L 4310 Crack in Frame
6,345
Yeppers, that is a crack.
2,775
I concur....it's a crack.
4,897
curious, why the hole ? Why the welded bar ?
if all original, I understand why it'd break there. Really, really BAD engineering.
Yooper
3901 LA525
May 31, 2015
1,527
529
NE Wisconsin
Looks like a stress riser from the weld. Possibly cracked and welded and then cracked again?
N3BP
Sep 20, 2016
468
195
Lebanon, PA
Question, how can you tell it's a crack vs weld separation by looking at that pic? To me it looks like the latter, and have experienced that on my drawbar receiver.
6,345
It's not a weld line that is a solid plate with reinforcements added.
The notch with the bar above is for axle clearance.
Back side view of cracked area.
4,897
Curious...Is there some GOOD reason that welded bar didn't extend PAST the big friggin hole ???
StephenR
32
Kentucky
It could easily be fixed by a good fabricator.
Grind part of the existing doubler plate off, grind a V in the crack on both sides, weld the crack up, extend the doubler plate past the hole to add strength to the frame. Add doubler plate to the other side. Simple fix!!!
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
181
220
CT
Pretty simple fix for a good gab guy. Probably takes longer to clean it up than the actual welding.
I would go a bit further and plate it like we do with tractor trailer cut offs
Beaux
Kubota 4310
Dec 11, 2019
38
Pine Grove, Louisiana
Right On North Idaho Wolfman, it is just above weld, cracked thu both sides. I’m thinking 7018 up hill, but have a welder coming that’s been around from underwater welding in navy to now pipeline welding.
Was having Steering Cylinder rebuilt, by Kubota shop Mechanic when he spotted break in frame. It took him 6 hours to remove, rebuild, reinstall and refill hydraulic oil and work air off system.
He furnished all tools except 3, I had aluminum 1” punch, 2 small steel punches.
All for $300 + 2 Dr. Peppers
I have him coming back to repair MF 135 hydraulics.
Beaux
Kubota 4310
Dec 11, 2019
38
Thinking along same lines, have material, welding machine, torch, grinder, metal chop saw, rods, I’m just lacking experience I have not welded in 3 years, actually getting 1st cousin to repair, he’s coming in off pipeline welding.
