Fixing hole in side of block
Status
Not open for further replies.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Got 30 gallon diesel ⛽, run tractor check for leak
went and got 30 gallon diesel, filled up diesel tank on tractor, get her running
got her started video is about 10 min after startup, clean all the oily areas with brush and solvent, hit with compress air
the level was a tiny bit below full, let her run for hours and hours, and see if it go down
tasks to do while waiting to see if it leak:
now would be perfect to paint but paint has not shipped, ordered one week ago
might nail in framing and put in metal to make more shade in shop,
also, i want to start the other d1301 engine build: i purchase ton of parts and feel bad they are not being consume,
at the minimum, entertain the idea, start to imagine it
Now I go put shade in shop, and let her idle, then decide next step
sit down next to purring diesel and narrate build for other d1301 engine:
start with front axle on block, then get the engine onto it, block under engine, build engine with access to every angle since it is not attach to tractor,
do everything, clean it perfectly, paint it once, then mate the tractor to it (like I did when fixing the rear main seal leak)
video after 1-2 hour idle: purring better, i test it out with less diesel, and she less likely to shut off than before, chooching along...
I dont see any leak underneath, but let it purr while you go build shade
another task I can do: build up that front air box/holder/battery and put good wire on good battery
been working on the shade task while she idle 4-5 hour
oil pressure not getting below 50-55 psi, leak coming out of exhaust 2, and leak near governor out of gearcase tiny
exhaust 1 and 3 bone dry, exhaust 2 pushing out some oil, what could be the cause?
@L35
yes, I see that, 1 and 3 are dry, 2 spitting out some oil
@D2Cat
only solar electricity available, not strong enough
couple time I choke her out with too little diesel, check oil level, exactly where it was when started
keep idling, keep working on the shade
L35
Jun 13, 2010
711
830
CT
Little head gasket oil leak there, Or is it coming out of #2?
7,676
Joe, I noticed you have frequent need to glue some metal body parts together! Do you have electrical supply in your work area? If so, I'd suggest you get a wire welder. Wouldn't take much and you'd have, easy, clean welds.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
396
541
SE, NM
That seems like a smooth running three banger.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Putting shade up, decide what to do
while she idle, I put 1 and maybe 2 strip of metal to make more shade
I try to show you where the oil level been sitting since she started idling, it is right below the "D"
not seeing any leak beside cylinder 2 and tiny gear case leak (jb weld did not fix it, it broke through)
It looks like paint is not showing up anytime soon and I have no funding to order another one
Now: let her idle a bit, keep putting up more shade, it is so easy to do and so glad i finally did it
but I am fixing to put the wheels on and ride around,
get the loader into the shop area, start to do the hydraulic line install
more detail plan: put on battery/air box/, install good strong battery, install good wires, rig up a switch for starter and glowplug, install front axle propeller, exhaust, front wheels, seat, steering wheel, keep making more shade, you wont regret it, then if I get to it,
go bring the loader to the work area, install the big bolt and bracket, finish up the hydraulic lines, last I remember they were almost figured out
it would have been nice to paint loader off the tractor, but we just roll with punches and be flexible
go get her started, keep making shade, and reflect on what was just said
idle for 1-2 hour, oil pressure staying 55-60 psi
yes, at around 1:50, she sink into that state of tranquility, the purring idle, that seem it is about to shut off,
but no, she stay on, purring, smoothly, then she choke out from too little diesel, but notice
that she can get lower rpm without shutting down, we are 20-25 hour idle break in time
about 75% done with the shade task, doesnt have to be perfect, get to machine assembly
that should be enough shade, got the main work area, this task been bugging me since page 1 of the thread
move all ladder, get rid of all block and anything off ground, clear area, then
rig up strong battery with switch for start and glow plug, wire the alternator, make sure it charge, be able to start and stop it reliably,
dont forget to tighten all bell housing bolt
then put front wheel on and it will be the first time machine off block in 4/5 month
then after that plan on bringing the loader, installing on tractor, figuring out hydraulic, etc
lower throttle until she choke out, check oil, oil level exactly same as before 3-4 hour idle
now that I study the picture then the video, oil level look like it drop tiny bit, keep idling it, and keep studying it
what could be the reason it is pushing out diesel or oil from cylinder 2?
