trial and error
Huge news, it's far from operational, but I no longer have two separate halves of a b7100. Got the new seal installed flywheel back on (that was a challenge becuase although we thought we marked it we did not do a very good job and struggled as the bolts only line up in one pattern) got the clutch kit installed and all of the bellhousong to engine bolts in and snugged down. Also got the rear subframe bolts back into the rear axle housing and torqued down. Still have to go back around the bellhousong bolts and check torque but that's minor. The rest is relatively easy stuff just putting everything back in its place and giving it a test fire and run before everything "not crucial" goes back on
The re-marrying of the two halves although slow went very easily it practically fell together. Driveshatlft didn't even put up a fight as we didn't remove it and I was a little concerned about that going back into the front splines.
