cptbarkey
BX2350
Nov 19, 2023
11
47
Central TX
The engine is buttoned up last night and with fluids. In the final run I was cobbling a few things together, used a vacuum plug on the radiator drain, and an AC delco hose will be my intake for a short while. It will breathe fresh air until I cobble together a real hose to the filter, or order the OEM parts.
Now i'm being held back by the several safety switches. I hear the fuel pump clicking, fuel solenoid seems to be working. Checking all sorts of things, operators manual and hitting the forums.
6,636
Possible. I
I doubt that the manufacturer of the trailer installed those tires and wheels, but most likely the selling dealer switched them out knowing that the bling of aluminum wheels was a better selling point than black steel wheels. He then sold the better tires and wheels to a customer or put them onto a used trailer that needed better wheels and tires because the buyer knew to look at what was on the trailer for sneakers.
Possible. I called corporate shortly after it happened, more as a notification than request for action, and as best I could gather they weren’t really specifying exactly the same wheels and tires on every camper of that model but just throwing on it whatever fit that they could get a good deal on a container load of. It was honestly pretty disappointing from a manufacturer of their reputation. Several things on the quality of build of that camper were disappointing. Most notably multiple leaks 3 days after we brought it home which resulted in my recaulking everything on the roof, which previously looked like a chimp with an electric caulk gun had done the caulking. To their credit, the dealer fixed the minor water damage under warranty. Part of what led us to now have an Airstream.
je1279
Dec 6, 2020
834
585
Upstate NY
I would try to bypass whatever you can to determine that the engine starts and runs well. After that, you can reconnect one safety switch at a time. This way you can easily identify if there is an issue with one of them. I would also put in some fresh diesel if it's been sitting for a while and take a look at the fuel filter(s) as well.
5,187
Not totally tractor related, had Winnebago Minnie 26BHSS travel trailer. 9500lb GVW. Bought it new. Had stylish 16” aluminum wheels and of course new tires. Stupidly think “It’s a decent name brand, no need to check tire or wheel ratings. They wouldn’t spec crap tires on a $35K camper with a name like Winnebago. Trust the engineers.”
First trip out was about 50 miles total as it was the shakedown run. All good. Second run was 250 miles out, 250 back. Check tire pressure pre-trip every time. About halfway back, less than 500 miles total, on a cool, rainy day the right rear explodes. Totally shreds to nothing. Pull off and see the tread is missing, sidewall is just a spaghetti of wires and rim bead killed by hitting the road. Change tire, pray we make it home (we did).
Start looking at tires and researching rims. Rims are rated for 1750lb each. Tires made by some no name Chinese manufacturer rated for 2000lb each. On a 9500lb GVW trailer that weighed almost 8000lb dry weight, well over 8000lb as outfitted and loaded when in use. Bad tires? Bad rim? Bad engineer? Maybe some combo? Regardless: bad.
Replaced all five (including spare) wheels and tires with black steel wheels rated for 3500lb each, shod with Kenda Loadstars rated to carry the full weight of the trailer. Have used Kenda Loadstars on campers, equipment trailers, and cargo trailers for many years. I’m sure they’d blow if I ran over a box of nails or something but thousands and thousands of miles without one failure.
Good trailer tires can be had, but the no name Chinese tires earned the moniker, “China bombs” for a reason.
I’ve heard from others that Greenball is good as well, but no experience with Greenballs.
And yes, I know Kendas and Greenballs are manufactured in China. Seems to be some quality control differences between them and the Fung How Ping Pong Co or whatever random folks make the no name stuff.
Much China "manufacturing" is VERY different from what we are accustomed to.
The Chinese build "knock offs" of many of their own products.
Backyard "factories" produce all sorts of products that are "similar" to those made by their primary Chinese manufacturers.
