Backhoe Swing Lock Pin
3,672
well, I was replying to the comment/question from yesterday, Not the OP's question from 2016.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,185
877
PNW-WA
No matter when the topic was started, it's all relevant...minus the dated remarks
2,965
I suppose so...but maybe not exactly?
Probably better to start a new thread if you have a question, and if you have a reply to an almost ten year old thread, may be best to hold you tongue, as it is likely irrelevant to the OP?
5,066
History is always good.
These machines do not change dramatically over time.
We do not need to care if the OP receives a benefit, just as long as someone might!
5,541
Ditch Witch came up with a simple solution to locking the bucket from swinging when not in use. They have a chain hook welded to each side of the boom. On each outrigger a chain is welded about 1/3rd the distance up from the foot. When the outrigger is up put the chain in the hook. Every thing stays in place and no chance of any damage by accident. Both chains easily reached from the seat on the hoe when done.
Trimley
Jul 25, 2023
1,185
877
PNW-WA
I tend to agree. Then again, I've noticed that seems to be the norm from most.
I've often replied, then deleted my response afterwards.
Smokeydog
Jun 2, 2020
668
620
knoxville, Tennessee
Bought the M59 backhoe separately, used, missing swing lock pin. Made one from scrap pile parts. Handle length sufficiently long enough to easily reach from operator station.
Handy when tapping the mounting pins in or out.
5,066
Bought the M59 backhoe separately, used, missing swing lock pin. Made one from scrap pile parts. Handle length sufficiently long enough to easily reach from operator station. View attachment 139594
Great idea !
A hammer is always useful!
6,338
Come on man, a claw hammer, the least you could have done was a Mini Sledge or a Ball Pein hammer head.
HAHAHA, Excellent Idea!
Smokeydog
Jun 2, 2020
668
620
Don’t use the swing lock pin much except for road transport or trailering. Hillside farm always swinging to the up hill side for balance.
Use the boom lock often. Have to lower the boom to get through the tractor shed doors with M59. Then raise then lock once inside so if the boom drops doesn’t hit the closed door. Again when moving out of the tractor shed. Hopefully memory keeps me out of trouble.
4,814
Put a note on the steering wheel "Remove Pin Before Moving Tractor". Keep the note on the inside of the garage door so you see it before leaving the garage and remember to put it back on the steering wheel when the tractor returns to the garage.
I habitually put my car key in my jacket pocket so I wouldn't forget my jacket when going to dinner. That worked well until one day someone took my jacket either by mistake or deliberately. Good thing that I had a spare under the seat and the keyless entry gave me entrance to the car.
5,066
Save the grief!
You NEED a taller/bigger building!
