I did something new today, used the FEL and the Q/A frame to hoist the harrow, WHILE also mowing. Didn't want to make two trips (1/2 mile), so mowed backing up, while also dragging the harrow. This gave me the option of lifting it clear up while going across my driveway and other areas not needing harrowed. This will be my new way to harrow, mower or not. Then I positioned (2% grade, down) 60' of drill pipe that captured my spring water, which originates 300' lower and 2000' away, and is pumped into a 2100 gallon storage tank at the highest end of my 70 acres. The tank has an overflow, and thanks to the fall of the property in 60' it exits the pipe about 5' off the ground. A water wheel, (using some 5' 100 year farm implement iron wheels), or a Japanese deer chaser, (a giant sized one, not of bamboo but 6 or 8" pipe)may be in the works, just as a hoot and also an easy to eyeball indication that the tank is full. With my "spring re-location" project in it's first summer, I have 3 to 4 K gallons of water to play with, every sunny day, and also am wrapping up an extensive irrigation project.
