What is this power take off up near the front axle for?
PHPaul
Apr 2, 2015
1,184
1,355
Downeast Maine
www.eastovershoe.com
A bit more detail would help. Assuming the tractor is the L4400 listed under your avatar? Exact location of shaft? Does your PTO selector have Rear/Front/Both positions?
Two major possibilities:
1. Mid-PTO for mid-mount mowers
2. Accessory PTO for front mount snow blower or power broom.
2,864
I have noticed a PTO shaft near the front axle. Can't find any information about it. Could it be used for turning a hydraulic pump?
Ron - picture is WORTH a thousand words, and would really help!
9,186
I'll bet your talking about the crank splines, yes they can be used to drive a hydraulic pump, many have over the years.
The real issue is parts availability for it are very very hard to find.
But why do you need to?
If you do have an L4400, the onboard pump is up to most tasks.
Ron Pridell
2004 L4400
May 19, 2024
Northern New York
I'll get some pics of it as soon as I can. It looks like it just runs off of the engine without a clutch but I"m not 100% sure. My son in law has the tractor now so as soon as possible I'll get the pics. posted.
Ron Pridell
2004 L4400
May 19, 2024
Northern New York
Just wondering what it is and what I might be able to do with it if anything.
Ron Pridell
2004 L4400
May 19, 2024
Northern New York
Ron Pridell
2004 L4400
May 19, 2024
Northern New York
2,327
on my older L185 (and many others in the same era) the engine crankshaft was extended out the front of the engine and used for hydraulic pumps, electric PTO to drive implements.
9,186
Yes that's the front of the crank. ;)
Ron Pridell
2004 L4400
May 19, 2024
Northern New York
I'm guessing that I would have to buy a gearbox of some sort to use it?
