Pulled the pins and the spools (circled on pic) spin pretty easily with the use of a flat head.It is really odd that both are stuck pulled????
Pull the pins and see if the spools move or if the cable moves.
Follow the cables back to the control looking for damage.
The ends of the cables move when wiggled. I will remove the plastic housing and check the cables.
Btw, it’s a hydrostatic, the pto sprins and three point raises and lowers properly. There are two sets of remotes on the back and pushing the levers up and down you can hear the pump working to push fluid.
