Broken Zerk Fitting
JimDeL
Aug 31, 2022
360
403
Austintown, Ohio
CAREFULLY use an 'Easy-out' to remove it.
jaxs
B1750HST
Jun 22, 2023
927
707
I've been searching six months for utubes showing how to remove broke zerks from tie rods. Will the same method(s) work?
6,634
Look up "easy out" and buy a good quality set, not a HF cheap one. (You don't need anything else to break)
5,152
If you can't figure it out with the helpful hints above, I suggest that you leave it to the Kubota dealer technicians to assist you with this problem.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Only the grease nipple broke off, the hex head is still intact
Easy. Unscrew it and put a new one in. The little nipple’s thread will be fouled up within the body. Don’t try to replace just the nipple.
Congrats on calling it a zerk vs the several other things folks try to mislabel it.
Dustball
2016 B2650HSDC
Sep 15, 2023
418
274
Hudson, WI
Broken zerk fittings are easy to get out since the hole's already there for a screw extractor.
2,062
5,152
Haven't seen one of those tools in a few decades. They used to sell for a couple of dollars in the old days. I would bet that if I searched in my old toolbox I might even have one.
I almost always check reviews of tools and look at the lowest stars first. Most times it is some lame reason that the person gave it a 1 star, however, this is the exception.
[QUOTE}1.0 out of 5 stars Broke my first use
Reviewed in the United States on July 26, 2023
No, I wasn’t cranking super hard on it. I assumed the tool could handle. Now to get this out…Super disappointing
][/QUOTE]
jaxs
B1750HST
Jun 22, 2023
927
707
No, I wasn’t cranking super hard on it. I assumed the tool could handle. Now to get this out…Super disappointing View attachment 117878 ]
[/QUOTE]
But people always point out "Harbor Freight has a lifetime warranty". :confused:
5,152
That was the one from Amazon. In defense of the tool, I doubt that he did that with just his fingers on the tool. Those types of "easy out" tools often crack since they keep trying to go deeper if the part doesn't start coming out. I never use those any longer. I have a set of Snap-On removers that work 1,000 times better and don't break. They also cost a lot more than $29 and they do have a lifetime guarantee..
5,152
It appears that either the original poster is mechanically challenged or he is pretending to be incompetent and wants to see how long this ridiculous thread will go on for. If he can't figure out how to unscrew a grease fitting (zerk) then he has no business owning a simple screwdriver or adjustable wrench. I keep checking for a full moon, but alas it hasn't arrived yet. I'll bet that he is still on his first tank of fuel and when the time comes to put fuel into the fuel tank, he will also need help removing the fuel cap. This thread belongs in the humor forum.
jaxs
B1750HST
Jun 22, 2023
927
707
No worries, screwdrivers that resist inserting into eyes will soon be available.
I heard air pressure is greater at bottom where weight of tractor has tire smooshed. Should stem be at top or bottom when checking pressure?
5,152
At 12 o'clock if fluid is filled into the tire, otherwise it doesn't matter. Now, if you fill your tires with helium it will ride like it is on a cloud. Personally, I prefer to use laughing gas!
Vlach7
L47 305DT JD500C
Dec 16, 2021
372
266
Frazier Park Ca
[/QUOTE]
I had a similar situation with a bolt in an exhaust manifold. When I was drilling it out the drillbit broke and was in there. The only thing I was able to do was use the grinding bits to sharpen chainsaw blades and pushed it through the hole, took me a couple hours of grinding to get through, the whole, but did a good job without hitting any of the threads good luck with yours that may be a little bit harder of a metal too.
