hoot owl
L2501 with loader and backhoe
Nov 13, 2022
94
272
53
65653
No pictures. But I dugout around 40 tree stumps today and piled it up for burning, Monday. Most of them were about 6" across. we cut them about a month ago about 4' high. We are clearing about 3 acres to plant for the bees at home. I will take some pictures Monday. Also it smells real good as most of the trees are Sassafras.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
Drove fence posts (63) for a cross fence today. The wife is in the tractor. She will prob come back for me. 😳
Reactions: 6 users
mdhughes
L3901DT
Dec 10, 2014
1,351
1,105
Ste Geneveive county, MO
Did some firewood yesterday. Moved the last of the cull logs I got last year. This is the biggest piece that was in the load. Was a lot of work to cut and split.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,537
central ct
Since we have a couple of house showings today (have to be gone during them) I gave the tractor a break today.
I did go and start to service my 'new to me' Leinbach rake. The zerks for the wheel shafts looked like they have never been greased. According to the PO he did one job at his house with it and that's where he bent a couple of tines on large rocks he snagged. Since then its been aging outside. Note to self, don't be stupid, use the grapple to get rid of larger rocks. The rake will be fine on brush, sticks and smaller rocks. It took the grease nicely - no plugged zerks :)
I have a 6 replacement tines coming tomorrow so tried to break the bolts free. Good luck with that. Had the feeling that 10 more ft-lbs of force and I would have 2 piece bolts :( Mouse Milk to the rescue! Put some on both threads as best as I could get it in there, wait one hour and magic. They both broke free easily. Tomorrow I'll elevate the rake and replace the 2 tines.
Keadog
MX 6000
Dec 22, 2021
Our generator died last week. Was starting its weekly warmup run and ran about 3 seconds then made some very, very bad sounds and died. Forever as it turned out. Called the guy that services/maintains it and he came right over. Opened the cover to a pool of oil. I asked about a replacement and he said he had 12 coming in this week but all were pre sold. He said if I could find one he could come over in 2 days but only had 3 total guys and needed 4 to lift safely. "Can you lift 100#?" "Yes". "Do you have a way to get it to the site if you find one?" "Yes I do". Found ONE in stock, bought it over the phone and picked it up.
He showed up bright and early Friday with his 2 guys but the Kubota was the star of the show.
Out goes the bad generator, in goes the good generator...
Those fake pallet forks worked fine but real pallet forks are on my wish list.
Reactions: 11 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,481
3,531
PEI Canada
Any idea how old or how many hours were on your generator?
Keadog
MX 6000
Dec 22, 2021
251 hours. 10.5 years old. The guy that services it has hundreds of accounts that he manages. Said he has never seen a catastrophic failure like that with so few hours and has some accounts that have 30 year old generators.
It was serviced every fall with a synthetic oil and filter change. The longest it ran continuously was last summer when the power was out for 91 hours. It burned 2 ounces of oil then. So most of its life was spent warming up and running for 20 minutes every Wednesday AM.
Just bad luck I guess?
Keadog
MX 6000
Dec 22, 2021
I forgot to mention the R14s were amazing. Had to drive over our (very wet) lawn and within a couple days it was hard to see where I drove. If I had the R1s on, there would have been deep ruts "forever".
S-G-R
Jun 17, 2020
1,481
3,531
PEI Canada
Too bad, we put ours in about 3.5 years ago and it does its 10 minute weekly test run but I do manually run it it 20-30 minutes occasionally if we haven't had an outage.
R14's are terrific tires imo. Wasn't a fan of R4's, had R3's on my last tractor but the thorns were hard on them. No complaints about the R14's.
5,683
Brush-B-Gone today. That's all I have for now.
Tuesday should be a fun dig and PowRMole in center city Allentown. Can't wait to play "frogger" on N. 6th street. :(
Reactions: 6 users
5,126
Didn’t take many pics but used the tractor quite a bit today. Road was getting wheel tracks in it, gravel migrating toward ditches, a couple small potholes starting at the edge where it meets the paved state road, ditches silting in a bit, backfill for the tree removed from center of drive finally stabilized enough for a final grade, etc. None of it bad, just needed attention. Didn’t take but about an hour. Would have been much longer without the hydraulic top and side link. Pic almost looks like there’s dirt mixed in with the gravel but that’s actually just wet gravel from the ditch where some was buried under leaves prior to the leaves being blown out today as step one of the process.
Also used the grapple to remove a couple of old scraggly bushes and a 3/4 rotten little section of split rail fence the were tangled in. Kind of sweet to rip all that out and dump it without ever getting out of the seat.
Then back to the bucket to backfill the holes left by the fence posts and bushes. Final touch was getting a couple buckets of chips about a year old out of the main chip pile to use to mulch the area.
Reactions: 7 users
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
Fencing supplies are a major expense now days!
Yes they are! I’m glad this is a short run.
I have a pond to fence off & watering lane to put in. I hope I have enough leftover supplies to complete that job. Might have to alternate green & orange T-posts.
GreX
BX2380
Jan 8, 2023
185
132
Maine
Added ROPS work lights 2-double sets, so nice to be able to see in front, behind, and on the sides while moving around at night/early mornings. Was fairly easy to install, though I'm not super thrilled with the light switches being 'mounted' to the ROPS via zip-ties - anyone have suggestions on a different location or different mounting style than zip-ties? I purchased them from ropslights.com
ctfjr
L3800HST
Dec 7, 2009
1,982
2,537
central ct
If you have empty slots available (like for a draft control), I found them perfect for control switches. They are out of the way and convenient.
5,683
The kit from ROPS lights, came with two electrical boxes with switches on them, they're just a bit bulky and kind of an eye sore on the ROPS. I'll take a picture here later this morning, was just hoping for something that looked a lot more 'factory'.
Huh? That's not what I posted. The kit comes with a relay and lighted (round) switch. I wired mine to the battery with relay so that I could turn the lights on without ignition on or running.
Here is mine installed in the dash. Doesn't get much simpler that this.
