Front wheel wobbles
11,329
Axle or case wear would be my two go too's.
Especially with the clunking I'm hearing.
Does it slide straight in and out too?
4,060
2,503
I'm no expert and it's not entirely clear, but it seems to me the movement is in this area, not the axle. I think that is controlled by the bushings NIW showed in post 6. Did you go into that area?
11,329
A part has to be worn to let it move like that.
You'll have to pull it apart and look and measure for wear.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
709
331
Herald Calif.
I would have any of the parts you might need for your front drive. I would have the outer axle assembly rebuilt ready to ship as well.
