leaking cylinder
4,816
I noticed that my snowblower lift cylinder was leaking last year, and it is also 3 years old. Since this cylinder is common to a lot of other Kubota products, I picked up a spare this past summer that I will swap with the K Connect cylinder. Then I will rebuild that cylinder and hope for the best. I have the identical cylinder on the chute deflection and my snow plow. For both of those items, the cylinder is a lot older and has never leaked. I believe that Kubota just had a bad lot, and everyone is paying the price of having to fix the issue. They are only warranted for 1 year from purchase.
BX Woody
BX1880, FEL, MMM, Bagger, Snow B
Feb 10, 2018
22
Hello everyone, same thing with myself. I have a bx1880 with 54” blower, used 2 seasons and attached it this year and the cylinder is leaking a pool of hydro on the floor. Hopefully getting the oil hot & exercising it will remedy it. There’s no way a 150hr grass cutter should have a leaking blower cylinder after so little use.
Update: cylinder leaking again 2nd year after seal kit. Hydraulic guy said Kubota used a cheap o-ring for the seal which flattens out on one side, said if it happened again he’d put a gland seal in it. I guess it needs a gland seal now!
4,902
It sounds more like you need a quality cylinder from another manufacturer. The snowplow angle cylinders never failed me after 10 +years of HARD service, maybe you can plumb one of them or similar ?
4,479
I am confused by your hydraulic guy's comment.
If the cylinder is leaking externally that IS the gland seal not the piston seal.
Is this a bx2810 quick hitch?
4,902
If BX2820, it's a 2" x 5" cylinder ( not normal...)
but.... maybe a 2 x 4 would be OK ,just won't raise snowblower up as high.
$125......
4,479
$125......
You also need to consider retracted length in that calculation. A "shorter" 2 x 6 may be equivalent. Its also pretty easy to shorten the rod on a clevis end cylinder.
