M9000 engine oil question
Gb540
44
15
Central US
Wondering if folks could recommend an engine oil for this besides Kubota's own?
Per the owner's manual this calls for API CD, CE, or CF in 10W30 or 10W40.
The only oil I'm finding in CF is Shell Rotella T1, which is a straight weight. Definitely need a multiweight here due to climate/winter.
ferguson
L3130
Jan 19, 2022
296
115
w.v.
Any name brand Diesel oil most common is 15W-40 WT ( this should stir the pot )
jyoutz
Jan 14, 2019
3,055
2,100
Edgewood, New Mexico
I use Valvoline extreme synthetic for diesel motors. Lots of people use Rotella T6. Both are good.
Gb540
44
15
Central US
Amsoil or no oil…
I'll run Olive Oyl if that meets the spec! (Maybe some spinach for more power?)
Seriously though, I've heard some late-spec oils shouldn't be used in the older diesels, and don't want to mess up here. Will run the Kubota stuff if I need to, but unlike say the UDT2 I doubt there's anything special provided it meets spec.
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
There was heavy sarcasm in my reply 😂. But any diesel rated oil will work for you. I personally use rotella 5w40 in mine.
Gb540
44
15
Central US
Ok, think I got it figured out.
Per the source, API.org, and if I'm reading it correctly:
• Service categories CD, CE, and CF are long obsolete.
• CH-4 and CI-4 are designated replacements.
• What this machine CAN'T use is FA-4.
Someone please correct me if I'm wrong. :) Was assuming this machine is fairly forgiving on engine oil (and appears it is), but it can get expensive to assume.
6,627
Shell Rotella T-4 (Dino) or T-6 (Synthetic), you can get it in 10w30, 5w40, and 15w40 all of them will work equally well in your tractor.
And a Very good substitute to UDT, is Mystik JT5.
3,326
Delo400 from WalMart…(2.5 gals for $41) or Wally’s own SuperTech is as good as most other major branded regular diesel oil. It’s a “CK” rating…supercedes all those listed in your Owners Manual.
mattwithcats
778
71
Any CJ-4 or CK-4 rated oil, preferably full synthetic, in 0W-40, 5W-40, or 15W-40…
The “C” stands for Compression…
The “J” or “K” is the version,
and the 4 is for 4 stroke, I believe.
The first number is viscosity when cold, hence the “W” after..
The second number is viscosity when hot…
This is a general rule of thumb, there are situations where other viscosities and/or ratings may be needed…
