even begun to look into possible upgrades on an F-650 with the Cummins 5.9L engine, but the rear end is supposedly a 4.11. The dealer says that it's a 6-speed manual but online specs indicate a 5-speed as being "standard" but does list other Eaton transmissions including a 6-speed and 7-speed. I could swear that I can see a 7 on the shift knob so I texted the salesman to ask for confirmation.
11,673
The salesman took a photo late this afternoon confirming that the F-650 has a 7-speed manual transmission. So it's a Spicer and either the ES52-7B or ES066-7B. Does this change anyone's mind either for or against?
CGMKCM
Jan 26, 2021
470
267
A couple of things I can suggest.
Check on insurance cost and cost of registration. My truck is insured through Farm Bureau and I get a good rate because all of my insurance is bundled through Farm Bureau. No auto insurance company would issue a policy because it is a commercial vehicle.
Registration costs are really high in N.C. because it is a commercial vehicle and I have to buy tags rated for 22k pounds. Weight of truck + maximum weight of trailer (10k) I can tow with a non-commercial drivers license. N.C. changed its registration laws several years ago to get more registration$$$$. I could apply for farm use tags but there are restrictions on using the vehicle for recreational purposes.
7 speed is a nice bonus. I dont know anything about the Spicer transmission. The Eatons lost the syncros about every 60k miles on our Two 4700 International tow trucks.
jyoutz
Jan 14, 2019
3,590
2,692
A Cummins 5.9 and a 7 speed transmission. This should be a reliable workhorse that may not be speedy but capable of towing a house. That 5.9 was the standard engine for forestry log skidders for quite a few years. But, a one ton duelly with the same engine would also do the job in a smaller platform, that might allow you to also sell your current 3/4 ton truck.
11,673
So something like this truck?
jyoutz
Jan 14, 2019
3,590
2,692
The 5.9 to 6.7 change over happened in mid year 2007. Mine is an early year 2007. The re-designed and beefier automatic transmissions were rolled out in 2005 and they hold up to the torque of the engine. So the sweet spot is a 2005-early 2007 Dodge with the 5.9 and automatic transmission, or 2003-early 2007 with manual transmission.
That truck looks sweet. I bought mine in Texas also because no rust.
Botamon
Mar 26, 2018
471
893
Winnemucca, Nevada
Yes! That one's a beauty and not too many miles on it considering it is 20 years old. If it has good maintenance records and a clean CarFax I'd jump on it. Price is high...almost no depreciation in 20 years...but as I said, they are in demand because taken care of, they'll last forever.
Copy the VIN # and paste it into this web site and it will give you the full build sheet:
