Picture of your tractor on your trailer
Bmyers
May 27, 2019
3,636
4,939
Southern Illinois
"Looking at a GN"
Absolutely...YESSSS!
A GN is truly fantastic compared to a bumper pull!
Although it may take a little rigging to get it to work with my Expedition, but I'm sure we can find some way of getting it to work. :D
Either that or I will have to use my dad's Ram 2500 or my BIL F450 until I get my own rig.
5,188
When I had a GN I had an F-250, and it was GREAT!
Then bought a Suburban with 454, and had to get a bumper pull.
Using the 14K (loaded to 12K max) bumper pull behind the Suburban was miserable, compared to the GN on the F-250.
Just cut the top off that Expedition, and the GN will work fine.😪
Being nearly 82 now it is all gone ......except for the 14K bumper pull, which is in my barn on blocks.
I could pull that with my son's Suburban, if I should need to.
Snowman7
May 20, 2020
403
310
Boyne Falls, MI.
Perhaps you can send me a couple of yours for an independent evaluation. I will send them back ... I promise! :unsure:
If you overnight them I can test them out on the MX6000HST this Saturday as it makes its way to its final resting place on 50 acres up near Polebridge, MT. A beautiful spot to live out its days. :cry:
It'll probably be puttering around Bowman Lake from time to time.
That pic is stunning!
7,007
Here's a few pics of the new trailer after applying a coat of used ATF on the PT decking. 20 ft trailer took every bit of a gallon of ATF. Total cost, about $2 for a brush. Sorry, no tractor in this picture.
There is no greasy feel whatsoever on the deck boards after a day. The ATF soaked into the wood almost immediately. It would appear to me to be a better option than the used engine oil I used on another trailer. I'm planning on a second coat of used ATF before winter, maybe.
wet:
Dry (pics taken 4 hours later)
7,007
11,757
wet:
Looks good. Is there a piece of steel plate that covers the transition from the flat deck to the dovetail? My trailer has that to protect the wood at the joint.
7,007
No, unfortunately.
5,188
That's something I see with many trailer owners. I've seen much worse lean than pictured here - and both ways - front way high and rear way high.
Very dangerous for both the towing vehicle, and the vehicle following.
i speak from experience!
Trailer came loose from vehicle ahead: My car was totaled.
Crash277
BX23S
Jan 17, 2021
844
623
Friend of mine borrowed my Lx2610 with his diesel Jeep. Towed it good he said.
just out of curiosity I looked up the towing specs. not bad for the size of the vehicle. 6500lbs for the diesel and 7700lbs with the 3.6l. A minimum 7000lbs towing capacity is what i need in a truck (that's the capacity of my trailer). might jsut be able to add the gladiator to the list of trucks to look at this summer
troverman
Kubota M4D-071 and Kubota ZD-1211-72
Jun 9, 2015
1,187
268
NH
I wouldn't. Rear MotorTrend's assessment of towing with the Gladiator...they are, or at least can be, pretty unstable with a heavy load. There are also a number of them with broken or bent rear frame sections from towing, within the rated amount, but off-road. The Gladiator has a couple of things against it as a tow vehicle - there is considerably hang-over of the frame and bed past the rear axle, relative to some other midsize like a Tacoma, Ranger, Colorado, etc. This is so Jeep can try to have a reasonable ramp breakover angle for off-road, as well as keep commonality with the front portion of the Wrangler JL frame. There is quite a bit of lever action on the Gladiator's hitch hanging back so far from the rear axle. Finally, unlike all other midsize and half ton trucks, the Gladiator has a solid front axle with slightly wandering steering, and coil springs at the rear which can be softer and "squishier" than the normal leafs.
It's worth noting the diesel is very powerful and is rated to tow over 10k in the RAM 1500 pickup with the same engine. However, the smaller Jeep grille and engine bay limits cooling, along with a smaller, weaker frame compared to the half ton lower the tow rating here. Both the gas V6 and diesel have an excellent 8-speed transmission made by ZF. I'll also point out the only Jeep Gladiator to get the 7,000lb tow rating is a specific model - a Sport with the Max Tow package. This is a basic trim model, which may be a problem for some people.
Don't get me wrong - I love the Gladiator and Wrangler, in fact, I own a 2022 Gladiator Overland (with a 6k tow capacity) but I would not try to tow more than 5k with it.