Kinda crude, but fascinating......A small smokestack/assembly operation in many backyards/alleys.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Post Covid, the products and merchandise found on Amazon is less and less "name brand", and more "off-brand" Chicom junk. The recent change/minimum purchase (for free shipping) jacked up to $35, along with "sold and shipped by Amazon" is more of what I find for my needs. Prior to the $35 minimum to get free shipping, there were many more choices/sellers available of which the purchase could be made. Now that's not so.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
Speaking of tires....
If one goes and they are all the same age, etc. and were inflated to 75 psi....
Drive a new set under them. This new set are Goodyears.
mdhughes
L3901DT
Dec 10, 2014
1,455
1,500
Ste Geneveive county, MO
That looks a lot like a tire that was on my Dodge Ram back in 2009. It was snowing and snow on the roads when I notice something wasn't right. This was on a 2 lane county road with now shoulders. I stopped and got my flashlight out and took a look. It was the passenger back tire. It was ripped to shreds. I got the spare down first and then took the flat off. The tire was pulled behind the brake drum backing plate and I had a hard time getting it off. I didn’t want to pull on it to hard so I didn’t pull it off the jack. When it came off it hit my left knee and I wound up with a nice bump. Someone in a truck stopped and came over and asked if I needed some help. I ask if he could help me put the flat in the bed of the truck. He asked me if I had good clothes on, I told him yes, he said that he had work clothes on and he would put it in the bed for me.
5,187
I use the "list" feature to store items to reach the $35 minimum.
I usually have several items "stored" there, that I am not in immediate need of.
Then, when I need a particular item, I just go to my stored list, and add one or more of those "list" items to reach the $35 free shipping minimum.
Works for me!
I consider the $179 yearly Amazon Prime fee to be a total rip off!
OntheRidge
Nov 1, 2020
494
585
Works for me!
It is only 139, not 179. Worth it for me, but not everyone.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Works for me!
I always use the list feature. The Prime, since getting this new Kubota, I've bought a LOT for it, so in that stint I would have benefit from it.
I know shipping isn't "free", but not seeing it, and it absorbed in the price, I like. Since Amazon changed their marketing strategy with the "sold and shipped by Amazon" push, choices to buy through the brand name resellers are fewer. That's my gripe. I've bought elswhere.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I will not subscribe to Prime. Before buying anything on Amazon, I look at the same item on eBay. It is usually cheaper and free shipping anyway.
I have never had an unresolved issue with eBay but I have with Amazon.
4,193
I find Amazon to be worthwhile, and particularly like their easy almost-no-question free return policies. We live in the boonies and it’s worth a few gallons of gas ($5+) not to have to go to town to pick up many items.
When I think of Amazon …I can’t help but wonder how the now-failed original mail-order-retailer Sears & Roebuck totally MISSED the boat in what was originally Their Idea!
cptbarkey
BX2350
Nov 19, 2023
11
47
Central TX
More progress today, confirmed one of the safety switches is bad, now just a matter of which one. Engine turns over and sounds like it has good compression, used a remote starter switch. My initial guess as to what is really wrong was confirmed as well when I removed the fuel line after the first filter and diesel barely dribbled out. The seller complained it was bogging badly.
I drained about 2.5 gallons after disconnecting the other side of the filter. It was fascinating to see the water contamination bubbles. I am putting a new filter and pump on tomorrow. Getting excited!
5,187
Sears = BAD management!
Old_Paint
Dec 5, 2020
2,036
2,304
AL
Is that metal shavings I see in the top photo? No bueno, amigo. You're gonna wanna know where that came from.
je1279
Dec 6, 2020
834
585
Upstate NY
I saw that as well, but I assumed that the metal shavings were in the pan before he drained the fuel into it. The pump could have grenaded as well though, resulting in a bunch of plastic and metal debris in the fuel system. If that's the case, hopefully the filters prevented any of it from getting to the engine.
cptbarkey
BX2350
Nov 19, 2023
11
47
Central TX
Barely anything came out after the first filter, all that came directly out of the tank thankfully. Brand new drain pan. I am replacing the pump anyway out of mistrust.
