Fixing hole in side of block
Status
Not open for further replies.
7,734
If I remember correctly there are two threaded holes in the hub of the steering wheel that can be used with a puller to draw up the steering wheel.
5,164
Not all steering wheels have these drilled and tapped holes.
TerryKing
B7100HST-D
Aug 18, 2024
180
122
Topsham, Vermont USA
arduinoinfo.mywikis.net
Depending on your location you may be able to use all the parts you need and sell the remains of what you don't want to inventory. Post on the internet the items you want to sell, someone is looking for them!
Joe, what is your location ? (Approx. no need to attract scavengers or vultures.) Although you could probably sell tickets. :)
Anyone, what would be the best places online to sell or find used / aftermarket Kubota parts??
TerryKing
B7100HST-D
Aug 18, 2024
180
122
Just type in something like "auto paint hardener".
LIKETHIS
Thanks, Guys!
Been a few (50+) years since "The Days Of Beer And Lacquer". Enamel was a Swear Word. But I can learn.
Also seems like the "8 coats with wet sandpaper in between" don't need to happen anymore..
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
I took an adult ed night course in body and paint work back in '76 just for fun and our instructor had us do lacquer and enamel, along with both polyester and lead body repairs. That was my introduction to hardener. Also the first place I heard about Imron.
3,411
Wow! Guess I lead a sheltered life!
A adult course in body painting! I can only imagine that the models that you painted were quite attractive, since it was your introduction to hardener!
I’m impressed and now realize I could’ve done more when younger!
Reactions: 10 users
jaxs
B1750HST
Jun 22, 2023
1,113
836
Why would you want to go anywhere to buy/sale/trade other than right here on OTT ? :unsure:
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Adjusting idle, still need to fix leaks
Video before adjusting bolt: notice the see saw, I try show you leaks, I show high oil pressure
I am adjusting this until seesaw gone
Here's where i got it after one adjustment, screw it in more and see how she idle
I do not think it is governor springs
Also: jb weld to fix exhaust leak did not work
need a comprehensive plan to fix leaks: take off head, perfectly bind the head to the flange, put in gasket on governor lid, and maybe injection pump leaking
Now: keep adjusting idle until stable
Rotated adjustment clockwise until tractor would no longer turn on, then backed it off a half spin
It is the smoothest I can get it, the seesaw has to be the springs
Springs will be here in couple days, when springs show up, that's when I get in there and fix all leaks with intent
I tell you what it need: take it all apart, clean everything, professionally and comprehensively reassemble perfectly
I point to a crack in the water flange, not related to my reassembly
Study entire area, find every leak, then take it apart, don't take it apart yet
In Utopia
L175 FEL
Apr 21, 2013
672
203
Utopia,Tx/Pasadena,TX
You can stop the exhaust leak by putting a small amount of red RTV on both sides of the gasket. That's what I did years ago and still no leaks.
Also I might be wrong, but I think the nut you took off is where you adjust the "slop" in the steering box.
7,734
That hose looks like it's got s soft spot by the clamp. If so, just as well replace it now!!!!
5,188
His location is "earth".......
Should be LOTS of folks needing parts.
It is a vast user area!:)
7,734
A few folks make comments on the "less then positive" side about Joe's operation and process. According to most it's unorthodox, but I think I would get along with Joe just fine if he was nearby. I appreciate his willingness to solve problem and document it for all to see. He makes something out of nothing. He uses what he has to get the job done. He's concerned about cost. He's not inhibited by opinions.
He reminds me of someone who is in the Navy, Coast Guard, or other service.... they learn to do with what they have to solve any problem. We need more of that in America!
Reactions: 9 users
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
In depth plan on fixing all leak
The water leak coming from gasket is not as bad as the water leak in the cracked flange that attaches to head
Previous post I show picture pointing to water leak
List of all leak: governor cubby holes I did not put gasket yet until I put new springs, should be here Friday
Jb weld on exhaust leak: no joke, it is holding better than anticipated, only tiny bit of leak on bottom of exhaust connection where i did not put enough jb weld, unbelievable
Water leaks: head connecting to flange, underneath water pump, and the crack in the housing itself that connects to the head
Also, there could be leaks in the gearcase, can someone recommend a torque for those bolts?
I will comprehensively go and torque all bolts during this rebuild
@D2Cat
I assure you this is what America was all about and tons of people use this method to solve problem and make profit
Big liar is so powerful he got us thinking we need fancy tool to fix or paint anything
These machine are made to be fixed and the old Japanese man that design these machine is on OUR team of making the machine run forever
Soon: make bubble spray, start engine, document all leak, do not take anything apart until you know exactly where the leaks are
Maybe someone has good idea: I want to pressurize cooling system to check for leak BEFORE putting on radiator,
How can I finangle pressurizing the cooling system to check for leak before putting it back together so many times?