@L35
valve guide seal: I think this is it, they were rubber seal that I did not change on the head
it does look like oil, diesel runs better
thank you
tighten all bell housing bolt, tighten diesel filter, study this image try to see why bracket not lining up properly
figured out bracket was upside down, diagram help
machine idle 5-6 hour today, close up of oil level, same level...
install air filter, exhaust, propeller, front axle, find strong battery, figure out alternator wiring
tighten bell housing bolt, install airbox, plumbing, hardware, install exhaust, try that battery see if she hold volt,
next: install front axle and propeller, put strong ground on battery, wire in alternator,
thought about starting wiring: put simple switch on starter solenoid, put switch on glowplug and mount them on a random bolt in good location
7,676
If you want a better filter and easier to service check out one like this. I put this on my L305.
L35
Jun 13, 2010
711
830
CT
Valve guide seals if motor oil, leaky injector if diesel.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Yes, soon once I get back to shop, enough with the idling and testing,
Get the tractor on all wheels moving around on its own
Go get the loader on it, work on the hydraulics
I've needed a loader for 2-3 year now,
This entire mission started from a need of a loader to do construction 🚧
install good battery, good ground and power wire, loader brackets and their big bolt, steering link, also went through and tighten all bolt that might be loose
now: rig up easy setup to start tractor, dont fasten down that battery until sure it can take voltage, get 2 switches and hook them up to starter/glowplug, find/rig up wiring for alternator charging, check voltage once you get it running
later: put on front wheel, go and get loader with tractor, bring to work area
install 2 switches on diesel tank, left is starter, right is glowplug
glowplug - big wire - right switch - big 12 volt solenoid next to starter
starter solenoid - left switch
these are the pathways used for this simple solution
now: wire up big wire for alternator, test out the system, make sure it charge the battery
test out glow plug switch, voltage showing at glowplug
video: test out starter switch, works
now: get it started, test voltage to see which terminal on alternator putting out voltage, run that wire to the main solenoid next to starter
used a volt meter to see which stud coming off alternator puts out the charging voltage
none of the leads, including the 3 leads inside the harness, show any voltage, except
tiny bit of voltage coming from lead I point to with flathead
could the alternator need a ground other than its frame being bolted to the engine block?
now: scratch them with wire wheel, and check voltages again
looked at diagram, does not label positive terminal
diagram off internet of how typical alternator wiring
it looks like that harness coming off alternator that go to fuse box has sense wires that need voltage
keep trying to rig up custom but if it is too complicated, maybe just re use all the factory wiring
now: experiment with putting in the harness that go into alternator and give 12 volt to those wire until she start putting out charging voltage
rigged up one wire from harness on alternator to constant 12 volt, now stud next to it putting out 17 volt, and
the stud i pointed to earlier putting out 28 volt, and if I connect those two stud, reading is 12 volt
looking at factory harness: run a wire from the stud showing 17 volt to the main terminal, and that shoud charge the system
let me know if this will work long term or there is a mistake
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Finish rigging electric, move show forward
Oil level check after 7-8 hour idle, even with the small leaks it has, level has not dropped at all, still covers the "D" completely
made a good 6 gauge copper wire to connect alternator to the main lug, tightened everything down
only concern: now that alternator signal wire always on, will that drain battery?
now I heat up glow plug and i show you cold start with the switches
confirm, charging at the battery, show 13 volt
confirm, charging at the alternator, showing 13.2 volt
cold start with new switches: glow plug for 2-3 minute, only thing i did before video: run it 30 second with no compression to prime diesel
observation: after installing air filter and exhaust, see saw completely gone, and now idle might need adjustment, meaning
the seesaw idle from earlier has something to do with no constriction on its intake and exhaust,
with intake and exhaust, it is more balance the way it was engineered
at this moment, diesel engine purring, no leak, charging battery, have start and glow plug wiring installed...
move show forward: put front wheel on, fix seat temporarily, fix steering wheel later but install it, get it moving on its own
install front axle/propeller, strap down battery,
install propeller front axle
strap down battery, battery showing 13 volt, charging
go get front wheel, install them, temporarily put on steering wheel, put couple bolt on the seat,
also paint is about a day away, its solved
for first time in 5-6 month, she is standing on her own feet, ready to move on its own
only 3 task to operate: put all lugs in rear wheel, install seat and steering wheel
woah, there she is, idling in the sun, healed from her surgery, she got there all by herself
she almost die august 23, 2023, but november 13 2024, she back to life
She had her surgery 10-12 feet away from where the engine exploded, but now she heal
dont worry, i got the first ride on it on video, take 1 hour + to upload
while video upload: clear out the work area, level the ground a bit with bx1500, take L295 that just got revived,
take it to the loader, lift loader, get L295 attach to loader with couple bolt, lift up on front of loader with bx1500 3 point hitch, hold up loader on L295 with lumber, bring entire assembly to shade
video: yes, you witness first ride since august 23, 2023
Move my home with L295 3 point hitch
3,399
Just an observation, but I get the impression recently you have been coming back and adding to your posts via the edit function, after a fair amount of time has passed.
