Kubota M7060 FEL control lever stuck
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
It is really odd that both are stuck pulled????
Pull the pins and see if the spools move or if the cable moves.
Follow the cables back to the control looking for damage.
Pulled the pins and the spools (circled on pic) spin pretty easily with the use of a flat head.
The ends of the cables move when wiggled. I will remove the plastic housing and check the cables.
Btw, it’s a hydrostatic, the pto sprins and three point raises and lowers properly. There are two sets of remotes on the back and pushing the levers up and down you can hear the pump working to push fluid.
5,226
If the joystick is still stuck with the cables disconnected you have a control cable problem or something is wrong with thr joystick pivot block. The cause should not be hard to find.
8,718
The Spools don't spin to work, they push in and out to work.
If you have the cables removed from the spools and the block, they should move freely
If they are not then something happened in the back.
I'm really confused by you saying it's a hydrostatic, they didn't make a M7060 in a Hydrostatic transmission.
Do you mean it's a hydraulic shuttle? They all are in that model.
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
Yes, shuttle shift. I apologize. Chemo brain is awful.
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
Took the joystick and cables off. Sprayed brake parts cleaner on the and let the soak. They broke loose and the joystick will pivot.
I put the joystick back on and attached cables. The joystick was pretty firm trying to move it but it eventually worked.
I can tilt the bucket back and forth but have no lift. I assume the nuts on the mounting block under the floorboard need adjusting.
Any suggestions on how to reset the adjustment nuts back to a default type position? Then adjust as needed.
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
I believe I have found the problem. The valve mounting bracket is bent (see pic). It bent towards the front left tire approx 3”. I'm going to take it off and attempt to straighten it.
8,718
I was wondering about that, the picture you just posted really shows it.
That bend in that bracket will bind everything up.
If it's bent too much you can get a new one, but ouch!
5,226
I think you have found your problem. Looks like its just a flat plate?? It should be easy to fabricate a replacement if you cant straighten the original.
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
After days of pouring down rain, I finally got the bracket off and straightened. There is a nice 90 degree in the bracket now and no curves.
I’ve put it all back together at this point. How do you adjust and set the cables from the lever correctly? The lever controller is just wabbly now and won’t control anything. Is there a method to set them to a default setting and adjust from there?
8,718
Look at the first picture you posted and set them like that. ;)
Looks like the outer nut was almost to the end of the adjustment.
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
I’ve just adjusted the calbles to match the original picture. The controller lever is just a little wobbling all over. It won’t be even stand up in a neutral position. It just leans whichever way it falls.
8,718
So when you move the joystick do the cables move?
Did you do any adjusting of the cables at the control stick side?
Please provide a new picture of the control stick bottom (pivot points) and the cable mount (that you straightened) at the valves.
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
When I move the joystick the cables do not move. I did no adjusting up at the control stick side. Just cleaned up the gunk and sprayed wd-40.
Here are the pics you requested. If there are any other specific pics you want, just let me know.
8,718
Sounds like the cable have become disconnected under the controller.
Or they got damaged.
Remove the 2 silver bolts on the side and the controller will lift out the top.
If you disconnect them at the bottom you will be able to pull the controller and the cables all the way out.
Need to check that the cables are connected to the ball ends that go up into the controller.
These are the cables ends that attach to the controller.
060 are the ball ends
8,718
To adjust the cables properly, you would put the controller in a lock position.
The slide lock ( RED #020) would go into the slots just below the balls ( Blue #060).
That puts the controller in neutral.
Then you would attach the bottom cables to the spools, as the spools sit in neutral.
CrimsonClay
Kubota M7060
Aug 4, 2021
25
Lewisburg, TN
Does this Allen screw come out to separate the block and check the bottom of the joystick and cable connections?
8,718
I'm pretty sure the allen just holds the fixed pivot point in place.
But you will remove it to get the block to separate from the other 2 joints.
The cables will unthread from the block after you unlock the lock nut on the bottom.
Before you take them out note how many threads they are into the block and note their location.
What you would look for is that the ball ends are seated on the cable and the small lock nut is in place.
