Bent Quick Attach on Loader
BAP
Dec 31, 2012
3,124
1,256
this ...
I recently bought a new 3902, it now had 30 hours and the rod has bent
is 'sail's post'.
yes, NEEDS to be a separate post and it's really,really vague !
'the rod is bent' on his '3902'. NOT enough information. I only own one Kubota, a BX23S, so I don't know what a '3902' is, could be a B3902, BX3902, maybe a MX3902 ?? What I do know is that not ALL loaders and QA plates are the same, different configurations and construction is used. probably based in part on WHAT tractor it is attached. I can't assume it's a B3902..my luck it's really a BX3902......
'the rod is bent'. 'rod' to me says 'rod', a solid round bar of steel, say 'hydraulic cylinder ram piece' NOT a section of structural tubing that connects SSQA plates together.
A picture is worth 1,000 words and would really SHOW what he's talking about.In my 'free' time I help others with coding issues using microcontrollers. Those that give details and examples are easy to help,even those they're 1/2 way round the World and in their native language.
What does your BX and your computer coding have anything to do with this. If you have paid any attention at all to this site over the last year you would know that a 3902 is a new L series tractor Kubota came out with and if he is asking about a bent tube on a thread titled “Quick attach on a loader “ then the common assumption is he is talking about the tube connecting the two sides of the ssqa. Giving a new member a hard time and babbling on about your other life experiences is just driving away someone new asking for help.
6,245
he 'hijacked' the original thread at post #51..
I'm betting not everyone using this forum KNOWS about every new product Kubota comes out and what it looks like.Heck odds are 50/50 BAP doesn't KNOW what loader is on my BX23S.
he did post pictures in #58 and #60, even circled the 'rod' to show what his was referring to. My analogy to computers is simple...information is critical.
I don't like to 'assume', prefer good detailed,accurate information before make a decision. While I only own one Kubota and have easy access to 5 others, it's not important to me to know what new models come out.
Sail
11
19
TX
no worries y’all, not worth getting spun up :cool:
going to call corporate and see if they‘ll show me any love…believe it or not it has zero to do $$$ as much as the company doing the right thing. It was/is a weak design if it failed under regular use, or any use for that matter. I’m no stranger to equipment, had a few tractors over the years and I‘ve run em hard (as a yout) and never bent or caused such a problem.
just one man’s opinion
7,519
Most likely a pin didn't get latched properly and the implement twisted causing the plates to be "de-tuned"! The plates can not be twisted if both pins are locked and stay locked.
B737
LX3310
Jun 9, 2019
2,022
2,205
Sail didn't "hijack" anything, do you even know what that means? He simply continued a thread that was directly related to his problem, in an identical way as OP.
The only thread hijacking around here is from you blabbering on about electronics and pontificating about "metallurgy", good job!
10,720
Not sure why everyones is not understanding...
This thread is about a bend quick attach, and the "rod" or tube that connects them as well as keeps the two shoes in alignment. What's not clear about that? This is a common issue sadly with a few of the Kub SSQA loaders. What does it matter if it's a HST or DT? The loaders are the same right? Cut the guy some slack, he came here for help.
Arguably, @Sail should have created a new thread rather than reviving and old one, and gave more detail about his issue, but it's not hard to figure out...and I'm not even a Kubota guy :LOL:
So, @Sail , I very well may be covered under warranty, you will have to battle wit the dealer on that.
I clearly didn't read back into the thread, I was confused how an engine rod got bent using the loader?
Hence the reason I was asking what exact model tractor it was. ;)
Yes your right a bent SSQA attachment plate alinement rod has zip to do with the tractor it's on.
10,720
I recently bought a new 3902, it now had 30 hours and the rod has bent (n)
how is this not a warranty issue?
Ok now that I'm back on track as to what rod got bent.
First thing to do is look at the latch pins:
With no bucket on it, are they booth pointing the right direction, wedge to the rear?
Are they both extending down the same distance?
When you throw the latches are the snapping into place?
If any of these are an issue, that will give you some ground to stand on as far as it not being operator or operation error.
If none of the above are present then sorry to say this, but yes it's operator or operation error.
