Finish mower blade sharpening? Jigs, freehand, angle grinder, bench grinder, stone, paper?
MAArcher
Kubota B8200
Oct 6, 2022
New England
Is there a consensus on the best way to sharpen finish and brush mower blades? I have an angle grinder, Dremel tool, bench grinder an oscillating edge sander. And I'm on the market to find a deal on a used 72" belt grinder. If I had the belt grinder I probably wouldn't be asking the question.
The bench grinder leaves a concave surface, the angle grinder requires some free hand consistency skills that I don't have and I'm guessing the Dremel's too small and would get to hot if removing a lot of metal. I'm thinking maybe a jig for the angle grinder?
Any recommendations?
armylifer
Mar 26, 2013
2,243
1,004
Thurston County, WA
I use a file. I used to do it with a hand grinder but I took too much metal off that way.
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
If you have lots of time some 4000 grit sandpaper :ROFLMAO: I use a belt sander with 80 grit sandpaper and have a mower blade balancing cone. For the brush hog blades use a angle grinder.
bird dogger
Vendor Member
Feb 24, 2019
1,722
1,672
North Dakota
You should check out this repair/sharpening thread, here on OTT for some differing ideas.
For my rear finish mower, I used to hand sharpen with a 4" grinder. A few years ago I upgraded to the "All American Sharpener" listed in the above thread. Was it necessary....no. Do I like it???.....absolutely. It takes all the guess work out of maintaining and sharpening a clean straight edge.....quickly!!
A blade balancer to get the blades evenly balanced after repairing/sharpening makes a world of difference.
For my brush hog mower.....4" grinder by hand with the mower deck tilted/raised up and an eyeball sharpening job is all it needs. :ROFLMAO:
Velma
B2301, FDR1660, RB1560, SGC0554, Pats QH, CMP Dethatcher
May 12, 2022
95
58
MI
4.5" angle grinder with 'flap wheel' works better for me than 'grinding wheels'...
2nd vote for the flap disk. A low grit 60-80’ish makes quick work with sharpening.
I sharpen free hand. As the sanding leaves a shiny surface. Quite easy to see where it’s hitting to maintain the angle.
jaxs
B1750HST
Jun 22, 2023
986
761
I like the edge a bench stone puts on blade but I'm too lazy to use one. If your neighbors watch 4.5" angle grinder looks cool and 7" looks macho.
MAArcher
Kubota B8200
Oct 6, 2022
New England
I'm tempted to try and American knock off.
I also just remembered that I bought one of these file sanders for another project:
Might be easier to freehand than an angle grinder. there's a platen behind the belt so I bet you could keep the blade angle pretty easy. Probably try that first and if I don't get the results I want, then try the angle grinder jig.
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
If they are not too beat up I will give them a quick once over with the angle grinder. If they are really beat up I blow the 21 bucks and let the local shop do them.
Daferris
LX2610
Nov 23, 2021
486
411
Mid-Michigan
I use this for the blades on my zero turn. I found it used for about 50% of the new cost and it works really well. It makes sharpening them better than I could do by hand. I have 5 sets of blades I rotate from being on the mower to getting sharpened. I only get 10-15 hours out of them before the cut quality starts to fall off.
bird dogger
Vendor Member
Feb 24, 2019
1,722
1,672
North Dakota
I think you'll find a 4" grinder with a coarse flap disk is the next best thing to a jig for an easy sharpening/touch up job.
Regarding the All American Blade Sharpener: Reviews comparing the "knock offs" to the "All American" say that the knock off's build is on the sloppy side with some play at the joints. All I know is the actual "All American Sharpener" is top quality built with both materials and workmanship. The moveable parts are smooth and tight with a lot of adjustments for all the different types of blades that can be mounted to it.
One can get really good just using a hand grinder. But that jig can make your blades look like new with almost no skill involved.
A buddy took 3 sets to be sharpened at his dealer. It cost him $90 last year. He showed me his newly sharpened blades. Whoever sharpened them did a terrible job!! I told him he should get his money back!!
When he saw my blades and how they balanced.....he asked if I'd sharpen his quickly. :ROFLMAO: I did. His blades weren't even remotely balanced. He promptly ordered the All American Blade Sharpener. Said it would pay for itself quickly.
I bolted my sharpener to a piece of angle iron so it can be clamped in my floor vise to use and stored elsewhere until needed. The blade balancer also mounts to that angle iron base.
3,495
2,087
If the blacksmith was still alive, I'd be tempted to take badly dull brush cutter blades to him and let him hammer them out, instead of grinding so much metal off. Sort of like I watched him sharpen plows so many times.
Alas, he's long gone.
PaulL
2,642
1,624
NZ
I'm much lazier than all of you. But I suspect this is secretly a religious thread with no correct answer.
I do mine on the bench grinder. Probably once a month. After two years I'm close to putting new ones on. I've never balanced them, and they seem OK. The deck doesn't vibrate, they seemed to balance reasonably level when I did check them once.
The other things I do to my deck will do far more damage than slightly out of balance blades. And I don't think the angle is all that important - I can tell I'm slowly creeping the angle over time and I don't really mind. They still cut the grass.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
Wow. I'm truly out of your folk's caliber.
For my lawn, or "finish" mower, I buy new blades every 5 years or so.
For my Brush hog blades, the duller the better. I replace them when they get too short.
The only blades I sharpen are on hand knives and chainsaws.
edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,130
841
Wellsville, PA
I scrape them off then grind them on a bench grinder and its always work fine for me when they start getting getting thin I'll just replace them.
3,945
2,608
When my ZTR starts leaving windrows I take my blades off the machine, put them in a vice and use a 5 inch grinder with 60-80 grit flap disc to put on a clean, sharp edge and bevel. I then scrape grass clippings from my deck using a chipping gun with a 4" chisel before re-assembling.
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
Belt grinder to sharpen then blunt edge square 1/16”. Stays sharp for most of the season.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
375
532
SE, NM
Yeah - don't over think it.
Ha, I might be under thinking it.
I've progressed from a hand file(back when I couldn't afford power tools) to the flap disc. If it takes more than five minutes I feel like I'm doing it wrong. I care about the angle and not getting the blade too hot. I try not to get it too hot to touch.
