How do I NOT Break This??
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
THAT'S the kind of thing I was looking for.. !
If we can find the best size for the Tractor Toolbox I'll know where to look for it next time. Anybody have these ? BTW do the bigger Kubotas have a larger similar fuel filter?
ToolFreaks Unite!
I used my spanner wrench (adjustable) to wrench on motorcycle shocks. It's come in handy on many applications.
Dustball
2016 B2650HSDC
Sep 15, 2023
477
340
Hudson, WI
@Dustball : I've found several wrenches like your photo, but their smallest limit is 2-3/8 inches or more. The fuel filter outer ring is about 2-1/8 . Anyone seen a different smaller size?
"without squeezing it at only two points." is the main point. Strap wrench meets that I think..
That particular one goes down to 2-1/4" which is too big.
This one goes down to 1-3/4" and may be in stock at your local Home Depot for you to physically look at before buying.
CHANNELLOCK 209
lynnmor
B2601-1
May 3, 2021
1,702
1,499
Red Lion
In posts #1 & #3 it sounds like low temperature is part of the problem, perhaps a hair dryer can safely warm it till it turns easier.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
175
183
My neighbor is an 80 year old gear head with 2 restored cars form the 50's and one hot rod from the 60s.
I was having an impossible time getting an oil filter off my motorcycle. The wrench was slipping, and the filter wasn't exposed enough to get plyers on it. I asked his opinion on how to remove it.
He suggested taking a screw type hose clamp, tightening it up around the filter so it wouldn't slip then gently tapping the adjustment screw with something to force the filter to turn.
Worked like a charm.
5,185
"plyers",...... rhymes with flyers?.........only in Texas? :D
John D 2
Jun 6, 2023
175
183
Thats what happens when you type 1st thing in the morning before coffee. :ROFLMAO::ROFLMAO:
How about pliers.
William1
BX25D
Jul 28, 2015
1,320
509
Richmond, Virginia
Heloise hint. Since an oring seals it, there is no need to make it tight, just snug. Screw on until resistance is felt and about 1/4 more turn is all it needs. You don't want to crush the oring. Being rubber, it will not vibrate loose. Over tightened, not only makes it very hard to remove but may necessitate replacement of the oring if deformed.
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
184
185
Demotte, IN
Next time you go by a Kubota dealer, stop in and see if they have a special tool. When I use a channel lock on items like that I’ll put a rag or old strap, etc, between the pliers and part to reduce/eliminate putting plier marks on the part.
