MX6000 Water Separator Dash Light Question
GrumpyFarmer
4,646
That’s what I thought to, well was hoping anyway. Once they looked everything up, they’d see parts are back ordered.
I still haven’t heard back from my dealer… I’ll call again tomorrow.
Well from my first conversations with them to the text, when they realized something was actually back ordered they said it may be a little bit and that,”Yes absolutely please check in. Once it gets in the system I will be able to put in an order status check and give you a better idea.”
I am not sure what their system is or anything on the process, but I left i would check back in a few weeks if I have not heard from them. They agreed that was fine. I don’t want to pester so I wanted to set a time to check back. I am sure they are busy.
jyoutz
Jan 14, 2019
3,494
2,581
Edgewood, New Mexico
Can you keep me posted? I also bought my tractor in 2021. I’m traveling now, but will check with the dealer next week. Did they process the order as a warranty claim? Recall?
GrumpyFarmer
4,646
Good day.
Sure, I will share updates as info from dealer changes.
Regarding order processing…I did not ask that specific question but they said it would be covered under warranty. But I really don’t know how they process the order, if that makes sense. They did say that my unit (based on serial number) was included in the range of units in the campaign. (They were able to look that up from the serial number).
I’d recommend have your serial number (pic) and also a pic of you dash with number of hours on machine handy… unless the dealer you are contacting already has it (I would think they would want to verify the machine working on is yours to submit for warranty…I don’t know that but that is my guess)
They also mentioned there is some time sensitivity to the warrantee coverage which is from date of purchase (if I remember correctly). They encouraged me do so quickly since my time to purchase date is almost up.
10,191
Good day.
For TSB work, do you need to have the problem show up or is it a case of "the squeaky wheel gets the grease"?
2,587
What makes the sensor show “water in seperator” ? How does the vibration make it go off?
The brace seems to simply eliminate the vibration of the housing. I assume the braces are the least expensive option for Kubota but there are probably other methods to stabilize the housing that could be implemented by getting some metal involved to support points.
jyoutz
Jan 14, 2019
3,494
2,581
Good day.
I purchased December 1, 2021. What is your date?
GrumpyFarmer
4,646
I don’t really know how that process works. I explained what had happened/situation/symptom same as what was in my first post. They said they wanted to look up serial number and see my warranty timing and if any service campaigns for my machine.
10,191
That's another good question. Water in fuel sensors typically work by sensing a change in conductivity, so perhaps the vibration of diesel around the sensor, and the possible cavitation around the sensor, is enough to change the conductivity.
I took a photo or two of the water separator in the M6060 and it's held in place by one bolt that connects to a thick steel bracket. The TSB that @whitetiger posted only refers to MX tractors, but I would have thought that the L60 tractors with the same V2400 engine would be included.
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
In my case, it was happening intermittently. Called dealer and told them, got a new fuel bowl and sensor under warranty, installed it. Few weeks/months go by started happening again, lived with it. Then I read about this TSB, called dealer and gave them the TSB number, told him I had already replaced bowl and symptoms were still present. Made a ticket for a bracket, now we are waiting.
@jyoutz I'd go ahead and call your dealer and get a ticket started. Once that happens, it doesn't matter if you go over warranty period, as you are waiting on parts. I just got off phone with my dealer and that is what he told me, my tractor was purchased early in 2021 by the original owner. I purchased from him May '21.
10,191
It's hard to imagine that @jyoutz wouldn't be able to get the parts before December 1, 2026. 😂
GrumpyFarmer
4,646
My dealer just texted me a few moments ago and they said they have been notified the parts are back ordered. (I don’t think anyone was lying but maybe whoever/however system works at my dealer had some lag to your already in process info).
Good afternoon TEAM,
I wanted to share a quick update.
I got text from my dealer that the part has come off back order status and they hope to have shipment information soon. I’ll keep you posted in case any of you are also waiting.
Thanks.
GrumpyFarmer
4,646
UPDATE: I received text from dealer this morning that the repair parts have been received / scheduled for repair.
10,191
It'll be interesting to see the before and after photos. Did you dealer have any idea why the open station kit is listed at $800 wheres the cab kit is around $50?
GrumpyFarmer
4,646
We did not discuss price. We discussed it being covered by K. The dealer thought it’s covered by Kubota. I am not worried what that will cost back to K.
Unless I misunderstood I will only be out for travel fee for the tech to come to the machine. The dealer is about 7 miles from my machine and I’ll have to cover that the techs travel and time during travel. There is salt on road and I don’t want my machine or trailer in that mess right now…and they rather not come get it in this mess either.
I believe the dealer will bill back to Kubota…I just have to pay for tech time and travel for the back and forth.
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Just got off the phone with my dealer, UPS shows delivery tomorrow. Can’t wait to see what this $800 bracket looks like!
10,191
I'm not worried either, just interested why there's such a discrepancy between the cost of the kits.
10,191
Prepare to be underwhelmed! 😂😂😂
GrumpyFarmer
4,646
When tech is in my barn I will ask about if it (if I remember).
GrumpyFarmer
4,646
I think I am going to ask them to scrape the gold plating off and put it in a little baggie for me before they install. 😉
