Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
378
161
Southern Worcester County, MA
5,185
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Ok, trees planted today. Geez. I'm tired. At 58 YO, I just can't do them as fast as I used to...and I have a few more aches than 15 years ago... :(
Start:
10 Norways...and a Maple for good measure (or shade the patio)
3 to do for my mom tomorrow...happy (early) mothers day to her.
You made her More Favorite list.
Great work!!
Feeling satisfaction from the hard work, stepping back to look, that's rewarding. 🙂
jyoutz
Jan 14, 2019
3,464
2,550
Edgewood, New Mexico
Yesterday, I attached my Fred Cain ripper cultivator and deep ripped my garden before tilling. Next weekend I’ll plant the cool weather plants.
Reactions: 8 users
5,185
Not to be critical,...
But, you could mount a 5 pound extinguisher in the same place.
IMHO a 2-3/4 lb. extinguisher is not quite enough, for much of anything.
Once fuel gets to burning, it can be quite tough to stop.
Hope that valve and handle are all metal too.
Plastic valves/handles tend to break, when you need them.
You could easily mount a 5 pounder in the same location.
I have had two fires!
One BIG one, ......and one little one!
jyoutz
Jan 14, 2019
3,464
2,550
Good idea. Yes the extinguisher has metal valves
johnjk
Apr 13, 2017
1,705
1,938
West Mansfield, OH
More rock work as I worked on the new turning area, ripped out the old raised gardens and filled a few more low spots on the drive IMG_2176.jpeg
5,185
My 19 yo. son was starting my electric start Gravely.
Spark ignited small tank spilled gasoline, and though he used two CO2 extinguishers (a 5lb + 10lb) it was not enough.
Result: $240,000 (1987 dollars) major part loss of house.
I LIKE ......fire extinguishers!
Dry chemical preferred for fuels.
WFM
L3800
Apr 5, 2013
1,557
1,012
Porter Maine
Cleaned up tree limbs from our 20" storm a couple weeks ago.
Five or six loads on the forks like this.
And lots more around my property to get to.
Reactions: 6 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,543
3,794
PEI Canada
@mcmxi found a rock today. The tractor and grapple handled it with ease😆
Cut some more saplings and dead limbs. Ended up with a decent pile.
Reactions: 12 users
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
I set the pond fence corner posts in the post holes previously drilled. All 15 of them. I’ll make the connecting supports & weld them in over the next couple days.
Reactions: 7 users
3,500
2,094
Hooked up the hydraulics for the new grapple. It's hopefully temporary until I figure out a good way using hard lines down the boom. I think I'm going to like it.
I need to find a good way to park it. LP says open it all the way and lay it face down, but that's sure hard to connect, and it takes a lot of floor space. It'll sit up vertically, but it's not very stable. Need to find an in-between.
Reactions: 10 users
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
324
180
Eastern PA, USA
I can think of a few people I'd like to grab with that fancy grapple. ;)
fatjay
Nov 12, 2016
324
180
Eastern PA, USA
I finished tilling the area with my new holand, and got the garden fence up, and gate built. I'll spread the compost and till once more, then plant. I really want a 3pt tiller for the kubota, the new holland struggles with the hard ground.
Reactions: 16 users
Old_Paint
Dec 5, 2020
1,944
2,130
AL
The primary reason for opening it all the way is so that the cylinder rods are fully retracted and protected from corrosion, as well as having the least amount of hydraulic fluid in them (by the amount displaced by the rods). Put a piece of RR tie on the ground and put the clamp teeth on that to lean it back just a bit to make it easier to connect the SSQA. It should still be forward heavy and relatively stable.
Old_Paint
Dec 5, 2020
1,944
2,130
AL
Dry chem and foaming extinguishers are the only kinds rated for fuel/oil fires. Foaming agents are harder to come by for personal/residential use. It takes a lot more CO2 than you can carry to put out even a small fuel fire because it does nothing to reduce the volatility of the fuel. Even kerosene and diesel are hard to extinguish with CO2 unless there is enough to completely starve the fire of oxygen and cool the ignition source. Keep a good ABC rated extinguisher handy. Dry chemical extinguishers are usually ABC rated. Good general purpose extinguisher. CO2 is better suited for electrical fires where water or any liquid is likely to create a shock hazard. I keep a 10# ABC in the kitchen and a couple 5-pounders in key locations in my shop, as well as one in the back of my truck. I also try to do any gasoline transfer outside for the very situation you describe. Then I lose a piece of equipment, not my house or shop.
I had to take fire safety training every year for 43 years. Some of it made pretty good sense.
7,116
Geddy’s grazing….have spots where lawn took off this spring. Most doesn’t need mowing yet.
I need to get the mower deck ready to go and on the tractor. Still have the loader and chains on. :oops:
Never mowed this early, and weekend weather has sucked lately. Got me behind, along with reorganizing after house projects.
Heck, 2 years ago we had 12” of wet snow and were without power for 2 or 3 days.
I’ll still take this over a foot of snow…. ;)
Reactions: 7 users
g_man
Feb 3, 2023
321
1,455
NE Vermont
I've been working up the firewood that I pulled out last winter. Took these the other day.
Stand between the bucket and the splitter and throw the splits on the pile/row. Straighten them out a little after each bucket full'
If the blocks are to big for me to handle up on the splitter I chunk them up a little and throw them back on the pile. Working of the carry-all gives a nice surface to slide them around on and makes it easy to mount them on the splitter w/o a wrestle.
Seems most of you have green lawns and are starting gardens. Still brown here and still running the wood stove. High today was 42* with bright sun - perfect in my book.
gg
Reactions: 11 users
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
258
448
Moseley, VA
A little bit of gravel and I can finally get to the back of the property without driving all the way around the outer edge. 2 - 12 inch drains to handle the rain and run off. The Kubota moved a fair amount of dirt for this one.
Reactions: 9 users
10,009
Am I to understand that trailer is dedicated to storing your firewood through the summer? Now I AM jealous. That looks like a nice dump trailer from this angle.
It's a 16ft PJ dump trailer but I need it for various projects so the wood will have to get dumped out soon.
