Pulling up young cedars.
pgmrdan
BX2380, L3902HST, Massey Harris Pony, Ford 3000, Bobcat 751 skid steer
Aug 16, 2017
201
80
How would you hook a chain or rope to the base of a very young cedar so you can pop it out of the ground with a tractor?
5,566
Wrap a chain around the trunk at ground level about three times, hook the chain to itself. Pull from drawbar.
2,811
1,528
I used a 5/16" log chain wrapped around it 2 or 3 wraps, hooked the end back on itself, hooked the other end on my loader SSQA frame or the forks, and plucked it out. Kind of taxing if you have more than a few, but it's good exercise.
Edit: Since I have more than a few, I sprung for a Landhonor tree puller. It's not the best available but, after modifying it, it'll pull little trees up to 6" or so.
Marky
L2502DT, Ford3000
Oct 24, 2024
23
50
Georgia
I use a homemade grabber. It’s much faster than wrapping and tying chain, and it pinches the tree or shrub and the pipe digs in so the chain doesn’t slip. Just use a chain with a hook and slip it thru a short pipe. Wrap it around the tree and hook to on the pipe. Then pull….
Reactions: 10 users
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
632
487
E.
a right sized chain and choker hook would be my go to
jyoutz
Jan 14, 2019
2,991
2,033
Edgewood, New Mexico
Pulling works, but so does a rotary cutter. That’s how I deal with small juniper saplings.
armylifer
Mar 26, 2013
2,051
784
Thurston County, WA
I used to use a chain wrapped around the base of the tree and hook up to the 3 point. Now I am going to use the way that @Marky showed.
pgmrdan
Aug 16, 2017
201
80
Thanks all!
I kept thinking the chain might just pull the tree over and slip off but it sounds like it will work. I've never seen a ring to slip over the chain like that before. Great idea!
3,309
If you are good with a welder something like this might work better
Marky
L2502DT, Ford3000
Oct 24, 2024
23
50
Georgia
Dang, If I was on an ATV going that fast with that cutter, I would hit a gopher hole, cutter would dig in under a big root or rock, and it would not be pretty. 😳
But I like the cutter….
5,566
Here's a simple method to get greater leverage to pull up and out of the ground. Any large round item will work fine, even a piece of firewood. You may need a longer chain.
pgmrdan
Aug 16, 2017
201
80
My 2" coupler just arrived. I'm ready!
Poohbear
Jul 6, 2018
504
157
Gilmer,Tx,United States
If you aren't in a hurry, cut the cedar about 2 ft off the ground and next year you can just push the trunk over by hand.
pgmrdan
Aug 16, 2017
201
80
Just tried the chain and pipe coupler. Brilliant!
Thanks again guys.