Anyone can put together an engine, but not everyone can put together engine and not have leak
Yes, in this comprehensive operation to stop all the leaks, I do have some red gasket maker and will be implemented into the operation
First thing I need to do: I need to put framing along that part of shop ceiling allowing in sun, and nail that scrap metal laying around
What's happening: too much sun hitting shop around 3-630 pm, making it less pleasant, it is annoying me
Yes, I come up with expermental plan to fix all leak, and NOT take head off, I narrate:
Take radiator off, now you are facing gear case and can access all leaks
The oil leaks: they will be gone since I have not yet put in the gasket and fastened bolts
Water leaks: Plug the bottom port going to radiator, then fill up engine with some water and it cannot escape since port is facing up
When engine get up to temp, you can see the leaks clearly now
Experiment: Can jb weld fix leak if applied generously?
big water leak is not in the gaskets that I installed, those are tiny, the big water leak is in the cracked flange from the head going to radiator
Summary: take off radiator, plug bottom water port, pour water into engine, get it up to temp, mark all leak, then use jb weld on brush and put aggressively over the leaks
fix that messed up paint job, Hit entire area with wire wheel, give it one thin coat that you let cure properly
apply jb weld on bottom of exhaust port that has small leak
Goal: keep expermenting until you have all leak solved, do not move forward until all leak is solved,
for the forum and myself to get to bottom of narrative of fixing leak
@Henro
paint narrative: I did not care about paint, but it come from trying to hit the dinosaur hard with nostalgia
Goal: make machine look so new, that dinosaur start to have memory from the 80s,
I want dinosaur to say: "Woah, I remember seeing that machine on hwy whatever in 1983, one just like that. It remind me of so and so"
Also, notice how right when the paint dried on that first chassis, the entire mood changed, with more positive statments
Remove radiator, cannot get belt off, bring brush and apply some diesel, hit belt lightly with torch
basic tool required, notice the gasket maker, experiment with that
took off belt, clean with part cleaner, hit with compressed air
now: fill with water, get engine running, look for all leak
Governor leak, water leak not showing, system need to be pressurized
Plan: fix all leak visible, then figure out cap to seal water in engine and see if it leaks
Now: clean areas, prepare jb weld with clean brush, apply to areas, might sacrifice governor gasket for purpose of eliminating all leak
This is the leak I think causing the big mess, a crack in flange
Exhaust leak underside of manifold
Put big glob jb weld on both, sacrifice 2 gaskets on governor and cubby hole for purpose of seeing if injection pump is leaking
File areas getting jb weld, clean them, glob on using small brush
Globbed on jb weld on two leaks, now: take out cubby hole then governor spring, sacrifice two gasket
File coupling areas, hit with air, then wipe with solvent, get new gasket
Also i experiment with bending governor spring
Heehaw
MX5400hst Kubota Z726X
Oct 4, 2022
108
117
Well said.
Kudos to the folks that give constructive criticism with the intent to let Joe know that what he’s doing may not work out or there may be something he is missing.
However I just shake my head when I read posts from folks that are basically just cutting Joe down without giving any real input. I guess they just have too much time on their hands or just like to put others down.
This has been one of the most interesting threads I have read on OTT.
Good job trying to figure things out Joe!
Sidekick
Jul 29, 2023
1,295
1,893
N.Y,
I'm old school and say do it right the first time or don't waste your time. That means inspect and verify everything is within tolerance before assembly. Paint to seal leaks, disassembly 3 times, lack of cleanliness, guessing at torque, hand sanding bearing journals and many more are not good alternatives for taking the time up front to ensure your not wasting time and money. I guess Joe has lots of time on his hands for short term fixes but that's not what we should be cheering on. Joe needs a mentor.
5,188
Possibly Joe developed his engine rebuilding techniques in a rural North Vietnam sand pit.
That IS part of our "earth".
3,411
Maybe not OLD SCHOOL, unless you attended a different school than I did... :ROFLMAO:
More like Perfect School, and nothing wrong with that....
Joe's approach exemplifies the other side of the coin. Hard for some to see both sides. Fact of life.
Lot's of people in lots of countries in the world today keep things running in conditions that are not imaginable by people in this country.
Maybe Joe is in one of them, or maybe he is here. He admits he resides on earth, so we know that much...LOL...good for him...
5,188
I have little doubt that Joe is doing this repair/engine rebuild/repaint, for the sole purpose of flipping the little Kubota.
Most of us would do this work (for ourselves) in the very best way possible.
Joe, apparently has a different mindset/goal.
7,375
@D2Cat - - Very well said.
I came from a place where you made do. 40+ years ago my grandfather rebuilt the engine on (now) my Minneapolis Moline on the barn floor. The cows were gone then, but it's what we had.
Gutters on both sides. Needed a trouble light to see/do anything, even in the middle of the day.
He did it on the cheap because there was no other option. I was in school and working a lot, so I wasn't as involved in the project as I now wish I could have been.
I certainly understand the position of many that it's "not the way I would do that."
I'm now in a position where I could be more exacting in my work. Often that entails $$$.
I haven't been a part of this thread beyond a few words of praise and encouragement.
Not saying I would take on Joe’s project in similar fashion today, but think I understand some of the aspects/demands of it.
Hope it all works out well.
Status
