Just puchased 6 acres, now what??
9,330
Yea, never cut too many down, takes too dang long for them to grow back!
This from a guy that has way too many trees on his place! 🌲🌲🌲🌲🌲🌲🌲🌲🌲🌲🌲🌲🌲🌲🌲🌲🌳🌳🌳🌳🌳🌳🌲🌲🌲🌲🌳🌳🌲🌲🌲🌲🌲
8,666
I have a few large oaks that need to come down. But almost done taking down the trees. Cleared area will get turned into lawn and fenced for the pooch. About 1 acre, probably a touch more.
Taking the trees back far enough from the build site so it won't be a danger from falling on the house, shop, or camper.
We were looking at double wides till the lenders started throwing in $10k to 17k in fees 😱😱😱 I told them to pound sand. The company looking at $17k in fees wouldn't send me the info in writing. I was actually fixing to turn them over to the states attorneys office for price gouging.
I'm gonna have the septic installed once it dries out enough. Water meter can get installed at anytime. I'll have the septic permit today. Then we can start moving forward.
We're gonna have an 18x40 carport w/ slab installed for an RV. As well as a 30x40 shop installed for storage.
Later, we will have rough in done for plumbing and a 30x40 slab poured. Then get a steel building installed on that for a Barndominium. Then we will frame and install the interior as we see fit.
9,330
Sounds like you have an excellent plan!
Heating everything is probably not much concern for you is it?
It's cooling that is more of a concern?
8,666
Cooling and heating are issues in this area. We do get cold snaps down to 0Β°f. But then we get Temps up to 130Β° in the summer.
Both aren't two big of a deal. They've come a long way with heat pumps. We will probably figure in a pellet stove for supplemental heat in the winter as well as back up heat for when the power goes out.
9,330
Our place is all Hydronic, (slab) heating and cooling.
Heating is awesome, constant heat all winter, open a door and temps don't fluctuate like a air heated home.
Garage is 30 x35 and heated/ super nice to work in there!
Open doors and close doors and heat rebounds quick!
Last year was our first summer in this house and the hottest it got was one day 71 inside, when it was 103 outside.
Normal average was 66 inside.
We don't even have the cooling (ground loop and exchanger) hooked up and running yet.
You can do a hybrid system for fairly cheap to do all of your DMH and Heating in one unit, and they are super efficient.
Just thought I would mention it as something to think about, as the investment is small and the pay off is huge.
8,666
Around here you would be hard pressed to find someone to install it. And if they did, it would be $$$$$$.
Geothermal is the same way. Very pricy up front, and good luck finding someone to fix it if it breaks.
Jchonline
599
Red Feather Lakes, CO
We also have hydronic in floor including the garage. Its really nice up in the mountains. We have a few mini splits for cooling deep in the Summer, but 95% of the year they arent needed.
9,330
Sorry, I didn't think about it that way, I did all my own work so it didn't cost me very much.
8,666
Our place is only gonna be either 1200sqft, or 1500sqft. 2 bed, 2 bath either way. Just depends on if there are any specials on steel buildings when we get ready to purchase.
We'll either go with a multi zone mini split or have a traditional heat pump installed.
Anyone can work on them around here 😁😁😁😁
I do plan on a pellet stove being installed. As well as a generator tie in.
7,001
9,330
If you were closer I'd give you a really nice pellet stove.
We bought it for the new house, used it in the trailer, then the new house didn't need it.
I might put it in the next shop as a quick heat burst.
2,402
Consider putting in a whole house dehumidifier since the air conditioner will probably not be running as much as normal if you seal and insulate it well. You can also use the dehumidifier for air exchange as well.
8,666
Both properties are rolled.into 1 πŸ‘πŸ‘πŸ‘
Wife will run over Tuesday to finish up getting our account set up with the water department. I had the bulk of it set up, but the manager through a fit that our address wasn't listed on our perc test. Had the legal description and GPS coordinates. But that wasn't good enough πŸ™„πŸ™„πŸ™„πŸ™„
Had to have the contractor who performed the perc test write the address in, initial it, and email it to them. They recieved it after closing. So it's just a matter of turning over our paperwork, them pri ting off the copy with the address written in, giving them a check for the meter install, permit, and hookup fee. Then in about 10 days we'll have water on the property.
Still getting quotes for the septic install. 1 guy was booked up and can't get to it. Another guy came in super high 😳😳😳 so we're hoping to get s couple more bids with a more reasonable price.
Started knocking down small stuff and then bulldozing my way through an area with the push mower. The briar are so thick, I got fed up with them snagging my boots while I'm clearing out there. The added bonus of using the push mower, is I'll definitely be able to go through the arra with the zero turn without issue.
7,070
Daren - what a the design of the sewage system?
8,666
Basic septic system with a pump added in since the leach field location is at a higher elevation then the build site.
Pump and 30 gallon box adds $300 to the total parts bill. I priced out all the materials for the job.
