Bearcatrp
Mar 28, 2023
1,092
724
Minnesota
Got it stuck for the first time!
I got a little too ambitious on a slope. I even thought "quit while you're ahead and wait for the ground to firm up and dry out before continuing with this". Too bad I didn't listen to myself. Not enough traction to go back up the hill because the ground is too slimy. Trying to back further down is a little precarious and would probably just make matters worse. Decided to use the phone a friend option and he'll swing by with one of his toys with a winch to help it along. I don't think it'll take much coaxing to get to where I have traction again, fortunately - I went just a little too far with it. In the meantime, it's stable and isn't going anywhere.
You wont find its limitations unless you push it a little. Your safe is the most important.
Toyman
B7100HST, 1630, 4' Tiller, 4' Brush Hog; Mahindra 5005/Loader, Woods Cadet 84,
Apr 15, 2019
120
104
Pittsburgh
I have had the 40v Greenworks pole saw for about 5 years and it's been great. Powerful and if you keep the chain sharp, it gnaws through about anything. I also have the blower and vac. Got the vac to clean out my planter and the blower to clean off my brush hog. Thumbs up on the vac, the blower is a little under powered.
In Utopia
L175 FEL
Apr 21, 2013
648
173
Utopia,Tx/Pasadena,TX
My L48 TLB lived the 1st 13 years of it's life outside.
It lives inside now, and I don't plan new hoses, until the first one goes.
Some slight cracking, but they all do still appear to be quite serviceable.
Replacing your BH hoses must have been quite difficult/frustrating.
Might want to rethink your game plan. My little L175 spent most of its life outside before I bought it about 10 years ago. It then got to spend its time under a carport.
About 2 years ago went to fire it up and bam. Fluid shot up from a hose at the fel control valve, hit the ceiling and promptly came raining down on me and the tractor.
Needless to say that prompted a hose replacement program.
5,185
While my hydraulic hoses are relatively old, I do think there is a very outdoor different history.
Your tractor apparently spent it's life in the hot dry Texas sun.
Mine apparently spent it's years before me, under a large spruce tree in Northern Maine.
Lots of cold cloudy days in Maine.
Sun rots rubber.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
I got most of the wildlife waters filled up yesterday. Last few rain events have been missing us again.
Reactions: 12 users
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
I also have the weedwhacker for the 80 volt Greenworks battery, and before I ran over my chainsaw (and futher solidifying my brand preference to them) I had also bought a hedge trimmer to assist in keeping my bike trail open. Got a 60 volt lawn mower also. TW: their 80 volt battery charger is done right, has a fan to keep things cool, first class all the way.
4,576
I gota take the wheel weight off the BX and pump the tire up, I hope I didnt run over another deer shed again :(
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
OK I guess Im missing something here, what kind of trees are they and I am guessing you are watering them?
You missed the part 'wildlife waterers' for birds, turkey, deer etc.
And the trees are Live oaks and Mesquites.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Fair enough
It's OK, I didn't brew coffee this morning. I brew coffee EVERY morning.
I slept really good last night, finished cooking breakfast and turned around to get a cup, lol no coffee. I grabbed one The Laundry Fairy's Dr. Peppers and called it good.
g_man
Feb 3, 2023
324
1,464
NE Vermont
Took the snow plow ballast boxes out of the one-ton and put them away. A simple job but good loader practice.
gg
Reactions: 8 users
5,185
Toyman
Apr 15, 2019
120
104
Pittsburgh
Good to know that they can take a beating :) Once you mentioned the hedge trimmers, I remembered I had a set also. Use those for trimming lanes for hunting blinds, and they work very well also.
g_man
Feb 3, 2023
324
1,464
NE Vermont
Tisk-Tisk,.....Throw that 5 lb dry chem extinguisher (on the wall) AWAY.
That has a plastic handle grip, that commonly breaks when used.
Metal valve and handle units are the ONLY ones sure to work, when you need them!
Thanks for the tip - But I just went out and looked. It is metal. Must be my poor photography that fooled you. :)
gg
Old_Paint
Dec 5, 2020
1,944
2,130
AL
Collected the storm falls that I could get to, now it's time to start chipping.
Just watch for dirt splattered on the stuff you’re gonna chip. Might not hurt to wash it with a hose first. Sand stuck to the brush will dull chipper blades almost as fast as rocks.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
258
448
Moseley, VA
Moving a bit of dirt again today as well as cutting the back field. Then it happened, oh well time for the next round of maintenance. I already have the filters and fluids on hand.
Reactions: 6 users
10,030
I used the EA box blade on the back of the MX this evening to do a bit more leveling of the gravel that my neighbors had delivered, and that was rather unprofessionally dumped on the lower driveway. I also did a bit more cutting/dirt moving on the new driveway I'm putting in.
I was reminded that a box blade is a really useful tool and I would have to choose it over the EA land leveler if I could only have one or the other. Luckily I have both, but the land leveler is better at leaving a nice finish on a reasonably flat and level driveway and not so good at moving material around to get a flat and level driveway.
One final thought ... this MX is the cat's meow running around at 2,100 rpm in mid range. It'll pull a fully loaded box blade up hill with ease in mid range. My property is very hilly and the MX handles it like a champ regardless of the task. Such a great tractor and frankly I couldn't, and wouldn't go smaller given what I do and where I do it. I do wish that the 3-point control was smoother. The M6060 control is so smooth in comparison, and therefore much easier to use when trying to adjust the position of the implement.
Reactions: 9 users
