Old style PTO shaft compatibility
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
449
706
NH
Bought a used 3ph Hurd sander ($600). New ones run in the $3-4K range. Unfortunately, the PTO shaft is too short and is of the old square telescoping tubing style. Also, the sander side of the PTO shaft is permanently affixed with no collar that slides off. Do they make some sort of square tubing extension kit? If not, would a weld shop be able to extend the shaft? I'd also happily get a new PTO shaft but what do I do about the sander end of the shaft which has no collar fitting?
Guess this is what happens when buying used equipment. All thoughts, suggestions, verbal abuse welcome. Thanks.
jyoutz
Jan 14, 2019
3,624
2,718
Edgewood, New Mexico
Could you get an extension cord from the tractor pto side instead of the drive shaft extension?
Gaspasser
Dec 16, 2023
449
706
NH
So the joints have to be aligned in the same plane? Always learn something here. Thanks.
Gaspasser
Dec 16, 2023
449
706
NH
Yep, if they make something like that.. It would have to be on tractor side. I'll have to crawl under in the snow and measure. Only place I'm aware of is TSC in my area. Thanks.
airbiscuit
Mar 18, 2021
405
463
NW WI
If it's only a few inches short, PTO overrunning clutch might work
Also, check out some vids on U-joint phasing.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
574
249
CNY
Yes you can get square pto shaft parts. Bothe male and female ends. I would measure it first as they do make rectangular sliding shafts as well.
But by the time you get that figured out you could probably buy a new shaft from Amazon and replace it. Just need someone who is skilled with a cutting torch to get that yoke off the other shaft.
Of course pics and measurements would help.
Gaspasser
Dec 16, 2023
449
706
NH
Sun was going down but I'll take measurements and pics tomorrow. Thanks for all input folks. I'll provide more info tomorrow.
jyoutz
Jan 14, 2019
3,624
2,718
I didn’t mean to say extension cord, I meant extension collar like air biscuit posted.
airbiscuit
Mar 18, 2021
405
463
NW WI
A truck driveline/driveshaft shop might be able to help you out.
airbiscuit
Mar 18, 2021
405
463
NW WI
As far as dimensions go:
What is the width of the smaller square shaft ?
How much too short do you think it is (does it not even reach the larger shaft)?
Pics are good too
airbiscuit
Mar 18, 2021
405
463
NW WI
This might help you get your head wrapped around this - but you probably already know this.
11,016
I can buy that rectangle PTO shaft at the local farm store.
I looked around and a lot of places sell the shafts you just need to know the measurements.
But if you can't buy a longer shaft, I don't recommend these, but they are all sold.
airbiscuit
Mar 18, 2021
405
463
NW WI
I get why you don't recommend them. I would be worried about what those long extensions would do to the bearings of the tractor PTO.
Gaspasser
Dec 16, 2023
449
706
NH
Thanks gang. Ran around all day to Kubota dealer, TSC, and called Kasco Mfg (maker of Herd spreader). Paula at Kasco was very helpful and knowledgeable. Turns out the PTO is rectangular and the spreader side is bolted to the shaft of the implement gear box with no "easy-off" collar. The tractor side has the usual detachable collar. Picked up PTO shaft extender and overturn clutch as was suggested here at TSC but neither works as L6060 PTO shaft has no through shaft hole to securely attach these devices. So, at this point, seems like the best solution is to order a PTO shaft from Kasco. Need approx 34 inches to link tractor and spreader. Thanks again for all the helpful input guys. Guess I learned a lesson.... buy new next time, lol. This tractor has been giving me quite an education.
11,016
Your really over complicating this, the rear coupling is a standard round shaft pin on coupling, easily replaceable.
You could buy a standard PTO shaft and replace it.
Like this:
Gaspasser
Dec 16, 2023
449
706
NH
Your really over complicating this, the rear coupling is a standard pin on coupling, easily replaceable.
Like this:
Thanks Wolf. Relative newbie here so over complicating tendency due to my ignorance. I aplogize if I am asking basic question. So, if I'm understanding you correctly, I can detach the universal joint from the spreader gearbox and use standard PTO shaft as you cited. I see that one end attaches to tractor with the standard splines. Is there a collar coupling on this end of shaft? Hard to tell from pics. The other end (implement side) has a round shaft fitting. I will have to measure the shaft diameter to ensure compatibility. I'll, keep you posted. Thanks again.
11,016
Thanks Wolf. Relative newbie here so over complicating tendency due to my ignorance. So, if I'm understanding you correctly, I can detach the universal joint from the spreader gearbox and use standard PTO shaft as you cited, Wouldn't I have to get a pin on universal joint with splines to attach to the gearbox shaft so that the PTO shaft has a compatible attachment point?
Measure the diameter of the shaft (green) and give me the length and I'll point you to the shaft you need.
