Fixing hole in side of block
Status
Not open for further replies.
jaxs
B1750HST
Jun 22, 2023
1,026
790
Guessing here. It looks like Joe is not using a punch that fits the ID of the bearing and the grease is squishing out around the punch. OR, the punch has a diameter that reduces before it reaches "home" going through the bearing.
Just for giggles, it wouldn't take a lot of time to cobble up something like this to try. Find a bolt that has a head, that when rounded, fits through the ID of the bearing. Grind the points off. Make a saw kerf from the head end into the shank of the bolt. Insert the head end into the bearing so the head is on the back side. Drive a small wedge into the kerf to spread the head so it grabs the back side of the bearing . Take a short piece of pipe, or a couple pieces of steel that will sit outboard of the bearing's OD. Bridge the pipe/steel with another sturdy piece of steel with a hole for the threaded end of the bolt to protrude through. Put a greased-up washer and bolt on it and tighten.
EDIT: Pardon the crude image.
I like this idea. (y)
5,188
I thought you said you were coming back after Christmas.
Did Chris come early in Maine this year? :)
My curiosity got the better of me.
It is political season,.......lying is in vogue! 😭
PaulL
B2601, MX5200.
Jul 17, 2017
2,758
1,763
NZ
I wasn't aware anyone was lying, I thought it was a bunch of bovine defecating.
This is a high quality forum. I fully expect it was equine.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
I am at harbor freight, closest thing I can find is the tool I show you in video
Do yall think it will work?
Or pay $15 more, and get this whole kit?
Only problem with this: I don't see how I can get teeth behind the bearing and grip it enough to pull it
Here is one for 30, someone did say slide hammer would work
Opened the slide hammer, I prefer the one I showed in the video
This one is exactly like the one that chim drew out for us, and it has that bridge to push onto the crankshaft
We give this one a shot
It says, "pulls pilot bearing from end of crankshaft"
Got the 2nd pilot bearing removed
Pilot bearing on crankshaft with 500 hours was much harder to remove
Found the grinding noise when turning crankshaft with 2500 hours
See how bearing is bulged? Damaged, seized bearing
Bearing from engine with hole in it
Spins a bit rough
I point: back of bearing seized to crankshaft, I hit with torch and try to chisel it out
5,165
That is like what I had shown you that I used. As long as the ends grip the backside of the bearing it should do the job. Take a video of you setting it up and pulling the bearing out.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Chiseling at seized back of bearing onto crankshaft
Sharpened chisel with grinder
Trying to uplift it from crankshaft, can't, fully seized
Now: hit it with torch, fill it with diesel, let it set in, give another shot with sharp chisel and sledgehammer
Mistake: chiseled into it for no reason, that was the whole bearing without the back cover
Picture of both bearings: same size, meaning nothing is stuck inside crankshaft
That bearing just didn't come with a rear cover
Crankshaft with less hours ready for bearing
Crankshaft with higher hours
Hit both areas with wire wheel in both directions, dip in diesel, hit with compressed air
jaxs
B1750HST
Jun 22, 2023
1,026
790
Before putting it away, you might want to consider hitting crank journals with that sharp chisel used to hit bearing recess in crank.
Joe's escapade just might cause folks to replace the moniker "school of hard knocks" with "school of hard hits".
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Gave block one last cleaning, painted opposite side of patch
20240903_162712.jpg 20240903_170820.jpg 20240903_172014.jpg 20240903_173526.jpg 20240903_174406.jpg 20240903_174415.jpg 20240903_174429.jpg 20240903_174442.jpg 20240903_174459.jpg 20240903_174509.jpg
Plained all flat surfaces with 80 grit flap, then 2800 rpm wire wheel
Removed all gasket material
Used files to get hard to reach areas
Hit cylinders with t shaped wire wheel on drill, spin both direction
Hit with compressed air then part cleaner
Propped up opposite side of block to paint, hit with compressed air then alcohol
Spray matching paint
Since there is nothing left to do on block with hole in it, shift focus back on other block that need milling job
Plan: take to machine shop in person, offer to pay the shop rate plus $150 tip if they can get it done within a month
It would be nice to put them back together at the same time, using the same tools, same diagrams, same hardware
The engine is worthless disassembled, but worth big cash on the machine running
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
You put wire wheel inside the cylinders????🫨
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,141
1,712
Pittsburgh
I think I'd like to see a straight edge posed in various locations across the deck.
jaxs
B1750HST
Jun 22, 2023
1,026
790
Shouldn't deck be square and plumb since he "Plained all flat surfaces with 80 grit flap then 2800 rpm wire wheel"? 🤭
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
That block had such little wear, i cant find anywhere on it to clean.
It only had 600 hours, thats only 6 oil changes
The reason why it popped a hole in the block: it must've sat for a decade or 2 without starting once
Then once it was started again, parts were seized and damage occurred
Not only are you seeing the pictures, but you are reading my narration, I am honored
problem is finding a machine shop that CAN do it right.
There are very capable machine shops that can mill the liners, its just that I am a nobody and cannot get their attention
Now, economy slowing down, people are more available, I can see it working out where:
If I offer the extra $150 tip, some guy might stay late and mill the liners faster
Also, that last machine shop had a hundred engine blocks all over the ground, and one guy working 15 hours a week trying to keep up, zero chance he was going to get to it
I will only leave the block there if I see evidence of motion and more people working
Soon: I load block that needs milling, I go show up in person, there are 3 machine shops I will give a try
That extra cash tip is the answer
My offer: pay the shop rate, and offer the cash tip to the exact person that does it
Also I notice with these kinds of places, you can't really call them, it's better just to show up in person
I keep having to find this, give this to machinist when giving block
3 things to give machinist: block, piston, and that sheet
Dirty block been sitting out getting wet
Washed block with free rain water
Now: go to machine shop and stick to narrated plan
Yes I wait now for library to open, print out 10 of those sheets
That way, I hand the machinist everything in one shot, no need for him to look up specs, he'll have: clean block, spec sheet, and a broken piston as reference AND the $150 cash tip if completed within a month
Showing you up close the milling required on two cylinders
5,188
View attachment 136699 View attachment 136700 View attachment 136701 View attachment 136702 View attachment 136703 View attachment 136704 View attachment 136705 View attachment 136706 View attachment 136707 View attachment 136708
'Of course it should be/will be!;)
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,141
1,712
Pittsburgh
15 hours a week?! I want that job!!
Address, plz.
5,188
ANY guv job would qualify........;)
Or Ontario Hydro !!
Yeah,......15 hours per week, and at least 15 paid holidays per year.......
Sounds normal for Canada to me.
Canada had a national holiday in every month except February, and decided that they just had to have one more!
Created it. out of the blue, for February, and.....
Called it: "Family Day"
  • Dislike
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Status
