aaluck
Oct 9, 2019
991
841
Snowdoun, AL
Always thankful for rain but this is getting ridiculous. I’m mowing every 5 days… IMG_2008.jpeg IMG_2007.jpeg
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
819
Andover, KS
I measure the well depth by tying a bolt to baler twine and dropping to the water. Then put a knot at the top. Then lay out the twine and measure. I leave the twine/bolt nearby so I can gauge the water level any time. Putting a tape measure down into water is sometimes difficult to know when the end of the tape is at the water's edge because of any movement down there! And I don't risk losing a good tape measure.
I will do something like that to see how deep it is. It has not been used since the mid 1990s. The tape came back pretty cold & clean, just wet. It amazes me that someone(s) dug & lined with rock at least 25’.
There is another well with an old windmill that is 5’-6’ wide & 42’ deep (I was told). I will check that well too.
Old_Paint
Dec 5, 2020
1,984
2,211
AL
Dug up a partially ground oak stump from some trees I had taken down about 4 years ago. One of the reasons I don’t like grinding stumps is that they will always wind up being sink holes, but the grinding was part of the price for removal. Within a year, a 4 inch tall and very solid chunk of this one was trying to kill my mower. Started digging on it a couple days ago, but got rained out, so finished the job today.
023EA569-EB41-45C4-8EEB-973EBD14E8C5.jpeg 86FB08DB-E945-4E25-837B-CA10500C878E.jpeg
The TEE post in the photo is my homemade stump puller. I used a subsoiler and stump bucket to cut/break most of the roots, and a pickaxe to get a couple I couldn’t get to with the tractor. Wrapped the chain under the root stubble and over the puller, and Bob’s yer uncle. This is actually the second piece I pulled out. I got some out on the first dig that looked like a totally separate older stump, which was also charred. There’s a pretty good sized mound in my front yard that I’m almost positive was an old homestead which was razed when this neighborhood was built, and all the trash and debris was covered by clay from the excavation for the foundation of my house. We pick up at least a pound of broken glass every time it rains. If I can get a good layer of centipede going, that’ll solve the problem with most of the glass. This stump always seemed to be leeching some kind of smelly black ooze that looked like used motor oil, but apparently it was from the older stump under it. The soil has a very smoky smell to it where I dug it up, but I’ve been here 20 years and know for a fact there hasn’t been anything burned out there since I’ve been here.
I also brought a couple bucket loads of compost and soi to fill in the divot from the stumpin’. Gotta get some grass seed and straw to cover it before it rains again.
When I finished with the front yard, I pushed the edges of my giant compost heap up on top of the pile and did a little boxblading to fill in another stump hole from a gigantic sweetgum that got knocked over last winter.
Made a bit of a mess on the tractor tending the compost heap, so hosed it off and knocked most of the mud outta the treads. Came up on the porch with a cold smoked porter homebrew, and wrote this while I was cooling off.
Snowman7
May 20, 2020
401
309
Boyne Falls, MI.
While you guys were having fun, I was trying to get my yard mowed. Everything was going good, weather was almost tolerable, until I stirred up the yellow jackets. Five or so got me. When I was undressing in the laundry room, four were still trying to sting through my socks. That was the end of my outdoor activities. Fortunately, I'm not deathly allergic to them.
Damn, that trashes a good day outdoors
Old_Paint
Dec 5, 2020
1,984
2,211
AL
Use something heavy (2-3 pounds)so there’s no doubt when it hits bottom. A nail on bailing twine is gonna be harder to detect because the baling twine has some buoyancy, unless it’s a really big nail. I found an old frow (for splitting shaker shingles) when we cleaned out a similar well in our yard when I was a teenager. We tied that to a hundred feet of paracord for our depth gauge. Each day, before we started pumping the well dry for excavation, we’d measure the depth of the water to get some idea how hard we could use the well.
Cleaning out that well is probably not in my top 10 favorite memories.
Old_Paint
Dec 5, 2020
1,984
2,211
AL
I don’t know if there’s anything on this planet that will put me in more of a rage than those things. They build in the ground to get that little bit closer to Hell where they came from. I let ‘em calm down, and come nightfall, I show ‘em how much a B***H karma is. I go find the hole while they’re still buzzing around, then return at night with a suitable size drink of 89 octane, typically about half a cup, in a 2-liter bottle that plugs the hole with them in it. I go back a couple days later to make sure I got the whole nest.
Knock on wood, I haven’t had any this year.
radas
Mar 21, 2022
719
834
Picked up a ssqa receiver to move my trailer around alongside my house without the pain of having to use my truck. I can back it in with a little effort but it'll be so much easier with a small tractor. Screenshot_20230724-210005~2.png
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
108
114
Bloomington, IN
View attachment 108025 View attachment 108026
Hi - Trying to understand your t-post puller, as it might help me with an upcoming project. After doing what you can to cut surrounding roots, you're putting the chain around the root ball, then somehow running the chain over the t-post as a fulcrum before attaching the chain to the drawbar? If so, I assume the t part of the post is on the ground and maybe the chain wraps around the 4x? I'm looking at the pictures - now I guess I need (hopefully less than) 1,000 words.
