Buying tires and Rims ?
9,667
They're the same chassis, hydraulics and drivetrain, just a smaller engine driving it all. Unlike the bx 70 and 60 series that had different frame and components for the 18hp models. The 1880,2380 and 2680 now all share components.
Lets hope your right.
SRD-BX
2022 Kubota BX1880
Dec 30, 2024
Ottawa, Ontario
I have a 2022 BX1880, I upgraded to bx2380 wheels and tires brand new from the dealership for 650CAD ( 453USD). The fit is perfect, 0 issues as all the BX 80 series use the same frame.
See pictures for size comparison.
in case anyone is wondering what the bx1880 looks like with BX2380/2680 wheels. No rubbing, clearance issues but better ride quality for sure. This is with the 48” MMM.
9,667
How did this affect the cutting height of the deck?
SRD-BX
2022 Kubota BX1880
Dec 30, 2024
Ottawa, Ontario
it sits about an inch higher so I presume instead of cutting on 3.5 I will have to bring it down 2.5 instead. Its winter here so no mowing currently but will update this in the spring time. I think there are mower height adjustments I can make but havent looked into it yet.
9,667
I do like the Beefier look of it with the bigger tires.
Taller tires = better land speed, but also lower torque.
And with that unit having less HP available then the tractor that the tires are designed to run on.
If your using it for snow duties I would be curious if the torque is as good?
SRD-BX
2022 Kubota BX1880
Dec 30, 2024
Ottawa, Ontario
I have a 50” blower on the back and have blown 7-9” with no problem. I always use L gear for plowing or snowblower work and so far 0 issues.
If there is bigger snow that mine cant handle, il use our TYM T25.
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
195
139
Villa Rica, GA
My BX1880 came with 12x24 turf tires. Can I fit the 12x26 R14's on the same rims and will they fit my tractor. I'm have trouble finding R14's the right size.
Bearcatrp
Mar 28, 2023
1,068
696
Minnesota
I have R4’s for just winter duties. I put the turfs back on for cutting grass. Going to put them back on to see if any rubbing. I like the 2-3 inch lift with the R4’s. Will post my results when I do it
Unnecessarytools
Mowing, tilling, snow blowing, pumping
May 28, 2025
Lethbridge, AB Canada
Purchased my 1880 with turf tires. Thinking of ordering the other tires for winter use, more traction. Don't care for chains. Does someone besides the dealer sell tires and rims for our tractors at a better price? Thanks
I have some brand new 6 bolt kubota rims meant for 23x8.5-12. Not sure if you would be intrested
Bearcatrp
Mar 28, 2023
1,068
696
Minnesota
Bought another set with R4’s awhile back. Am good to go. Thanks for the offer.
9,667
If you have 12x24 turf tires you're in a bit of a pickle because you have some odd tires.
Now if you have 24x12 then that's easy:
Bearcatrp
Mar 28, 2023
1,068
696
Minnesota
You will need to get the rims from the 23s so they match by the ratio front to back like the 1880 has. Surprisingly the complete set is cheaper than buying individually. Found this out when I put a hole in my front turf tire that came with my 1880. Makes no sense to me but it is what it is.
