B7100 Inoperable PTO
duzitrun
B7100; M4030
Feb 6, 2024
Alabama
Just purchased a B7100 with a non-functioning PTO. Assuming it is a problem with the one way clutch, can it be replaced by pulling out the 4th shaft from the rear or will the tractor need to be split. TIA
3,037
DO you have the work shop manual ?
5,255
1,056
Describe what you mean by non functioning pto.
Your machine has a multi speed pto, are you certain one speed is fully engaged and the lever is not between speeds
More info on tractor such as type of transmission and if 4WD.
Serial number and possible year if known.
Doubt your diagnosis is correct.
If manual transmission, will the tractor start from rest in a high gear without evidence of clutch slipping?
10,747
Do you have a B7100 HST or a B7100DT (gear shift)?
They have both manuals on kubota books.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
181
Attalla Alabama
mossycreekoutdoors.com
Looks like you beat me to that tractor haha. Anyway I'm in northeast Alabama and would be glad to help you if needed. I also have parts tractors. Send me a message with your number if you want.
duzitrun
B7100; M4030
Feb 6, 2024
Alabama
It's a DT. Missed the D manual but went back and saw it is combined with 5100/6100.
Gear transmission, 4wd. I'll check on those suggestions and report back.
