BX25D. Mod #1 and continued.
Wildfire
After all of this modifications, do really want to take it in the woods and get damaged? You know, it not pushing snow around, the job in the wood will be different. I hope your little friend stay alive and shiny nice. ;)
Have fun!
carl
Don't worry carl. I've worked in the woods before and IF I damage it, I'll repair it ;)
Wildfire
OK. I'm happy to report that I've completed all the wiring on the BX25D.
Yep. It took all day and most of this evening but it's done. I snapped some photo's for you all to look at. As you'll see I installed an auxiliary 6 cavity fuse panel. It's relayed so that power will only be on the fuses when the key is on.
I also snapped a few photo's of some GM weather pack solder-less terminals that I used. Some might not have see these used before so I wanted to include them in the photo's. You'll notice there's a special crimping tool that's need to crimp the little pins but I like these and use them a good bit. 95% of all the wiring was soldered and heat shrinked. I am not a fan of stab loc connectors but I do use butt connectors where it's dry and away from water.
I used waterproof switches for everything. I also installed a horn, reverse alarm with a by-pass switch so it could be deactivated when ever I didn't want it on. I installed the horn switch towards the said of the instrument panel due to lake of space but it's easy to reach there so I'm OK with it. I put in an extra accessory outlet and the tactical light on the ROPS is working now as is the 20" LED light bar. The ditch lights are absolutely awesome now that they are working. I also got the back hoe lights wired in and they are very nice as well. The 6 cavity fuse panel was just enough to get it done. I put a disconnect on the back hoe with harness because when I go to let the hoe go from the back of the tractor I'd need to be able to split the wiring.
Anyway I hope you enjoy the photos. I'm using a new camera and it's taking some getting used to so bare with me. :eek:
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
@ wildfire: On the last picture I see, you use some self sticking mounts for tie-raps. We use them also, but even in a room with aircon they do not really last long. Maybe they need some special glue...
carl
Wildfire
carl
Carl I used to have the same problem with them as well but I found a supplier that sells them with 3-M two way tape on them and I haven't had a problem since. They cost three time the price but good quality. I would have liked to put the wiring inside the ROPS but we all know we shouldn't drill though the ROPS :(
I hope the pictures are right side up now.
Wildfire
You think you're funny doncha? Toying us hapless orange souls?
It's a new tractor. I didn't lie about that. Well its new to me! I collect and restore pedal cars, tractors, planes and boats. Never had a Kubota pedal tractor :D
For anyone that's interested. My next mod may be posted tomorrow. It's coool :cool:
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
AH! I thought the bosslady decided the BX25 was to small and wanted to go bigger because she didn't like using it herself...
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
The paint doesn't quite match on the new tractor so I'm guessing either a paint job or going to use the new one for a pattern and build his own from scratch.
Tractor teased us today, mod tease tonight. Wildfire, what's the world coming to? :eek: :D
cabu
May 24, 2009
736
Germany, Oyten
I like it.
I bought a toy tractor for my 3-year old daughter and she likes to cruise around in the backyard. It is a cheap china toy, but still working.
@wildfire: If you fill up your museum with this things, don't you think, you need more space for more stuff. Maybe that's the reason for the BX25. Need to clear the backyard for bigger museum... :rolleyes:
Have fun
carl
Wildfire
I've had her trying the new BX and she seems to like it so I'm sure she will get to use it more and more.
Hum. Some good points and observations. :D Actually this tractor was won by its owner. Up here they go for $200. Plus but I got this one for $30. So I'm hoping to have a grandchild some day and he or she will have a Kubota as well :)
I like it.
Have fun
carl
Cool. This tractor is made in Germany. I figured it was you that built it :cool:
Today I'll post the latest mod. Its different but everyone around here likes it.
3,494
Wildfire- One of your earlier posts shows a fuse block that appears to be the same one I have used on several projects:
Here's some pics of a cover I made for mine- not completely waterproof, but it keeps the dirt, mud, and the occasional possum out.
Wildfire
More pics:
Nice work and a great idea. Thanks for posting it. ;)
OK here's the latest mod. I didn't see much interest in the shots I posted on the first part of building this latest mod so I'll just cut to the chase and post the finished product.
I'm calling this mod "Stihl Here".
Yes I blocked one way to exit the machine BUT I've never got out on the right side of a machine even when I operated BIG heavy equipment. To many obstacles in the way. Yes some might ask what IF you have to jump clear of the machine? Well as an operator we were always told the safest place for you to be in the case of a roll over is on the machine. You go to jump clear you get run over with the machine.
Now that we got that out of the way here's my solution to storing my chainsaw on the tractor. I have all the leg room I need, It's in easy reach in a convenient location. It's strong and I'm happy with it. It took a bit of milling, drilling, countersinking and welding but it was a nice little project. I also included a storage area for an axe.
Here's how it looks :)
Burtonbr
2012 B2620, LA364 FEL,rear remotes,grapple pallet forks, many other toys.
Nov 11, 2012
179
NC
Very excellent !!! I love the saw and axe holder. If they were for sale I'd order it right now. Your projects are inspiring .
Thanks for sharing
