L3302 what size box blade and rotary cutter?
Tonka
32
9
usa
Dealer said the L3302 can handle a 6' box blade. Sound right? Also, what size rotary cutter ( brush hog) ?
2,583
I would agree with both, BUT much more important - IF you grab too much anything with the box blade, it will lose traction - so smaller bites depending on material.
Same is true with rotary cutter - what speed will you operate in? L - M - H? how tall is the grass? What RPM you plan on cutting in?
StephenR
39
20
Kentucky
I've read that bush hog size was 1 foot per 5 HP. A five-footer would probably be OK as long as you didn't try to do some serious land clearing.
Steve.
jyoutz
Jan 14, 2019
3,057
2,100
Edgewood, New Mexico
Steve.
I agree and would recommend 5’ both for the blade and cutter.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,390
1,814
Western MT
My dealer recommended a 6 ft rotary cutter for my L2501, but we don't have thick material to cut. I have a 6 ft Grader/Scraper that they recommended as well.
Depending on what you plan to do, you might be better off with the Grader/Scraper. For driveway maintenance, the grader/scraper is much easier to use.
Also, depending on how you want to mow, you might also consider a flail mower.
Tonka
32
9
usa
I had New Holland TC24, TC33 and have an LX2610 - I've always only cut in Low because if I've always only used a cutter for clearing wild overgrown land. And much of the time I'm backing up to scrub brush and lowering the cutter down onto the scrub grinding it down.
Tonka
32
9
usa
Steve.
My LX2610 handles a 5 footer with ease - grinding the scrub brush down. Occasionally when I get into 2 to 3 inch stuff it will slow down some so I just slow the rate of descent on the cutter and give it more time to grind its way down.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
659
536
E.
check out about page 30 of your operators manual.
of course much comes into play like commercial/homeowners use, type of soil, type of brush, etc..... but the Kubota Op. Manual will likely have you conclude these sizes are to large.
Tonka
32
9
usa
Don't own one. Thinking about one.
MapleLeafFarmer
Dec 2, 2019
659
536
E.
DDCD
1964 MF135, L2501
May 8, 2021
160
179
Oklahoma
You need a 66" to cover your tire tracks on the standard L series.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,155
1,267
Near Lancaster, PA, USA
A little late, but I used a 5' box blade with the L3200 we had. It was easily too much sometimes depending upon how much I tried to do with it. It was frequently a good anchor when trying to be more aggressive than I should have.
The B7500 was a tad undersized for the 5' rotary mower we had. Again, with some patience and the FEL for a counterballast it was workable. I'd guess the L32/33 size it would be fine.