Chanceywd
Mar 26, 2021
799
785
central ny
You will love using it!
I love my lift! Put it in when I built the garage 20 ears ago.
Had 2 brothers here sunday and we did brakes front and back on ones 2017 Jeep compass. He uses the thruway a lot and salt made those a bear to do. The lift made the difference it was stand up work for 68 yr old owner, our 66 younger brother and me the 70 yr old lift owner. Had a couple beers after and a nice lunch.
Bill
Reactions: 6 users
7,303
Bill
Bill - just a short distance east of you…..need another younger brother?!?!?…..🥺 😉
Have two friends with lifts close to us. It’s like having a swimming pool for do-it-yourself guys….. you get lots of new friends…😉
5,166
I would put a few pounds of chlorine powder down the well to sanitize it if you are considering using it for drinking water. Water in the well is always moving in and out of the well, so in a few months, the well and surrounding rocks will be disinfected.
trial and error
Feb 16, 2023
394
386
NY
@DustyRusty I know you are likely not the original source of the info you gave so keep in mind this isn't "an attack at you lol." This info or advice is passed around the interwebs like a bad cold amd it is dangerous to
I am going to preface this by saying I am not looking for a argument or debate as I know this is not the thread for these things. and while I appreciate the advice for dissenfecting potable water with a dose of bleach or chlorine. This is a unsaglfe and temporary way to do so. DOH has strict protocols for disinfecting potable water and for good reason, people can get very sick and even die from contaminated drinking water.
Now there methods for properly treating contaminated water that is to be consumed.
1 is boiling for X amount of time
2 a DOH aproved U V system
3 a constant chlorine injection system with a minimum 240 gallons of rentention/contact and strict daily cl residual checks
Pouring X amount of bleach or chlorine down a well will dissenfect water and pass a bacteria sample BUT... it does not treat the source of contamination in a permanent way it is only a band-aid and the results and time that is affective can and will vary.
Again I apologize for criticism of this advice, and my reply may not be even apply in this particular instance. However contaminated drinking water is not something to take lightly and there are protocols in place for a reason. And that is becuase people can and have gotten very sick and even died from improper treatment or a false sense of security consuming what they believe to be "treated water" becuase of bad advice
P.S. I work for a water treatment company that is DOH certified and has been in bussiness for over 30 years so I'm not just pulling this stuff out of my Backside
7,514
I did a search looking for reports of deaths from drinking bad water. The EPA mentions children less than 6 months old in this paragraph.
"Nitrate and nitrite are present in chemical fertilizers, human sewage, and animal waste and fertilizers. They can contaminate a private well through groundwater movement and surface water seepage and water run-off. Once taken into the body, nitrates are converted into nitrites. High levels of nitrate and nitrite are most serious for infants. High levels of nitrate/nitrite in drinking water can cause methemoglobinemia or "blue baby syndrome". These substances reduce the blood's ability to carry oxygen. This acute condition can occur rapidly over a period of days. Symptoms include shortness of breath and blueness of the skin. Infants below six months who drink water with high levels of nitrate can become seriously ill and die."
I was interested because the well at my farm is 6' in dia. laced with flat rock from top to bottom, 25' deep, and lover 100 years old . I had it tested by the EPA because I was concerned about run off from pasture and oil wells mis-managed. I can't remember the exact numbers, but when I got back to the man at the EPA he apologized for not getting back to sooner. He said "the number" was so low (in parts/ million) he justleft it on his desk.
I put a pump at the top of the well right next to the hand pump and ran water lines up to a corral with two hydrants and an automatic waterer. The water is crystal clear. I clean out the inside of the waterer every few weeks. I am sure the inside of that waterer has more :stuff" than the well. The cattle often add some slobber and grass remnants!!! ;)
Have a friend who hauls his water and buys his drinking water. He comes with several gallon containers and fills for his drinking usage. He's been doing this for 5 years and declares it's the best water he's ever drank. Suggested I bottle and sell it!
I do have concern about safety of water. Can you point me to articles of human death caused by bad water coming directly from the ground (not lead pipes)?
trial and error
Feb 16, 2023
394
386
NY
@D2Cat ill have to get back to this later, I'm @work and have a busy evening ahead of me when I get home. I think you answered your own question in the article you cited above though. Yes it is rare and mostly if not all in infants but that was not the point of what I wrote, becoming sick over something that is completely avoidable is no fun either. Btw the guy who pulled your samples did what is common practice at least where I am "no news is good news" on BAC samples
