Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Is that a makeshift geo grid for ground stabilization? If not, what is the purpose? Reminds me of those stabilization grids they place under driveways that keep the stone from shifting/washing out.
Yes to help prevent erosion, he mentioned watering lane, meaning the water flows through there from a pasture or overflow from a tank.
11,758
I started the second driveway in earnest this afternoon. I only put about 45 minutes of work in with the M6060 and EA Extreme box blade to see how it's going to go. I'll hook up the MX to the small dump trailer once the sprayer is off, and load that up to move dirt rather than making numerous trips to the dirt pile to dump the M6060 bucket out. That's just not efficient.
This driveway will be about 175 yards long when it's done and it'll be really helpful bringing trailers and the boat up the hill. Currently there's a really sharp bend where the lower gravel driveway turns into the asphalt driveway and it's a pita pulling a trailer, and a real pita in the winter since I have to take the truck out of 4wd to make the turn. This new driveway will fix all that.
The elk were checking out my work yesterday morning! I'm planning on hooking up the smaller dump trailer to the MX this afternoon and continuing to "excavate" in preparation for gravel. I'll be using the EA box blade behind the M and the loader in front to loosen and then load up the trailer.
Reactions: 8 users
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
819
Andover, KS
The rain is Thur. night and Friday!
I was watching the radar, (didn’t want to get caught in the field), rain was moving towards me & just fell apart. Oklahoma took all the moisture. You are right, we have more chances. 🤞
Did you cut those tires yourself?
I picked up the tires at Express Tire in Emporia. We had a local guy cutting tires for the State. 1 side of a semi tire is what is put around orange traffic cones to keep them upright in the wind. The other 1/2 works good for watering lanes. He retired & sold his machine.
I have not found a good way to cut them.
Trapper Bob
Jan 17, 2022
446
819
Andover, KS
You are right. Except the traffic will be cattle. Our local NRCS says the life of a stock pond where cattle can freely walk around is 17 yrs. Then, the pond is shallow because of the cow’s hooves beating down the banks & pushing mud to the center. There is a lot of weight on the small surface area of a cow’s hoof.
A pond where cattle have restricted access can last 35+ yrs. This watering lane is that spot where the cattle will be able to get a drink (& the only spot). The rest of the pond will be fenced. There will be temporary panels between the posts that can be moved as the water level goes up or down. This will limit the amount of steel exposed to water (rust).
There is more work to be done. Stay tuned😁.
Trapper Bob
Jan 17, 2022
446
819
Andover, KS
62 Ton or ~44 yards is no joke, that's a solid day of tractor work.
Never seen the cut tire for underlayment trick.........makes sense when I think about it. How were they cut, sawzall?
There is a machine, but I have not seen it. The cuts are clean & a little rubber particles make me believe a rotary blade was involved. I have tried to cut tires in the past & the rubber would pinch the blade. It wasn’t fun. These tires were cut in advance of disposal (landfill I think). They are available, but you are asked to sign a waiver stating you’re not going to do something environmentally irresponsible with them. This is a way to get a little more use out of an oil d tire.
Trapper Bob
Jan 17, 2022
446
819
Andover, KS
The scenery around your “work” is wayyyy better than mine.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Very Nice. Doing it right from the get go.
radas
Mar 21, 2022
719
834
Had no idea cattle were so complicated (and destructive), thank you for the education!
6,974
Broken water service repair today. Kind of a crappy job at a very nice home. Didn't bother taking any pictures...
36" grading bucket worked very well for the clean up. I have to remember to not be so lazy and actually unchain it from the trailer and actually use it! It's so much faster and does a much better job being "toothless".
On to another water service in the morning. This one ought to be a real hoot. Steep front yard with pole (and several guy wires) right where we need to make the connection at the curb stop. :(
7,633
Cattle as individuals are not destructive (if they have food and water) it's a herd of them that makes a difference. Kind of like humans!
Bearcatrp
Mar 28, 2023
1,369
992
Minnesota
Picked up my new front tire today. Got it mounted after work. 80 bucks for tire and rim. Also attached the rear blade I picked up this past weekend.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Oh this could have been bad. Caught some horse wire(previous owner had in 1970s, generously left me pieces scattered everywhere) underneath the tractor frame, didn't make it to the shredder. This wire is thick and strong too. Glad I saw this quickly and easy fix to remove.
Goodnights!
I think this old Bute L305DT needs a LED lighr bar up front!
Reactions: 6 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,710
4,493
PEI Canada
Goodnights!
Nice catch. That would of been a real chore to get untangled.
11,014
Loaded up for this week's festivities and came up with an easy way to get the plate compactor on the trailer as well. Who knew mini's could be so much fun? 🙂
Yea I use the Bob Cat to load mine, muscled it the first few times till the brain kicked in!
11,014
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
ZEP orange cleaner will wipe the grease right off of it, and bonus will leave it smelling like an orange!
Can't reach all the pivot areas behind the frame/lift arms. I think I'm gonna have to start pressure washing it more often, like every 50hrs to see if that helps cut down on the amount of grease build-up.
