Tractor got hot know drags and not start?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,828
1,544
WestTn/NoMs
curious am I .
I only see one temp sender, on the head ,at the back in the online drawings.
Maybe it'd defective or the gauge. usually you remove wire from sender,ground it and meter goes 'full scale'. WSM should have 'how to test sender'...so many ohms when hot and cold.
it'd be nice to know what the other one is and for !
Until you KNOW, if you use the tractor keep a nose out for 'high heat ' smell ! Also, check fan belt tension. If it's a little 'loose',pump won't pump coolant and engine can overheat, then big $$$$$ to fix.
His second sensor may be for a glow plug timer. The L35, for example, uses coolant temperature to modulate the timer's interval.
5,248
1,924
if' it's the L2900 in your sig, the second sensor is for the glow plug system, just like the L35's. All of the old Grand L's had that system. L2900, L3300, L3600, L4200 L3010, etc
