I could really use this Buhler/Farm King 8ft hydraulic angle rear blade.
10,093
If the pictured holes are (as you purchased) the rear blade, they look to be made for hardened bushings to be pressed in similar to what Land Pride does.
Good luck with your Remedy. ;)
Thanks! And thanks also for getting me to go in a different direction, one that I'm pleased with. Yes, the earlier photo with the CAT 2 to CAT 1 pin shows the holes as the implement was purchased. So you think that bushings for a CAT 2 pin might have been in those holes originally? That's an interesting thought.
Today was a much better day. I used plasma to open up the holes for the pins and also to do some weld prep in the form of cutting a bevel around six of the eight faces to be welded. I then used 7018 rod to completely weld up the pins. I'm happy with how this has turned out and it's certainly a lot stronger than it would be with pins that are free to rotate and slide. The welded pins obviously tie the two plates together which makes it much stronger (not necessarily needed of course). Those plates that hold the pins are over 1/2" thick, more like 9/16" so pretty stout as it is.
I did a bit of clean up grinding too, for example the two plates where the top link connects via a pin. Some ACE Hardware gloss black paint made everything look decent. It was easy to get the implement on the M6060 after I swapped out the top-n-tilt for the original top link and lifting rod. I connected the hydraulic hoses and cycled all three cylinders and they work great. I have them set up the way I want and will check and most likely add hydraulic oil tomorrow since the blade probably took 1-1/2 gallons.
I'll take the blade for a spin tomorrow. :)
MtnViewRanch
881
328
Lakeside Ca.
With the blade being as low as it is when lifted, you will soon find that you need your top link just for general transport.
You do not need to remove the T&T set; just unplug them, and they are as solid as the OEM manual links.
You're going to need those diverters sooner than you might think. :)
10,093
Yeah, that fancy 4x multiplier might get ordered early in the new year. For now I need to remove the top-n-tilt so that I have three rear remotes to use with the rear blade. The blade can be raised high enough for the sort of tasks I'll be doing this winter. I need to get the 3-point leveled up tomorrow and remove two zerks and see why they won't allow grease to flow.
9,866
Upgrades / Updates, It's such a slippery slope! o_O :ROFLMAO:
MtnViewRanch
881
328
Lakeside Ca.
WHY? Simply unplug the couplers and bungee the ends up out of the way. The cylinder-s should be rock solid. That way you have easy adjustment when needed.
I believe that it is easier to plug-unplug couplers than to manually adjust the links, no??
10,093
I understand your point, and you've made it earlier in this thread, but here's a list of the reasons why I swap out top-n-tilt on both tractors. 😂
  1. It only takes 5 minutes to switch out top-n-tilt for the standard top link and lift rod
  2. Swapping out top-n-tilt allows for servicing/greasing pins
  3. Swapping out top-n-tilt means that parts aren't sitting on a shelf for decades not being used
  4. I don't like the idea of hoses and fittings out back that aren't being used
  5. It's tidier/cleaner not having unused hoses and fittings hanging around out back
  6. The top link and lift rod only need to be adjusted once
  7. Because they're my tractors
I've been reading up on draft control for both tractors and am looking forward to trying that feature today. It's cold this morning but it should warm up later today. The M6060 is plugged in and warming up too.
10,093
OK, you have your reasons. :cool:
You've been an enormous help in this thread what with the Scorpion grip controls, the Summit multipliers and the suggestion to weld the CAT 3/CAT 2 pins in place. There's only so much I can absorb, but if next year I'm using top-n-tilt cylinders in the way you suggest I'll be sure to thank you for that too. :giggle:
As for draft control, I hope it's everything you say it is and that I can get the lower gravel driveway as flat as a runway.
MtnViewRanch
881
328
Lakeside Ca.
Regarding draft control, as long as you understand how to set it up (adjust it as needed for the circumstances), it will work as needed.
10,093
I was able to test out the Buhler/Farm King blade yesterday and it's pretty awesome, but unfortunately my road grading skills are not. The conditions were near perfect when I started, but a couple of hours later (was supposed to be a 30 minute test), the gravel was soft and I got myself into all kinds of issues.
Regardless, the blade is excellent and will see a lot of use I'm sure. The second photo shows how much overhang the blade has when swung all the way over to one side, and with the wheels on solid ground I should have no problem pushing snow over the edge and rolling downhill.
The M6060 is running like a top and is enough of a beast to pull a loaded blade uphill in 2WD which is impressive, and that's not in creep range, just low range and first gear at 1,500 rpm. I'm going to remove the snow blower and hook up the EA land leveler to the MX later today and try to improve on the finish.
10,093
That looks very similar to my Bison blade. It’s built much heavier than the equivalent Landpride model. I’m very pleased with it and if the farm king is still available at a good price, you should buy it.
How much play or slop do you have with your Bison blade at the location shown by the arrow in the schematic below? I think there's some excessive spacing so will try to tighten bolt #43 and see if it closes the gap a bit. It's not a big deal but I imagine that the bolt can back off over time as the blade angles back and forth.
jyoutz
Jan 14, 2019
3,482
2,569
Edgewood, New Mexico
My blade has very little slop. In fact before I got the hydraulic cylinders, it was a bit stiff to move by hand.
10,093
This afternoon I removed bolt #43 that threads into the king pin, and the top of the king pin is flush with the top of the boss that the 3-1/2" O.D. disk sits on. So without removing material from the top of the king pin there's no way to close up the gap between the king pin weldment and the boom. I had to get the 3/4" drive Tekton ratchet on the bolt since I couldn't get it to budge with a 2ft 1/2" drive breaker bar or the M18 1/2" impact.
I see no way for the gap to get wider through use unless the king pin has somehow stretched. I'll leave it for now but will take another look when the weather improves. It's not really affecting performance of the blade, but there does seem to be excessive play between the blade and boom.
jyoutz
Jan 14, 2019
3,482
2,569
Perhaps install a bushing or large flat washers to take up the slop?
9,866
I was going to say, my take is, remove a little length (but not too much) off the kingpin to tighten it up.
