What Attachment?
jyoutz
Jan 14, 2019
3,589
2,692
Edgewood, New Mexico
hmm, I'd call that a cultivator not a plow. To me a plow, has a moldboard that turns over the soil.
Farmers call them chisel plows, as differentiated from a moldboard plow. A true cultivator is for shallow weeding, not deep ripping.
MRudy86
L4701
Jan 24, 2023
42
check local farmers, ask around..since 'no-till' became the thing to do ,odds are there's a LOT of 'cultivators' looking for a new home !
Unfortunately, I don't live in a farm-dense area. I am kind of an outlier. I check FB marketplace and CL all the time, but that's basically what I have to work with.
5,184
The manufacturer calls it an "All-Purpose plow"!
You obviously have the right to call it a toothbrush if you so choose.;)
5,184
We likely live within 100 miles of each other.
I strongly suspect you will not ever find what you are looking for, anywhere close by.
It looks like Wade Tractor, in Griffin, GA. has all sizes of the Bush Hog All Purpose plows available
sales@wadetractor.com
1-770-227-2021
Shipping to RI. will certainly be an issue, but I may be able to offer a shipping suggestion.
There are 6 Bush Hog dealers listed in NH, and no sales tax.
ddavis83864
Kubota Grand L6060
Mar 3, 2021
128
149
Here is what I use to till our property. Just depends on how I angle the disks. Leaves a fairly smooth surface.
Enjoy!
Disk Harrow trailed by a drag harrow.
jyoutz
Jan 14, 2019
3,589
2,692
S
1-770-227-2021
hipping isn’t an issue. When I bought my plow from EA in NC, they shipped it to me in NM though FedEx freight. It arrived at their local freight depot strapped to a pallet and I had to go pick it up. They loaded it into my truck and I unloaded it with my pallet forks. I remember freight costs only being a little over $100.
jyoutz
Jan 14, 2019
3,589
2,692
I have that same chain harrow. I was thinking of doing that with the Cultivator.
It will takeover passes with the plow first because the rippers do have some distance between them.
MRudy86
L4701
Jan 24, 2023
42
S
The place in PA that has the FC 9T cultivator is $425 shipping and the NC place is $485
5,184
S
Shipping rates are NOT the same for all sellers.
MRudy86
L4701
Jan 24, 2023
42
Anyone wanna weigh in on if a flail mower is worth the up charge from your standard rotary mower? Gonna try and rent one of them but if that’s not possible I may pick one up.
11,726
I have an offset hydraulic flail mower and a rotary cutter and they're very different animals. I would say that the rotary cutter is a one-trick pony whereas the flail is more versatile and more maneuverable. The flail will leave a better finish than the rotary cutter too, but ground speed with a flail can be slower.
MRudy86
L4701
Jan 24, 2023
42
I was looking at the woodmax 78. I’m currently cutting 10+ acres biweekly on a z turn cuz if I go any longer the fields will be too long for the z turn. Figured with the flail I could let them go longer and free up a little time for other tasks.
BAP
Dec 31, 2012
3,124
1,257
One thing to consider MRudy86, and that is how much time you want to spend picking rocks after tilling your land. Unless you are one of the lucky ones to one the 10% of total New England land that is rock free, using any sort of chisel plow or cultivator that everyone is pushing you to buy, will pull up every rock on the property. Then you will be picking rocks to get it so you can mow it afterwards. Ask me how I know. I farmed in New England for 45+ years and spent hundreds of hours picking rocks getting land ready to seed. That’s why using a disc harrow, and going over and over will work better. It will still get rocks up, but no where as many because you aren’t going as deep and doesn’t have that pulling up action.
MRudy86
L4701
Jan 24, 2023
42
That's a good point, I am definitely not one of the 10% haha. I have spent more time on my tractor moving rocks than just about anything else.
