Tractor got a little hot.so I shut it off.and now when cranking the motor drags and not crank fast enough to start.
Sounds like it got more than a "little hot"
[/Q The temperature gauge was still only notch bellow half way.i was keeping an eye on it.gauge defiantly can't be right.
Yep both is full.just rensently put on new oil in it.did you check the oil, and the anti freeze?
Was it stesming and puking coolant?Tractor got a little hot.so I shut it off.and now when cranking the motor drags and not crank fast enough to start.
Leaked a little coolant out.but still is close to radiator full mark.Was it stesming and puking coolant?
Do you have a question?
What makes you say"it got a little hot" and caused you to shut it off?Leaked a little coolant out.but still is close to radiator full mark.
I shut it off to move stuff out of the way.and you could here the water kinda bubling a little.i had my brother to pull it to my house.i tryed starting it up and started right up.shut it off and tryed it again.cranked over like suppose to.it don't make sense to me.with my luck I don't think I'm going to try playing the lottery.What makes you say"it got a little hot" and caused you to shut it off?
Check and top off the fluids, put it back to work, and keep an eye on the coolant level.I shut it off to move stuff out of the way.and you could here the water kinda bubling a little.i had my brother to pull it to my house.i tryed starting it up and started right up.shut it off and tryed it again.cranked over like suppose to.it don't make sense to me.with my luck I don't think I'm going to try playing the lottery.
Or just watch the one that comes with the tractorStop guessing and add a reliable heat gauge.
But it won’t crank fast enough to start.Check and top off the fluids, put it back to work, and keep an eye on the coolant level.
There seems to be some confusion about that.But it won’t crank fast enough to start.
I would try to spin engine by hand just to see how difficult it is to turn.
Then if that seems “normal “ (whatever normal was or is) try to jump it off or charge battery with a trickle charger and see if it spins and starts.
Good luck.
I am still doubtful it actually overheated. The bubbling noise you heard when you first turned it off is not unusual on a machine with a coolant recovery tank.It starts like it is sopose to now.and my tractor temperature gauge ain't right.onlt barely moves off cold mark.and only on the first mark when over heated.which temperature sensor works gauge.mine has two on it.one by thermostat housing.and one towards back of head.
