BXHoosier
BX24
Jan 21, 2018
513
634
Indiana
Used the backhoe on the BX24 to peel off the sod for a paver path from the garage to the deck landings. Picking up another 2.5 tons of #73 limestone tomorrow for the base for the paths. So far, I’ve got 5.4 tons on the 90’ path from the deck to the barn. Another 2.5 tons should be enough to finish everything.
D5D584A6-E5BD-4790-8C86-87DB70EE8934.jpeg A410C3B1-7E23-43E5-A7C4-CA8B0167A45B.jpeg
Bmyers
May 27, 2019
3,644
4,958
Southern Illinois
Send some of that moisture here, where gardens are not even germinating in the dry soil.
We received an inch and half of rain yesterday (some spots seen more). It was badly needed and greatly appreciated.
11,757
I was on the struggle bus most of yesterday. It started out ok welding two D-rings (repurposed) onto the front weight bracket that I bought last year. I used 7018 rod, beveled the loop to get good penetration, and made multiple passes. The D-rings are for trailering the tractor and so far that's the only part of this project that has gone well.
I thought that the Kubota weight bracket and Kubota "brush guard" would play nice together but that isn't going to happen. Initially I was supporting the brush guard with a floor jack and blocks and trying to lift up and bolt the weight bracket in place through the guard. That proved to be extremely difficult and finally I removed the guard only to realize that the suitcase weights won't fit on the bracket with the guard in place. I don't know if Kubota suitcase weights would fit but it's moot at this point.
Next up was to bolt the bracket to the tractor sans the brush guard. Not ideal but I can live with that and make up a custom guard or modify the current one over the summer in time for forestry work in the fall. So after getting the weight bracket installed I put one weight on and although there's minimal clearance between the weight and the hood it fits. Great, now to get the other seven weights on. Nope! The weights are a little oversized and they interfere with the steel lip that runs around the base of the hood. I bought the weights from Everything Attachments but they're made in India so it should come as no surprise that the "Kubota" weights aren't plug and play. Now I have to modify all ten weights by adding a groove or notch to provide clearance. I must have moved 3,000lb of steel by hand yesterday afternoon/evening getting the weights off the trailer, test fitting them and moving them back to the trailer. Who needs to pay for a gym membership!!
aaluck
Oct 9, 2019
1,008
845
Snowdoun, AL
Had yet another tree fall this weekend. This one right on the gate. Those forks I purchased when the tree fell last week are worth their weight in GOLD. Front1.jpg front2.jpg front3.jpg front4.jpg front5.jpg front6.jpg front7.jpg
Reactions: 9 users
cthomas
LX2610 HSDC
Jan 1, 2017
866
576
La Farge Wi
Instead of grinding all the weights, can you install a couple washers to the bracket to allow clearance?
3,165
If it was me I would get a thick steel plate spacer and move the weigh bracket out and avoid interference with the hood when it gets opened.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
688
755
Indiana
It rained today. The day before yesterday, I mowed field grass outside of our yard. It was about a foot tall since I mowed it last month. I'm getting better at not leaving high spots or scalping it. Lots of dips and humps. I need to get a hydraulic top link that can float.
Reactions: 6 users
11,757
That's a good idea but it turns out that only the two center weights needed clearance so I notched the backs of two weights. The bigger issue was that the fillet weld on the back side of the bracket was interfering with the weights and preventing them from sitting down on the bracket (see first image below). I fixed this by chamfering the appropriate edge on all eight weights. Fortunately the steel is fairly soft so it didn't take long.
Reactions: 7 users
11,757
Yes, this is a good idea and something I'll most likely revisit in late summer, early fall. There's no interference with the hood. The interference was between the two center weights and the lip that the hood gasket compresses against when the hood is closed.
I might weld a spacer plate to the brush guard, and then weld the weight bracket to the plate and bolt the whole thing on as one unit (easier to handle with a floor jack as one piece) if this will give enough space for the weights to clear the brush guard. Another project for another day.
