Rear Floodlight On A LX2610?
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
I thought you found one for your Kubota. Lots of people ask, so I was interested where you found it. It's been the source of numerous threads.
It was faster to pin a water tight automotive connector it than it was to go to the parts store. Searches yielded nothing useful. Lots that looked similar, but no measurements.
Apparently Kenwood stereos use the same plug.
Found these on Digikey-
If I had to choose out of all those, I'd go with-
and
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
Well, part of that explains it. I don't shop Chinazon. Lol. Good to know when people ask about them though. There are a ton of threads here with no real answer. Till now.
Not sure why so many folks are worried about cutting the factory one out. I love my Eastwood kit.
airbiscuit
Mar 18, 2021
422
482
NW WI
So is that the work light plug on your Kubota?
What s the Eastwood kit?
Did you get a work light mounted?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
Not my tractor, it's the same plug I installed. I don't have a photo of the tractor connection. This is a fuel transfer pump power lead from a Yanmar to power the transfer pump on the drum.
I use them all over- lights on the tractor or truck, replace burnt connectors on motorcycles. Totally factory looking. Better than what is used on a lot of equipment.
Foxrunfarms
Kubota LX2610, 1951 Farmall M, 1967 John Deere 110 Rf, 2010 Arctic Cat 700
Apr 25, 2023
366
530
WI
Little bit of an update. There's a winter storm coming so I ordered this wowled off Amazon.
It's magnetic and plugs into the cigarette lighter. I bought this 1) I grew up running farm tractors that had only 1 rear work light, 2) I wasn't 100% sure where I wanted it mounted to look down at my blade and have the rops down, 3) wasn't sure how well it'd work so bought 1 4) I can remove it and put it on the atv.
It seems pretty decent but not getting my hopes up being from Chin-amazon. No directions on hooking up the brackets but it's pretty self explanatory if you look at it. The magnet is bigger and stronger than expected. The cord isn't the longest which for me in fine but a lot of people gave it bad reviews because it wasn't 20ft long.
Granted this was in my garage I'll try to get some pictures from when I'm out in the storm at night. But it does put the front lights to shame.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
If I need something "yesterday" Chinesium works. At least you'll be able to repurpose the mount and wiring when that one fills up with moisture.
Nice thing is, it's not a permanent mount. So if you want to mount it higher, you aren't stuck with the current location.