You either didn't get it latched into the SSQA plate properly, or something caused it to unlatch or pop the pin up and unlatch.
Bending that rod only happens when one latch or the other does not stay latched, I've had sticks and branches unlatch them, I've had rocks pop the latch pin out of the pocket, it just happens.
Some would argue that it's a design defect, but with 100's of thousands of this exact setup, that has been used for years and years successfully, it's hard to put any weight behind that argument.
Several on here have implemented methods to mitigate the issue, by adding supplemental lever holders and if your working in brush and things of that sort it's a very good idea to do that.
Sail
11
19
TX
Just a follow up, the dealer I bought it from made good on the fix, no charge. (y)
Ewald Kubota Marble Falls
….never did get ahold of corporate
Sauce73
B2301
Sep 9, 2020
Lafayette, Indiana
I have straightened at least 6 of these, a couple were even this twisted. Just block the right side and roll quick attach back. Bring it back slow, let the pressure off and measure the distance on each side. If you do go too far on the left, move the block from the right side to the left side and try again.
Thank you for sharing your experience. This worked perfectly. IMG_2208.jpeg IMG_2211.jpeg
Sauce73
B2301
Sep 9, 2020
Lafayette, Indiana
If it was me, I would try putting a two by four in that shortest ram to stop it from returning and see if the hydraulics can pull the other back in line. If it does then you can reassess whatever welding or gussets etc you may add to strengthen it. You are correct in assuming the latch released I believe. It is designed to work as a unit with the bucket in place.
Thank you for sharing, that’s what makes this site great!
MudMaster
MX5400, LA1065, QH16 (T&T), Precision Mfrg Big Mouth Grapple, Artillian Forks
Feb 19, 2023
21
27
Upper Black Eddy, PA
@highcountrybarry -- This was brilliant. Was using my SA20 auger the other day when, unbeknownst to me, one of the hoses (which are very long to allow the auger to go deep) caught and flipped up one of the QA latches. By the time I realized, the left plate was completely disengaged and the connecting bar bent. Went back to the barn, stuck a 4x4 exactly where it appears in the photos above, and curled the loader function. Couldn't believe how well it worked! A few quick bursts, and the plates are now (almost perfectly) flat against the floor. Saved me mucho $$$ on a new QA assembly (and the down time waiting to receive it). SUPER HELPFUL -- THANK YOU!!
garjess
KX040-4, L3240, grasshopper 428D
Nov 13, 2025
New York
Just a bad day, worked in rain most of morning then this......
Rain let off early morning so I started brush hogging paths, food plots, trails, and removing some trees that had fallen. Getting ready for the up coming deer season on our lease.
Cut up and pushed a tree back in woods that had fallen near one of our stands.
Left there to move an oak that had fallen in one of our food plots. Bucked the tree which was not large in diameter into about 8' sections so I could push it out of plot.
Pushed on one part and then on the second when I noticed the bucket was not level. Apparently when I pushed the first tree near our box stand into the woods one of the locking handles released and then when I pushed on the smaller tree that was in the plot it tweaked the quick attach,
See pics attached, one is of the big tree that we cut and pushed into the woods no problem and the other of my bent quick attach for the bucket.
Thoughts on what to do, try and repair or replace? I don't have the means to try and bend back in place but plenty of welding shops around I could carry it to.
So, buy new one which seems to be as simple as removing 4 pins and plenty of cash or carry to welding shop and have them remove round cross bar and weld new one in place.
You guys and gals here always have great ideas and insight so let the suggestions, thoughts and advice begin.
I want it to be right! My 2 year old daughter loves her Katie Kubota and is sad she is broken down and has to go see a doctor! Anything that is broken from a limb to well any thing she says it is "broken down dada fix it".
I bent mine at least as bad as the OP's pics. I used a block of wood to keep it at 90 degrees so the hydraulic cylinder has the most leverage. It wouldn't pull it back. I then used the hydraulics and pushed up against a tree and fixed it in about 5 minutes. Simple easy fix and other then the paint being cracked you can't tell it ever happened. I'll make sure both sides are latched from now on!