If you have been, this is very confusing to those who have already read the posts. I always thought the edit function was something to be used to correct typos and such, but not for the purpose of making significant changes/additions later.
Of course it matters not to someone reading the thread months later.
Just a thought if this is what has been happening...
6,793
Just curious, why are the rear tires backwards?
3,118
Congratulations @joesmith123
I bet you were so worried when it didn’t move and then ecstatic when you got it rolling!
two observations though
Are your rear wheels on the wrong sides? Not that I am worried you are going to get stuck in the mud! But look at pic of tractors with similar tires, I think they will have the lugs the other way.
And what is the weird whistling noise as you walk behind the tractor? It sort of sounds like an air leak out of an air hose. Is the exhaust crushed or something? It might just be the camera microphone picking up wind noise but I only heard it both time you walked behind the tractor.
Again, congratulations on the success with the repair.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Bring loader to shade area, attach to L295DT, paint everything
clean up shop, leveling shop floor, getting ready for next step using bx1500, then
front left wheel of bx1500 grinding, with and without 4x4, it popped out of that weak structure holding the steering hydraulics
I might've run it dry and broke something inside the gear, but
it leveled it good enough and its a sign to focus on L295DT
paint showing up today probably, get ready for paint, I imagine:
take L295 to the loader, raise the loader with 3 point hitch on L95, get it on block, get it high enough over the front axle, attach some bolt of loader bracket to tractor, hold up front of loader using wood blocks
It would be easier if I had bx1500 running, and use the 3 point hitch to lift on the loader while getting it mocked onto the L295
ok glad you think that sound off, I think also that
it started that sound when intake and exhaust installed, they seem to be sufficating the engine a lot
very unlikely that muffler is clogged, and no sign of being crushed, but
I try to stick long thin metal, and scratch away at whatever is inside of it
and yes, wheels will come off today/soon for paint and will be properly install
summary;
confirm that battery charging and can start it from cold start, soon we find out,
take L295 to the loader, lift loader, get couple bolt on tractor, bring loader to shade, get the tractor off of all wheel, and get loader fully attach tractor
maybe just drag the loader with the dolley and 3 point on L295, dont install loader since it will be being painted anyway,
nature will choose the path taken
battery completely, dead jump tractor with pickup
turns out, you cannot just give power to the alternator signal, it does need to have "ignition on", meaning
it does have a draw that will kill battery when tractor off, simple solution that I will likely do:
once I put components: I might just have to intstall the factory wiring and take out all the extra junk
or
(for now) put a master switch on the battery that I can turn on/off all power to battery, then
I would always have to remember to turn it off when turning off tractor
that would be hillbilly ignition
raise one end loader with L295 3 point hitch, get your dolly underneath
lift other side of loader with 3 point hitch, connect them, drag loader to the shade
hillbilly ignition: install this on the main battery terminal, turn off when machine off, turn on when you run machine
@D2Cat
yes, dinosaur always know something, i listen about the "diode"
could it be that simple, that diode can fix the issue? How could it know when to shut off that connection?
My suspicion: it does need a separate ignition, but nature will reveal the truth, per usual
now: paint almost here, take L295 and park it away from paint area (since it is already blue) and take wheels off and put it on blocks since wheels are orange, get loader on blocks and start soaking it in diesel, hit it with wire wheels, bring pallets and bring all parts getting orange, get all parts getting painted orange clean and ready for paint, grind down that jb weld used to cover welds on the hood,
declare few other task: the seat bolts did not line up the seat loose and slanted, maybe line it up properly or put new holes in seat bracket, take off steering wheel, level out the cracks using jb weld, and it might need a top seat if I cannot find solution cheap enough to fix current seat, unscrew the idle adjustment half a turn or more
3 point hitch and dolly to move big loader to shade
lift up on each side of loader with 3 point lift, get block under
install hillbilly ignition while charge dead battery
bring pallet close to loader, bring all parts getting orange
paint show up perfect time, you imagine that it will lay perfectly and you wont make mistake and matches properly, and
that it hit dinsaur hard with nostalgia, take them back to 1982..
Status
