Best Battery for MX4800?
trackman23
MX4800
Nov 22, 2023
117
22
NC
My MX4800 cranks too slow to start without the help of a jump battery now that it is cold outside. Any recommendations for a high quality, long lasting replacement battery? The one that is in my machine has no markings on it so I have no idea what size / spec it is and I don't know the OEM size either.
Thanks
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Just a quick look at messicks shows the OE battery is a 80D26R (JIS number), which would convert to a group 24 battery.
Do you see the JIS number on the battery label?
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
553
316
Mandeville Louisiana
Pending the battery's age/condition confirm that the posts, terminals and connection points (positive/negative) are clean (not just tight!), if a replacement is deemed necessary, take the three measurements and get one with the highest cold cranking amps that fits.
5,857
if you do replace the battery, install new battery cables as well. Just because they're 'clean' doesn't mean they're 100%. They corrode from the inside out and you'll get the 'weak battery- slow crank' problem.
if you remove the battery and connect to your truck battery and starter spins great, then not usually corroded cables but heck, batterys out, take 1/2hr,replace now instead of 1-2 years from now ??
5,183
Thanks
Go to local Wallymart!
Buy their group 24 "EverStart Maxx"
Best bang for the buck in the battery market.
Go for "Interstate" ( $$$ ) though,..... if you are tuned into their advertising hype!
3,493
2,077
What viscosity oil are you running? When I went from 15W-40 to 5W-40, both Rotella T6, it made a noticeable increase in cranking speed.
As for battery, measure the space for it, including the height, and note which side the positive post is on. Buy the biggest one that'll fit. I was able to put a truck battery in the Ford, and it was cheaper since the NAPA store bought them by the pallet.
trackman23
MX4800
Nov 22, 2023
117
22
NC
That is a good question...The previous owner changed the oil recently but didn't note what weight.
BAP
Dec 31, 2012
3,048
1,165
Asking for a battery recommendation is like asking for oil recommendations. Everyone is going to tell you that their brand is the absolute best and everyone else’s is junk. Fact of the matter is, there is only 2 or 3 companies that make all the batteries on the market and sell them under many different labels. Buy the highest cranking amp battery you can find that will fit in the space. When I replaced my 10 year old battery last year, my dealer had the best price of anyone around, including Wally World which some people like to support and all the auto parts stores.
5,183
Yup!
The biggest (heaviest) battery contains the most lead, and is usually the most capable.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I like the Absorbent Glass Mat / AGM type, they are a bit more money, but seem to last longer, and have a good reputation.
trackman23
MX4800
Nov 22, 2023
117
22
NC
Thx folks. I ended up with one from the dealership which is supposed to be a private label interstate battery.
looks like my old one was cracked and leaking acid from the bottom…the steel at the mounting location confirms it.
5,183
Contrary to popular belief, Interstate does not actually MAKE batteries!
They are a marketing group called Brookfield Business Partners, and apparently contract with varied battery manufacturers for inventory.
5,157
They are also into property management and own a bunch of shopping centers! The only reason that I know this is because I bought some bonds that they had issued. I think that they are paying about 4 1/2%. I wasn't aware that they owned Interstate Battery.
5,857
hopefully you'll pour a LOT of water/baking soda mixture where that battery was !!! Pour. let it fizz, pour some fresh water on it, repeat until no more fizzies.....
trackman23
MX4800
Nov 22, 2023
117
22
NC
I didn’t think of that but I did spray it with a good bit of fluid film.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
375
532
SE, NM
Boil some water, take it off the stove, add baking soda, pour it on, watch the magic. Hit it with some good paint.
5,183
Too late now!
That potion will not easily remove the already applied Fluid Film.
7,080
They also own Johnson Controls automotive battery division.
