No, just bought the tractor. Best place to get one?DO you have the work shop manual ?
Got it. Much appreciated.go here:
https://kubotabooks.com/AutoIndex/index.php?dir=Tractor Owners Manuals/&AutoIndex=ee0a37a1ed6f3fa74ae29ef5f7b51717
Scroll down to :
virus safe - good documentation too!
Describe what you mean by non functioning pto.Just purchased a B7100 with a non-functioning PTO. Assuming it is a problem with the one way clutch, can it be replaced by pulling out the 4th shaft from the rear or will the tractor need to be split. TIA
Looks like you beat me to that tractor haha. Anyway I'm in northeast Alabama and would be glad to help you if needed. I also have parts tractors. Send me a message with your number if you want.
It's a DT. Missed the D manual but went back and saw it is combined with 5100/6100.Do you have a B7100 HST or a B7100DT (gear shift)?
They have both manuals on kubota books.
Gear transmission, 4wd. I'll check on those suggestions and report back.Describe what you mean by non functioning pto.
Your machine has a multi speed pto, are you certain one speed is fully engaged and the lever is not between speeds
More info on tractor such as type of transmission and if 4WD.
Serial number and possible year if known.
Doubt your diagnosis is correct.
If manual transmission, will the tractor start from rest in a high gear without evidence of clutch slipping?