3,165
With the front of the weights so close to the hood, what will happen when you raise the hood if the weight is on? I am assuming the hood opens from the rear and will hit the weights as it rotates up but I really
11,757
The hood opens from the front and there's no issue with raising or lowering it. I took some more measurements this morning and I would definitely need to add a plate (spacer) between the weight bracket and the brush guard if I wanted to have them on the tractor at the same time. At least I have something to think about moving forward. The bottom photo shows the steel lip that the hood gasket sits on when the hood is closed and that's where the interference is/was.
By the way, the paint that was applied to these weights is an absolute joke. I would rather they were unpainted so that I could apply paint of my choosing.
As I said, these are not Kubota branded weights and I have no idea if this would have been an easier install with factory weights. Here's a comparison of the EA Kubota weights for this tractor.
forky
Feb 23, 2021
352
395
Wisconsin
Good for you and the million-dollar rain. We are praying for rain here, but it looks like another week of hot and dry here.....dang!
Bmyers
May 27, 2019
3,644
4,958
Southern Illinois
It looked like most of the corn was going to struggle to be knee high by the 4th. Yet, after this rain, the corn has taken off and it is quickly approaching waist height. The plants are just sucking up that water. Looking at NWS, we are still between 5 to 6 inches short of our yearly average. Hopefully, more rain this weekend (smaller chance), but what we got has made a big difference.
SteveBX23
LX2610SU; BH77
May 23, 2021
185
313
South Jersey
2566790D-AA82-4ABD-A5E8-EAE9261AEC60.jpeg 9C4D0573-CCEF-4892-9B96-0C75C0C9D09C.jpeg
Brought home the LX today. Glorious day. Early test was picking up and moving a big stump the old BX could only dream about. It wont be hard falling in love with this machine
Reactions: 20 users
GrumpyFarmer
5,252
I was trying to sneak in a quick mow, when Mother Nature decided to rain…all I could think about was why have I been so cheap to not have a canopy 😢. Rest assured I did not melt.
7,368
Since I was a little farm kid, nobody ever thought I was sweet enough to melt in the rain.
Six decades in I've proved them right.... :)
3,165
Well the hood opening from the front makes that work better. Thanks for the information
What is the 90 degree angle hole through the weight for?
The ones I bought from the dealer (but not Kubota brand) for my older L 185 have a bolt that attaches them to the weight bracket and a round hole in the weight similar to the angle hole in yours. I ran a piece of all thread through the weights and clamped them together with nuts to keep them together and red the movement of them slightly. But the paint on them was also poor quality
11,757
The 90 degree hole in the weight is for a piece of heavy duty angle to pass through, which bolts on either end to the weight bracket to keep everything nice and tight.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
When it's hotter in South Texas(Heat index here reached 120*) than Death Valley this week, the seat cushion decided it wanted to part ways with the backing.
And a little bit of hog relocation.
  • Sad
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
Last weekend I was the winning bidder on a lot of ten 20ft pieces of 4" Sch.40 pipe (galvanized) which looks like it might have been used for a pivot irrigator or something. I got the lot for $108 which works out to be $0.54/ft.
Drill stem is regularly for sale up here on Craigslist and similar. Here's a typical price range.
  • 3/4” sucker rod 25’ lengths, 50 per bundle. 15.00 per rod
  • 7/8” sucker rod 25’ lengths, 50 per bundle. 17.00 per rod
  • 1” sucker rod 25’ lengths, 50 per bundle. 19.00 per rod
  • 2-3/8” pipe 40’ lengths, 1/4” wall thickness. 80.00 per stick
  • 2-7/8” pipe 32’ lengths, 1/4” wall thickness. 85.00 per stick
Here's another listing in my area.
  • 2-3/8" X 31' STICKS OF DRILL STEM. $74.00 EACH
  • 2-7/8" X 31' STICKS OF DRILL STEM. $90.00 EACH
I just paid 85 bucks for 2 7/8" 31' long stem pipe here in idaho. I was happy with that. I love the stuff...., have used it for years.
