Seat Safety Switch Bypass
CommanderDave
L3301
Nov 1, 2022
10
Western Iowa
I would like to bypass my tractor's seat safety function with a separate on/off switch. I don't want to have it permanently disabled. Tractor is a 2023 Kubota L4060 ROPS model. I've attached a photo of the wiring. You can see where the safety engage button is located and where I would install a switch on the blank plate. My question is where do I tap into the wires, just after the button, or on the other side of the gray connector in the line? Also, I guess I have one other question...is this the only safety function, or is there another "switch" located inside the seat? Thanks.
11,280
You would have to give me the actual model your working on, as there are several L4060 ROPS units.
I will only tell you if there are mutiple safety switches which there probably is.
I will not tell you how to bypass it.
And FYI your dealing with a computer controlled tractor, get shorting out wires wrong and your very very likely to fry the ECU
Why do you want to bypass the safety switch? :unsure:
My Personal / Business opinion, I think bypassing safety switches is a BAD idea.
CommanderDave
L3301
Nov 1, 2022
10
Western Iowa
Let me guess, you voted for Kamala.
  • Dislike
11,280
I think we should play the game... "why did i drop the ban hammer on him at Mach speed".🧐
Give me your best answer why. :unsure:
One hint: It's not based on who I voted for. ;)
5,576
@North Idaho Wolfman ......OOOO....Illl play, Ill play....
I hate to state the obvious, but since its a mechanical switch, It won't be that hard to figure out how to depress the button.
Reactions: 6 users
7,361
7,717
Maybe because he's extremely derogatory. Been on forum two years, ten post and doesn't appreciate good information that doesn't suit him. Doesn't understand there is some information that others will not express on an open forum, but may be available by other means if really interested.
MountainMeadows
Jun 6, 2022
220
291
Poconos, PA
Because you never By-Pass the Safety Switch until you remove the ROPS?
btw, I voted for joe but forgot he wasn't on the ballot...........
ayak
L3301 HST
Feb 16, 2018
789
1,303
WV
I’m going with ā€˜salts and peppers his food before tasting it.’
WI_Hedgehog
Apr 24, 2024
1,130
1,647
Milwaukee, Wisconsin, U.S.A.
Hey, I have a switch that bypasses all the safety switches and I would have voted for Kamala in a heartbeat if I lived south of the 49th.
I just ordered a switch to do the same. If I lean to the left while hooking up a front implement all sorts of regulations kick in. :ROFLMAO:
It is annoying. When I'm mowing and lean over to grab something the "safety" shuts down the machine. If I'm hooking something up and need to move the tractor 1/2" I've got to go from the hydraulic lever side to the left side (where not much useful happens), get on sit down, take things backwards, ... lots of work to do almost nothing. :unsure:
So I ordered a red switch. (Somehow in this case it does not mean Communist, as if someone in the media purposely misrepresented the colors.) Waterproof, illuminated when on, flat-faced so it can't be pushed accidentally, etc. It's going in the dash where it's plainly visible (and kind of annoying when on), so if that's not "safe" I don't know what is. (y)
(While I did order a very specific switch, the above post is meant in fun.)
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
Link to switch? I’ll be expecting a write up, with pictures also. I have the same problem when my forks are on. Gotta stand a bit, flashing lights and sirens start wailing, pain in the butt.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
614
640
Lake Almanor, Ca
I do believe that there is a previous thread around here somewhere where this exact behavior is discussed.šŸ˜Ž
Being rude seems to be a common things these days, unfortunately.
Judicious use of the ban hammer Wolfman.
3,401
Yep!
Also, when the guilt feelings overcome you, remember that the "Powers that be" have no issue with you running the tractor with the seat belt on, and the ROPS folded down.
If you have a open station tractor, this seems to go against accepted safety guidelines...and not recommended if you decide to roll the tractor on a side slope.
Hummmm...And...where are the side slope tilt switches that shut the tractor down if a given angle is exceeded? Really needed to protect us from ourselves...
5,691
Awww go ahead tell him how to bypass everything that is in place to try and keep him and others safe, I am so sick and tired of people, that think they know better, and have yet to figure out that these things are there because somebody died,, so yeah by pass everything, and clean out the bloody gene pool, remember it aint if, its when ! OK Im done now,, I think
6,328
as for 'how=to=bypass', 1st get the correct wiring diagram for your exact model tractor.
I can't tell from the picture if that 'seat switch' is SPST-NO, SPST-NC DPDT-NO_NO or SPDT. What type it is does make a HUGE difference as to HOW you can bypass it.
Since some need to bypass switches, manufacturers have gotten clever using something other than a simple SPST switch(2 wires). In the early years ADT used SPDT switches for their alarm systems,making them impossible to defeat when connected to a control panel with window comparator inputs.
Why some won't tell you how to bypass ? , is for legal reasons. If 'A' tells 'B' ,do 'this' and 'B' gets maimed, 'B' could sue 'A'.......
Scm
BX23S
Sep 28, 2024
444
415
Missouri
That "safety" switch is the one thing I really don't like about my new tractor. Maybe there is something wrong with it? But I'm a small guy and I live on the side of a mountain. If I add a ratchet to my seat belt and strangle myself to the back of the seat it MAY not shut off the machine. Otherwise, just going down my hilly road and sliding forward even a little on my seat will kill the machine. Super annoying. Uphill, no problem.
Is there a way to adjust them so they are not so sensitive?
