11,757
2" of fresh powder last night so more snow removal this morning before heading to town for meds. I have the flu or similar so not feeling great. I will say over and over how much I like this MX6000 and the snow clearing set up I have. I'm able to do a good job on the asphalt with the blower, and the gravel with the front blade.
I put quite a bit of work into the blower a month or so ago and it's a beast for sure. It was flinging large chunks of ice this morning, nasty, jagged chunks but it didn't miss a beat. The spring that I installed to hold the hoses works great, the spacers on the cylinder for the chute angle work great, and the repairs to the auger and baffle (for want of a better word) certainly don't hurt. I think that this SB1574 will be around for many years to come. I'll change the gearbox oil in the spring ready for next year.
The M6060 is plugged in so I might give the new to me hydraulic rear blade a spin to see how it does with removing the snow along the edge of the lower driveway. If I start to slide I'll have to drop the blade and hope that it serves as a decent anchor. The R1 tires are great for most things but not sure how they'll do on a thin layer of snow.
Reactions: 12 users
Rosohatica
Kubota L3200, Tehnos MULS 130 flail mower, Fužinar 14” plow, Landforce 5′ tiller
Feb 23, 2022
234
106
Zagreb, Croatia
Did you have it in 4wd? 4wd helps with braking too, as the front wheels will brake too.
Also in 4wd you can keep a little more traction.
Chains are a huge help in Snow, Ice, Mud and Slime, you might really want to look into them for future use.
Yes I was in 4WD but remamber how my front tires look like? Not much thread left there.
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
I just picked up this for my diesel jug. I have a similar one for my gasoline jug and love it.
This is gonna make it easier to add fuel to the tractor, especially where Kubota likes to put their fuel tank.
Call me lazy...but why work harder? No splashing, no losing fuel. It cost money ya know.
Just what I need :)
Rosohatica
Feb 23, 2022
234
106
Zagreb, Croatia
@Rosohatica : Diamond-pattern chains, even without studs, should cause your tractor to stay grippy. They cost more, but less costly ladder-bar chains have non-chain areas that ride rougher and can slide when braking--pumping the brakes helps if the wheels rotate and catch, or you might have to go forward a little to rotate to a chain area (and sometimes only one wheel catches), experience helps. More ladders also helps but the cost goes up and at that point diamond pattern are only slightly more.
Studs will damage pavement and concrete, and dirt paths and everything else, but wow they grip. I have them on lighter equipment for use on hard ice.
Thanks. I was looking at so called ( at least around here) horshoe chains. They look like this:
Scottly
B2601, LA434 loader, SpeeCo E-Hitch, LP-FDR 1660 mower, LP-GS0560 land plane
Jan 24, 2017
36
58
Indiana
No good deed goes unpunished they say.
We have more snow coming tomorrow so I thought I would push the piles back for me and the neighbors.
Plowed up a big rock I didn't see and backed over it. Punctured 1 of the hydraulic filters.
A quick trip to dealer and $226 later I am back in action.
Changed both filters since I was under there and added 4 gallons of fluid.
I have refused payment from all I have plowed out.
  • Sad
Reactions: 7 users
nerwin
Z452KWTi-60, L2501, LA525, HLA Forks, Land Pride STB1072
Nov 13, 2024
647
1,870
Vermont
youtube.com
I feel guilty. Haven't used the tractor in two weeks. It's been single digit temps, no snow to plow. Besides installing lights on it and greasing it earlier this week, I went out to the garage today and touched it and said don't worry, you'll be put to work soon. 🤗
5,164
I too feel guilty, I am 5 hours overdue for the 200 hour oil change, and it has been so cold outside that it isn't going to get done anytime soon unless the temperatures rise enough that I can do it without getting frostbite.
fc1
L3940
Apr 17, 2024
Wood, as per usual. The sun was out yesterday (been a minute) so I took a break from work to move and stack some splits...
Low 20s (*F) so pretty easy to stay warm so long as I was moving; once the tractor was warm I ran it at a higher RPM than I would in warm weather. It's my first winter with a diesel, and I didn't know what to expect. Operation was flawless.
biketopia
Feb 15, 2024
435
467
Warrenton VA
A co-worker brought me a light-duty 3pt 7' blade. I hooked that up and spent over an hour on the driveway and parking area. It helped a pretty good amount, It might just be on a long-term loan to me now!
Old_Paint
Dec 5, 2020
2,047
2,334
AL
Meanwhile in Alabama….
I think the general reaction is “Aw heeell naw!” Got about 3” accumulation meaning at least 6” probably fell. Temp is 31F right now and I felt sprinkling rain on my noggin when I went to feed and water the chickens, so it ain’t gonna last long unless it gets a lot colder. According to the Weather Channel, 97% chance of rain and 37F for the high today. It’ll be gone by lunch time.
The governor (we fondly call her MeeMaw) declared a state of emergency last night and rightly so considering we have nothing to handle it and only idiots think they can drive on the sheet of ice that usually comes down before the snow does. Fortunately, it doesn’t look like we got the usual ice this time. I still see a few brave (or stupid) souls on the nearby road. By the time I got out to the chicken pen and back, I heard no less than 3 go by intentionally spinning the tires and playing on a very dangerous morning. They forget that if there is a SOE in the state, their insurance can and will refuse coverage. I’ll just watch from the sidelines.
Reactions: 8 users
Old_Paint
Dec 5, 2020
2,047
2,334
AL
They sound more Canadian than MidWestern, but yeah, that’s similar to winter driving training in Alabama. But the first lesson in Alabama is to make a run to the grocery store and buy a year’s worth of milk and bread just in case the snow lasts more than two days.
Moose7060
Oct 14, 2023
827
2,243
bc
They don't sound even remotely Canadian.
7,662
Get your wax out! You can do that in the shop, so the outside temp not important. ;)
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Thinking of a new to me chariot for the MX. Not that I need to haul the tractor often, but I have to borrow a trailer from work, don’t want to make a habit of it. This is 30+5 and the guy will take my car hauler that the MX is too big and heavy for and $4k. I’d be into the gooseneck for $6k total.
@RCW think this will be enough trailer from this?
Here’s the work trailer for reference. 24’ of deck.
Reactions: 9 users
nerwin
Nov 13, 2024
647
1,870
Vermont
youtube.com
Well I hopped on the tractor today and did some snow clean up. Didn't get much...maybe inch or two...but its been accumulating the last week or so with the winds its been making drifts. I wanted to clean up the snow banks, widen the driveway for a potential snowstorm this weekend. I also scrapped down the driveway so there isn't too much slush if it warms up enough. Just some simple work but was nice to be outdoors and not risk getting frostbite haha. Plus the sun felt good on the skin. Needed that..fresh air was nice when I wasn't smelling diesel lol.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
198
201
I totally understand. I HATE having to go to the neighbors to borrow things. I just sold my 14 foot motorcycle trailer. I'm looking for a 20 foot car hauler now. My neighbor has offered use of his 16 ft car trailer anytime I need it, but no thanks.
I'd rather own than borrow.
