I'll call around some more, milling co only sales 18W loads in bulk, textured/milled feed. Otherwise it's $17.55 per 75lb bag, cows on pasture/hay would need 4lbs per day, not too cheap.
I can have the feed store size the bags so at least my tractor can safely unload them. I usually try to get 1400-1500 # bags. They can go up to 1800#. The feed store off loads the pellets into the bags from a semi which comes weekly. Takes 1500# x .16 ( for 14% pellets) = $240. The 16% would be times .18 per/lb.I think so, I'll call the milling co. What are those bulk bags running ya?
Appreciate all the info, Victoria, Tx is an hour & 10min drive and we visit there about 3 weeks or so. I will get some prices from them tomorrow. But, honestly after 3 to 4 years and burned up with consistent droughts continued losses, I'm about to give up next Spring.... Definitely not taking on any more head of cattle or land leases, the 1st year was great and has since spiraled down since. I don’t accept failure, I learn, adjust and adapt and move on to plan b, d, etc. It's all up in air at this point. I could be fishing more on the coast than worry about the homestead.Maybe you can set up a bulk delivery, even if you need to get some neighbors to participate using them. I used your zip code of 78102 and they show something in Victoria.
Find a Dealer
Find a West Feeds dealer near you! Use our interactive dealer network map to find the closest feed dealer in your area.westfeeds.com
I hope you get plenty but not enough to be flooded out.Potential total rain fall.
Including fraud charges?Went it comes to fencing here's a simple reminder: If it ain't tight it ain't right!
PoTreeBoy, you said, "Fences are to animals as locks are to people - they keep the honest ones in/out."
Most farmers will put up with a lot of things but not an animal that keeps challenging fences. They quickly get a ride to the sale barn!! Now if we had a similar process for humans the violated rules we'd have less broken rules!![]()
New updates show the entire county supposed to get a minimum of 4in.I hope you get plenty but not enough to be flooded out.
Thanks!@Siesta Sundance - wishing you get your much needed rain.
Also hoping that you don’t get too much……
I’ve gotten so I can generally identify your locale on the Weather Channel maps….
Best wishes to you and yours.
Wash a car or paint something outside. If you have the same luck I have, it will rain shortly afterwards!Thanks!
It's crazy, we hadn't had a drop all day, I have feeling it's just gonna dump on us when the rain bands do arrive. We need the rain bad.
I see some cells off in the distance, so that's a good sign.Wash a car or paint something outside. If you have the same luck I have, it will rain shortly afterwards!
Hope you get some moisture soon.
