Finish mower blade sharpening? Jigs, freehand, angle grinder, bench grinder, stone, paper?
leveraddict
Apr 1, 2019
905
592
NEPA
Sandy soil here. I have to replace my blades every year because they get sand blasted paper thin.
Bring your file, I like to watch work in action!
Ahh ok! I just cut grass. All I ever need is a file! Nope! Not going to add If you cut sandy soil to my rocks and roots post! LOL!
TopK
BX2360
Jul 30, 2023
Aylett, VA
I'm much lazier than all of you. But I suspect this is secretly a religious thread with no correct answer.
I do mine on the bench grinder. Probably once a month. After two years I'm close to putting new ones on. I've never balanced them, and they seem OK. The deck doesn't vibrate, they seemed to balance reasonably level when I did check them once.
The other things I do to my deck will do far more damage than slightly out of balance blades. And I don't think the angle is all that important - I can tell I'm slowly creeping the angle over time and I don't really mind. They still cut the grass.
My last Bush Hog totally came apart because my sharpened blades were out of balance. I would just use an angle grinder on them once in awhile - never removed the blades, so didn't weight them to see if the grind was the same. The bolts where the Gear Box attached to the Mower Deck basically failed as a result of the imbalance (and I didn't grind off very much metal at all).
Mowbizz
Bx25d
Aug 19, 2021
556
322
All American blade system is the tits! I used to free hand but now my blades are shaving sharp….or can be. I run the edges lightly across the grinder just to create a non-razor edge that lasts all season and leaves a beautiful cut! I mow 5 acres with no land mines to ruin blades.
lynnmor
B2601-1
May 3, 2021
1,662
1,438
Red Lion
Since you are now free handing the grinder, how is that any different? That "system" is just a fancy vise.
Mowbizz
Bx25d
Aug 19, 2021
556
322
[/QUOTE/]
I guess you haven’t googled the All American system…your grinder is part of the system. It is attached via a threaded “pin” and fitted into a bushing on the arms of the system. NO FREE HANDING REQUIRED!
