Kubota L35 Problem
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Thanks for that. Doesnt sound unusual .
The engine should turn any direction. If not, that would be unusual.
If you're going to start removing bonnet and associated radiator, alternator, etc you'll have an easier time of it (more room) trying to turn the crankshaft.
Hoist the bucket and chain it up (or remove it) if you can. it helps working on engine getting the loader booms out of the way
Check front pump bearings, steering yoke bushings and steering hoses and other hard to get items to while in there. Water pump is cheap and easy to replace FYI while in there.
I hope you wont mind keeping us informed of what you find.
Ok thanks for that info I will keep those things in mind. I will update and probably ask some more questions thanks.
10,451
yea my brother in law is saying need to pull the motor and see what's going on. Any good videos or guides on pulling the motor. I guess the maintenance manual would have some info. thanks
I don't know of any videos of doing an engine removal on that model specifically.
When you get to the finer details of a tear down or rebuild I can most certainly help out.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
I’m the workshop manual it mentions disassembling the main frame. It’s referring to just the brace and loader main frame? I was looking for some YouTube videos on this procedure but couldn’t find any. Looks like a lot of work - I guess the most daunting part to me is splitting the tractor to get the motor out. Any tips or tricks if anyone has done this let me know thanks guys
3,643
2,225
I used the search string 'L35 clutch site:www.orangetractortalks.com' in Google and found several threads on this site. Whether it's clutch or engine, the tractor has to be split. You can browse other threads, but the one below probably covers it. @lugbolt participated and he can probably answer your questions. Sounds like the FOP, loader and backhoe have to come off.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
So finally got around to pulling the engine. Just looking for some direction on the next step. I was following the checking disassembling and servicing in the work shop manual. Should I continue with that. I just finished the 1-s14 page. I’ll include photos of that and the next page. Thanks
10,451
Looking good so far, keep following the manual.
I would be pulling the clutch off next.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Ok thanks. Here’s pictures let me know what you think, should I replace since I’m in here anyway if it looks ok?
Ok pulled the clutch of here’s pictures let me know what you think. I assume I should replace it since I’m I here anyway? Should I get a clutch center tool when I reinstall? Also it’s says about applying three bond 1901 is there something recommended for that? Also looks like there’s a bunch of grime around both sides where I pulled the engine off should I remove that the best I can? I’m going to continue with the dissemble let me know if I should be doing something different also if some other things should be replaced while this is apart. Thank you Wolfman and anyone else for the help.
10,451
The WSM can tell you how to determine if it needs parts changed.
But me personally if I'm in there I almost always plan for a clutch disk, pressure plate, throw-out bearing and pilot bearing/ bushing.
You could get a alinement tool, but a simple dowel will get you lined up too.
It's not hard to center the disk.
Yes clean all of that up, a little rust remover wouldn't be a bad thing, and a light coat of paint afterwards.
On reassembly you want to seal the mating surfaces of the cases with a light coat of RTV to seal moisture out of the clutch area.
L35
Jun 13, 2010
682
786
CT
See if the engines rear main seal is leaking as well, considering it’s around 25 years old if it isnt now it may be soon. I’d look into doing one of those “while your in there” kind of thing.
10,451
Look at all the dry rust in there, I don't think a drop of oil has ever seen that space. 😜
He is going to end up messing with seals and such because he has an engine issue not a trans or clutch issue. 😉
L35
Jun 13, 2010
682
786
CT
I was looking at his installed pressure plate pic, it’s got a little engine oil visible but not able to tell if it’s from the RMS or no.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
ok sounds good do you have a recommended place as to where you normally buy the parts. As should everything come from a dealer like messicks. I popped off the head cover last night and theres something broken under the rocker arm where the spring is. I’ll get pictures here soon and post.
  • Sad
Fluke216
l35 kubota
May 2, 2021
84
21
PA
is this something I should leave and not mess with? Thanks
10,451
Yes I want to see what's under the cover, it would be rather ironic if that was all of your noise.
Clutch setup for it:
Fluke216
l35 kubota
May 2, 2021
84
21
PA
It doesn’t show the L35 on that clutch kit just wanted to double check and make sure that’s the correct one. Thanks. Also is it ironic because it could have been fixed with out splitting the tractor? - genuine question as my knowledge is limited. I will post a picture when I get home. Thanks again
10,451
Yes that's the right clutch package, they just don't list the L35.
Depending on what you find, you might still need to get into the bottom end to get it fixed.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
ok thank you. Here’s some photos looks like something broke on top of an inlet valve? Also on the other end under the oil cap area looks like got real hot or something like burnt oil in that area or something you can see the spring is kinda blueish colored.
