Torque Wrenches
paul888
US
Can anyone recommend decent priced torque wrenches? I just took delivery of my LX and I need to get torque wrenches to cover the required ranges.
OntheRidge
Nov 1, 2020
495
587
I use an Icon (Harbor Freight), 40-250 ft-lbs.I think around $100.
GrizBota
Apr 26, 2023
1,147
733
Oregon
Depends on how good is good enough for the end user. Anywhere from $500 plus snap on to $20 Harbor Freight will buy one that works fine. Most of mine are on the lower cost end. A 1/2 inch drive torque wrench that goes up to about 150 ft-lbs will do “most” routine maintenance you need on a CUT tractor. One that goes up to 250 ft-lbs would probably do nearly everything you need to rebuild a CUT. I think the rear wheel lug torque on my L is 160 ft-lbs, what’s that, 150 plus a little bit? The torque wrenches with the “clicker” are handy. Nothing against the beam wrenches, but you have to be able to see them.
cthomas
LX2610 HSDC
Jan 1, 2017
865
576
La Farge Wi
You forgot about the the Snap-On torque wrenches that beep and vibrate when the requested torque is reached.
GrizBota
Apr 26, 2023
1,147
733
Oregon
Lol. There’s probably a whole lot of things I didn’t mention.
paul888
US
I just need something that is accurate and can do the job. It's only needed for the tractor so its use will be limited.
lynnmor
B2601-1
May 3, 2021
1,796
1,604
Red Lion
There has been Youtube videos comparing anything from real cheap Harbor Freight to over the top expensive ones, their results should convince you to buy the real cheap ones for tractor work.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
I can't vouch for their torque wrenches, but HF feeler gauges are the worst thing ever.
Pretty much been using the Craftsman branded ones for ever. They have remained pretty accurate for their service life. I check them every so often.
Unless you are building engines or transmissions, the accuracy isn't as important as repeatability. A wheel doesn't care if it's nuts are 150 or 180 lb ft. It does care that they are all close to the same torque though.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,212
3,563
Eh, I don't put too much stock in what is shown on the tube. I know enough mechanics, and built enough bikes and Jeeps to know that you get questionable quality with cheap torque wrenches.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
this is the way 😁
I like a digital for accurate automotive/engine use. (y)
But for general use (lug nuts, fasteners on tractors) the various Proto (click or beam style) torque wrenches I have do a good job. Two of those are calibrated however.
4,196
Do you know how aircraft shops certify clicker torque wrenches? They use calibration stations…OR….they use beam torque wrenches for comparison. So, …guess which type is more reliable for the long term…
4,196
bought this:
https://www.harborfreight.com/hand-...e-10-150-ft-lb-click-torque-wrench-63882.html
cannot say it is "perfect" nor do I know the error while using it.
But have used it twice so far and no problems.
They claim the same accuracy as Snap-On….2%. I’ve checked my three HF torque wrenches…(1/4” in-lbs, 3/8” ft-lb and 1/2” ft-lb…and they are ALL within tolerance with my Thorsen beam torque-wrench.
(at least the HF tool-store keeps the American cashiers and distribution-network workers employed) 🙄
MountainMeadows
Jun 6, 2022
220
291
Poconos, PA
Don't forget the built in torque wrench we all have. Just tighten until your elbow clicks and you're all set.......
Elliott in GA
Mar 10, 2021
875
881
North Georgia
Tekton - nearly everything is built in Taiwan or the US, and the price/quality are right.
3,057
I always liked the GRUNT and a HALF method too!
