Problem kubota 4 wheel drive
GrizBota
Apr 26, 2023
1,147
733
Oregon
Thank you
He was my strength. This is so hard rt now
My condolences on the loss of your Father. As you said, he raised a strong daughter. Try to keep that in mind in this difficult time. I’m sure your Dad would be so proud to know you are keeping on keeping on with your quest to get the tractor fixed and keep the cows fed.
Your struggles and sharing them may well be inspirational to others that find themselves in difficult times.
I wish you all the best in dealing with all you have in front of you.
cowgirl
Kubota
Oct 7, 2023
42
Tennessee
Thanks for your support ..wsiting on Wolfman he was helping me and I can not find him
cowgirl
Kubota
Oct 7, 2023
42
Tennessee
Serial #50378
Model #M8540D
Hi Wolfman have not worked on the 8540 lost my Dad and hard to keep my mind in a better place
Need to replace the pinion gear and propeller shaft..is there a easy way to replace the pinion gear without disassemble the frontaxel
Thanks
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
870
canada
Hope this helps, I am not the best at computer stuff. There are four different "D" versions of your tractor, so I just picked the first one. 3C09197080 bevel gear kit. They all seem to use the same kit.
cowgirl
Kubota
Oct 7, 2023
42
Tennessee
Is there a simple way to replace the bevel ..pinion? Gear without disabling the front.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
870
canada
I am not sure. The pinion comes out by removing #50 snap ring. Whether you can do this with the axle in place or not, I am not sure. It looks like you should be able to, but I don't know if the oil pan would be in the way or not. I am just going by the parts break down, and have no hands on knowledge. Hope this helps.
cthomas
LX2610 HSDC
Jan 1, 2017
865
576
La Farge Wi
My condolences on the loss of your father. You can click on Wolfman's picture to send a message to him.
11,046
Thanks
You can replace the pinion without pulling the axle out, but you will have to drop it down to get the rear carrier off.
That will allow you to get the seal, snap ring, shims, bearing, spacer, bearing and pinion out the back.
But the ring gear require some disassembly of the axle to get to the gear.
